linebreak between Strings? [message #66130] |
Wed, 28 January 2009 05:36  |
Originally posted by: jgreen.upb.de
is there a way to insert a line break between strings?
Something like 'line1 text'.concat('\n').concat('line2 text')
(which doesn't work)
Thanks for helping.
Joel
Re: linebreak between Strings? [message #66172 is a reply to message #66151] |
Wed, 28 January 2009 10:25  |
Christian W. Damus wrote:
> Hi, Joel,
> The OCL concrete syntax for strings is unspecified, alas.
> Literally including a newline in your string literal doesn't work, either:
> 'line one
> line two'
> Perhaps http://bugs.eclipse.org/242880 should be prioritized for this
> release
That's it, I didn't see the bug.
> (once the crazy deadlines at my day job pass).
I know, sometimes work keeps you from doing useful things ;)
> There is some measure of code in the parser that is intended to process
> Java-style escapes; it doesn't seem to be working.
> cW
> Joel Greenyer wrote:
>> Thanks for helping.
>> Joel
FUDForum. Page generated in 0.07247 seconds
