Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » teneo - performance problem with new impl of HibernatePersistableEList.isLoaded()
teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #66126] |
Tue, 02 January 2007 16:45  |
Hi Martin,
your new implementation of HibernatePersistableEList.isLoaded() gives me a huge
performance drop. Before this change it took < 1 min for a particular load,
afterwards it takes several hours.
I don't know what has changed but I just wanted to let you know about this. I
think it cascades too deep and too early now. Or may be it is now correct
behavior and I have to completely change my code...
Andre
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #66233 is a reply to message #66212] |
Tue, 02 January 2007 19:54   |
Hi Martin,
I've turned on debug output and found that is definitely something wrong with
that code. Here is the output from the expansion of a tree node in the editor
which will expand to having just one(!) child:
2007-01-03 01:42:41,297 [main] DEBUG
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEList -
Persistentlist already initialized, probably eagerly loaded: EList of type:
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEList of
member clients owned by com.pareis.trading.System with delegate list
org.hibernate.collection.PersistentList
Started loading elist EList of type:
Reconnecting session to read a lazy collection, elist: EList of type:
Loaded 1 from backend store for EList of type:
Finished loading elist EList of type:
The same list is loaded 6 or 7 times. I used the debugger and could see that it
was not initiated by some notification mechanism. Here is the stack of the first
load() call taken from the debugger:
Thread [main] (Suspended)
HibernatePersistableEList.isLoaded() line: 70
HibernatePersistableEList(PersistableEList).load() line: 176
HibernatePersistableEList(PersistableEList).delegateSize() line: 400
HibernatePersistableEList(DelegatingEList).size() line: 214
DelegatingEList$EIterator.hasNext() line: 1000
SystemItemProvider(ItemProviderAdapter).getChildren(Object) line: 339
AdapterFactoryContentProvider.getChildren(Object) line: 167
TreeViewer(AbstractTreeViewer).getRawChildren(Object) line: 1166
TreeViewer.getRawChildren(Object) line: 768
TreeViewer(AbstractTreeViewer).getFilteredChildren(Object) line: 574
TreeViewer(AbstractTreeViewer).getSortedChildren(Object) line: 543
AbstractTreeViewer$1.run() line: 728
BusyIndicator.showWhile(Display, Runnable) line: 67
TreeViewer(AbstractTreeViewer).createChildren(Widget) line: 705
TreeViewer.createChildren(Widget) line: 892
TreeViewer(AbstractTreeViewer).handleTreeExpand(TreeEvent) line: 1251
AbstractTreeViewer$4.treeExpanded(TreeEvent) line: 1263
TypedListener.handleEvent(Event) line: 181
EventTable.sendEvent(Event) line: 66
Tree(Widget).sendEvent(Event) line: 928
Tree(Widget).sendEvent(int, Event, boolean) line: 952
Tree(Widget).sendEvent(int, Event) line: 937
Tree.wmNotifyChild(int, int) line: 6315
ViewForm(Control).WM_NOTIFY(int, int) line: 3794
ViewForm(Composite).WM_NOTIFY(int, int) line: 1166
ViewForm(Control).windowProc(int, int, int, int) line: 3298
Display.windowProc(int, int, int, int) line: 4025
OS.CallWindowProcW(int, int, int, int, int) line: not available [native method]
OS.CallWindowProc(int, int, int, int, int) line: 1844
Tree.callWindowProc(int, int, int, int) line: 1321
Tree.WM_LBUTTONDOWN(int, int) line: 5206
Tree(Control).windowProc(int, int, int, int) line: 3279
Tree.windowProc(int, int, int, int) line: 4785
OS.DispatchMessageW(MSG) line: not available [native method]
OS.DispatchMessage(MSG) line: 1925
Display.readAndDispatch() line: 2966
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 1914
Workbench.runUI() line: 1878
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 419
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
TradingEditorAdvisor$Application.run(Object) line: 99
PlatformActivator$1.run(Object) line: 78
EclipseAppLauncher.runApplication(Object) line: 92
EclipseAppLauncher.start(Object) line: 68
EclipseStarter.run(Object) line: 400
EclipseStarter.run(String[], Runnable) line: 177
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available
[native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object...) line: 585
Main.invokeFramework(String[], URL[]) line: 336
Main.basicRun(String[]) line: 280
Main.run(String[]) line: 977
Main.main(String[]) line: 952
And here is the list variable:
this HibernatePersistableEList (id=95)
delegate PersistentList (id=185)
eFeaturePath ""
estructuralFeature EReferenceImpl (id=163)
isLoaded true
isLoading false
logString "EList of type:
org.hibernate.collection.PersistentList"
modCount 0
owner System (id=183)
May be the reason is the isLoaded() call here:
protected void load() {
if (isLoaded())
return;
This does not test the isLoaded variable but calls isLoading() which calls
doLoad() but then without having the isLoading flag set to true? I'm really only
quickly guessing...
