Home » Archived » M2M (model-to-model transformation) » [ATL][UML] Problem with UML transformation
[ATL][UML] Problem with UML transformation [message #66137] Wed, 14 November 2007 12:25 Go to next message
Originally posted by: david674.bezeqint.net
We try to develop the following ATL transformation:
Source metamodel: UML2 from EMF Registry
(uri:http://www.eclipse.org/uml2/2.1.0/UML)
Target metamodel: a class diagram we built in Papyrus (we use version 1.8)
Source model: a statechart, also built in Papyrus
We have two problems:
1) we cannot use the .uml file from Papyrus as a target metamodel. We've
read through the related ATL use case UML2MOF:
http://www.eclipse.org/m2m/atl/usecases/UML2MOF
and the Papyrus user guide:
http://www.eclipse.org/m2m/atl/usecases/UML2MOF/userGuide.ph p.
In the Papyrus guide screenshots of Run Dialog is shown "Papyrus
Transformation" launch configuration. But in our installation it's absent,
so we cannot work through the guide!
(We upgraded from the Papyrus 1.8.1 archived update site and 1.7.x update
site -- but this did not help.)
2) In an ATL rule, how we should reference to elements within the source
UML2 metamodel, specifically, Statemachine, Region, State etc.? Should the
source metamodel name be "uml", as the name of the main package?
Anybody who can help, please answer ASAP!!!
Thanks in advance,
David
Re: [ATL][UML] Problem with UML transformation [message #66164 is a reply to message #66137] Wed, 14 November 2007 13:01 Go to previous message
--------------090204080703000708050208
David a
Previous Topic:[ATL] Standalone ATL transformation of UML2
Next Topic:resolving links to input model
Current Time: Tue Jul 15 09:30:35 EDT 2025
Powered by FUDForum. Page generated in 0.08446 seconds