Andre
Andre Pareis wrote:
> Hi Martin,
> Ok, this method has been called frequently I think. In particular, I
> have seen calls initiated by this line:
> Object[] objs = delegate.toArray(); // this forces the load
> (frequently) which results in System.arrayCopy() calls which I also saw
> often.
> I haven't tried to disable the notifications but I will do that. But I
> think it has more to do with the arrayCopy invocation because I saw
> these very often when I suspended execution in the debugger occasionally
> during the long running operation.
> Thanks
> Andre
> Martin Taal wrote:
>> Hi Andre,
>> Hmm the isLoaded does not load the objects from the db (as this has
>> already been done), the only difference is that isloaded will now
>> attach loaded objects to the resource using the method:
>> addToContentOrAttach. Can the issue be in this last method? The
>> hibernate resource now also sends out load notifications as a default,
>> did you disable that?
>> gr. Martin
>> Andre Pareis wrote:
>>> Hi Martin,
>>> me a huge performance drop. Before this change it took < 1 min for a
>>> particular load, afterwards it takes several hours.
>>> this. I think it cascades too deep and too early now. Or may be it is
>>> now correct behavior and I have to completely change my code...
>>> Regards
>>> Andre
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #66278 is a reply to message #66233] |
Wed, 03 January 2007 04:06   |
Hi Andre,
Yes this is not good at all. Afaics it always calls doLoad when you call isLoaded and the load
method calls isLoaded.
I have changed the isLoaded method in HibernatePersistableEList and the load() method in
PersistableEList (in org.eclipse.emf.teneo).
Can you try this (is in cvs)?
If a build is easier to test I can make one for you so you can try that out.
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> with that code. Here is the output from the expansion of a tree node in
> the editor which will expand to having just one(!) child:
> - Persistentlist already initialized, probably eagerly loaded: EList of
> type:
> of member clients owned by com.pareis.trading.System with delegate list
> - Started loading elist EList of type:
> - Reconnecting session to read a lazy collection, elist: EList of type:
> - Loaded 1 from backend store for EList of type:
> - Finished loading elist EList of type:
> type:
> type:
> type:
> type:
> type:
> that it was not initiated by some notification mechanism. Here is the
> stack of the first load() call taken from the debugger:
> 339
> 1251
> [native method]
> 149
> eFeaturePath ""
> isLoaded true
> isLoading false
> modCount 0
> if (isLoaded())
> return;
> calls doLoad() but then without having the isLoading flag set to true?
> I'm really only quickly guessing...
> Thanks
> Andre
> Andre Pareis wrote:
>> Hi Martin,
>> saw often.
>> occasionally during the long running operation.
>> Thanks
>> Andre
>> Martin Taal wrote:
>>> Hi Andre,
>>> default, did you disable that?
>>> gr. Martin
>>> Andre Pareis wrote:
>>>> Hi Martin,
>>>> gives me a huge performance drop. Before this change it took < 1 min
>>>> for a particular load, afterwards it takes several hours.
>>>> about this. I think it cascades too deep and too early now. Or may
>>>> be it is now correct behavior and I have to completely change my
>>>> code...
>>>> Regards
>>>> Andre
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #66796 is a reply to message #66278] |
Fri, 05 January 2007 13:18   |
Hi Martin,
this is perfectly working now, it is even much faster than my quick fix ...
which is no wonder as you know what you're doing ;)
This bug must have always been in the code. I always had huge problems when I
wanted to manipulate/browse my database on a remote server over a 3mbit link. It
was unacceptably slow. I always had to replicate the database to my local
instance first. I always blamed it on the slow link assuming that all the
traffic was necessary.
Now that this is all solved, I can work with the remote DB as if it were local.
Thanks, man! This is a huge benefit.
Thanks & Regards & Nice weekend
Andre
Martin Taal wrote:
> Hi Andre,
> isLoaded and the load method calls isLoaded.
> load() method in PersistableEList (in org.eclipse.emf.teneo).
> out.
> gr. Martin
> Andre Pareis wrote:
>> Hi Martin,
>> wrong with that code. Here is the output from the expansion of a tree
>> node in the editor which will expand to having just one(!) child:
>> of type:
>> list org.hibernate.collection.PersistentList
>> type:
>> of type:
>> type:
>> of type:
>> type:
>> of type:
>> type:
>> of type:
>> type:
>> of type:
>> type:
>> see that it was not initiated by some notification mechanism. Here is
>> the stack of the first load() call taken from the debugger:
>> Thread [main] (Suspended) HibernatePersistableEList.isLoaded()
>> line: 70 HibernatePersistableEList(PersistableEList).load()
>> line: 176
>> 339 AdapterFactoryContentProvider.getChildren(Object) line:
>> 167 TreeViewer(AbstractTreeViewer).getRawChildren(Object) line:
>> 1166 TreeViewer.getRawChildren(Object) line: 768
>> 543 AbstractTreeViewer$1.run() line: 728
>> 1251 AbstractTreeViewer$4.treeExpanded(TreeEvent) line: 1263
>> [native method] OS.CallWindowProc(int, int, int, int, int) line:
>> 1844 Tree.callWindowProc(int, int, int, int) line: 1321
>> OS.DispatchMessage(MSG) line: 1925 Display.readAndDispatch()
>> line: 2966 Workbench.runEventLoop(Window$IExceptionHandler,
>> Display) line: 1914 Workbench.runUI() line: 1878
>> 149 TradingEditorAdvisor$Application.run(Object) line: 99
>> Main.basicRun(String[]) line: 280 Main.run(String[]) line: 977
>> this HibernatePersistableEList (id=95) delegate
>> PersistentList (id=185) eFeaturePath ""
>> estructuralFeature EReferenceImpl (id=163) isLoaded
>> true isLoading false logString "EList of type:
>> list org.hibernate.collection.PersistentList" modCount 0
>> if (isLoaded())
>> return;
>> Thanks
>> Andre
>> Andre Pareis wrote:
>>> Hi Martin,
>>> saw often.
>>> I think it has more to do with the arrayCopy invocation because I saw
>>> Thanks
>>> Andre
>>> Martin Taal wrote:
>>>> Hi Andre,
>>>> gr. Martin
>>>> Andre Pareis wrote:
>>>>> Hi Martin,
>>>>> min for a particular load, afterwards it takes several hours.
>>>>> code...
>>>>> Regards
>>>>> Andre
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #66811 is a reply to message #66796] |
Fri, 05 January 2007 13:34   |
Hi Andre,
Yes, let's hope that I know what I was doing ('the proof of the pudding is in the eating' is an
english term I think ;-). I am happy that this works (better) for you.
Note that there is a problem with the current teneo build. It appears that the build scripts
sometimes 'forget' to include external jars in the build. Luckily the current Teneo builds contains
almost no other jars (only two: log4j and commons-logging). It appears that commons-logging.jar is
not being included in the org.eclipse.emf.teneo.libraries plugin. If you already have
commons-logging somewhere else (which is very likely) then this issue is probably not a problem.
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> ... which is no wonder as you know what you're doing ;)
> when I wanted to manipulate/browse my database on a remote server over a
> 3mbit link. It was unacceptably slow. I always had to replicate the
> database to my local instance first. I always blamed it on the slow link
> assuming that all the traffic was necessary.
> local. Thanks, man! This is a huge benefit.
> Andre
> Martin Taal wrote:
>> Hi Andre,
>> call isLoaded and the load method calls isLoaded.
>> the load() method in PersistableEList (in org.eclipse.emf.teneo).
>> that out.
>> gr. Martin
>> Andre Pareis wrote:
>>> Hi Martin,
>>> of type:
>>> type:
>>> of type:
>>> type:
>>> of type:
>>> type:
>>> of type:
>>> type:
>>> of type:
>>> type:
>>> of type:
>>> type:
>>> line: 176
>>> 400 HibernatePersistableEList(DelegatingEList).size() line:
>>> 214 DelegatingEList$EIterator.hasNext() line: 1000
>>> 574 TreeViewer(AbstractTreeViewer).getSortedChildren(Object)
>>> line: 543 AbstractTreeViewer$1.run() line: 728
>>> line: 1844 Tree.callWindowProc(int, int, int, int) line:
>>> 1321 Tree.WM_LBUTTONDOWN(int, int) line: 5206
>>> 419 PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor)
>>> line: 149 TradingEditorAdvisor$Application.run(Object) line:
>>> 99 PlatformActivator$1.run(Object) line: 78
>>> 977 Main.main(String[]) line: 952 And here is the list variable:
>>> owner System (id=183) May be the reason is the isLoaded()
>>> call here:
>>> if (isLoaded())
>>> return;
>>> true? I'm really only quickly guessing...
>>> Thanks
>>> Andre
>>> Andre Pareis wrote:
>>>> Hi Martin,
>>>> saw often.
>>>> saw these very often when I suspended execution in the debugger
>>>> Thanks
>>>> Andre
>>>> Martin Taal wrote:
>>>>> Hi Andre,
>>>>> gr. Martin
>>>>> Andre Pareis wrote:
>>>>>> Hi Martin,
>>>>>> code...
>>>>>> Regards
>>>>>> Andre
The Netherlands
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #67223 is a reply to message #66811] |
Fri, 05 January 2007 15:52  |
The latest build should solve this issue of missing jars.
gr. Martin
Martin Taal wrote:
> Hi Andre,
> is in the eating' is an english term I think ;-). I am happy that this
> that the build scripts sometimes 'forget' to include external jars in
> the build. Luckily the current Teneo builds contains almost no other
> commons-logging.jar is not being included in the
> gr. Martin
> Andre Pareis wrote:
>> Hi Martin,
>> fix ... which is no wonder as you know what you're doing ;)
>> a 3mbit link. It was unacceptably slow. I always had to replicate the
>> link assuming that all the traffic was necessary.
>> were local. Thanks, man! This is a huge benefit.
>> Andre
>> Martin Taal wrote:
>>> Hi Andre,
>>> that out.
>>> gr. Martin
>>> Andre Pareis wrote:
>>>> Hi Martin,
>>>> tree node in the editor which will expand to having just one(!) child:
>>>> of type:
>>>> type:
>>>> of type:
>>>> type:
>>>> of type:
>>>> type:
>>>> of type:
>>>> type:
>>>> of type:
>>>> type:
>>>> of type:
>>>> type:
>>>> is the stack of the first load() call taken from the debugger:
>>>> line: 176
>>>> line: 1166 TreeViewer.getRawChildren(Object) line: 768
>>>> 705 TreeViewer.createChildren(Widget) line: 892
>>>> call here:
>>>> if (isLoaded())
>>>> return;
>>>> Thanks
>>>> Andre
>>>> Andre Pareis wrote:
>>>>> Hi Martin,
>>>>> I have seen calls initiated by this line:
>>>>> saw often.
>>>>> But I think it has more to do with the arrayCopy invocation because
>>>>> I saw these very often when I suspended execution in the debugger
>>>>> Thanks
>>>>> Andre
>>>>> Martin Taal wrote:
>>>>>> Hi Andre,
>>>>>> has already been done), the only difference is that isloaded will
>>>>>> now attach loaded objects to the resource using the method:
>>>>>> gr. Martin
>>>>>> Andre Pareis wrote:
>>>>>>> Hi Martin,
>>>>>>> may be it is now correct behavior and I have to completely change
>>>>>>> my code...
>>>>>>> Regards
>>>>>>> Andre
The Netherlands
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #600473 is a reply to message #66126] |
Tue, 02 January 2007 16:57  |
Hi Andre,
Hmm the isLoaded does not load the objects from the db (as this has already been done), the only
difference is that isloaded will now attach loaded objects to the resource using the method:
addToContentOrAttach. Can the issue be in this last method? The hibernate resource now also sends
out load notifications as a default, did you disable that?
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> Regards
> Andre
The Netherlands
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #600503 is a reply to message #66148] |
Tue, 02 January 2007 19:28  |
Hi Martin,
Ok, this method has been called frequently I think. In particular, I have seen
(frequently) which results in System.arrayCopy() calls which I also saw often.
I haven't tried to disable the notifications but I will do that. But I think it
has more to do with the arrayCopy invocation because I saw these very often when
I suspended execution in the debugger occasionally during the long running
operation.
Andre
Martin Taal wrote:
> Hi Andre,
> already been done), the only difference is that isloaded will now attach
> gr. Martin
> Andre Pareis wrote:
>> Hi Martin,
>> Regards
>> Andre
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #600508 is a reply to message #66212] |
Hi Martin,
[native method]
eFeaturePath ""
isLoaded true
isLoading false
modCount 0
if (isLoaded())
return;
quickly guessing...
Andre
Andre Pareis wrote:
> Hi Martin,
> often.
> Thanks
> Andre
> Martin Taal wrote:
>> Hi Andre,
>> gr. Martin
>> Andre Pareis wrote:
>>> Hi Martin,
>>> Regards
>>> Andre
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #600529 is a reply to message #66233] |
Hi Andre,
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> type:
> type:
> type:
> type:
> type:
> type:
> 339
> 1251
> [native method]
> 149
> eFeaturePath ""
> isLoaded true
> isLoading false
> modCount 0
> if (isLoaded())
> return;
> Thanks
> Andre
> Andre Pareis wrote:
>> Hi Martin,
>> saw often.
>> Thanks
>> Andre
>> Martin Taal wrote:
>>> Hi Andre,
>>> gr. Martin
>>> Andre Pareis wrote:
>>>> Hi Martin,
>>>> code...
>>>> Regards
>>>> Andre
The Netherlands
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #600807 is a reply to message #66278] |
Hi Martin,
Andre
Martin Taal wrote:
> Hi Andre,
> out.
> gr. Martin
> Andre Pareis wrote:
>> Hi Martin,
>> of type:
>> type:
>> of type:
>> type:
>> of type:
>> type:
>> of type:
>> type:
>> of type:
>> type:
>> of type:
>> type:
>> line: 176
>> if (isLoaded())
>> return;
>> Thanks
>> Andre
>> Andre Pareis wrote:
>>> Hi Martin,
>>> saw often.
>>> Thanks
>>> Andre
>>> Martin Taal wrote:
>>>> Hi Andre,
>>>> gr. Martin
>>>> Andre Pareis wrote:
>>>>> Hi Martin,
>>>>> code...
>>>>> Regards
>>>>> Andre
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #600810 is a reply to message #66796] |
Hi Andre,
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> Andre
> Martin Taal wrote:
>> Hi Andre,
>> that out.
>> gr. Martin
>> Andre Pareis wrote:
>>> Hi Martin,
>>> of type:
>>> type:
>>> of type:
>>> type:
>>> of type:
>>> type:
>>> of type:
>>> type:
>>> of type:
>>> type:
>>> of type:
>>> type:
>>> line: 176
>>> call here:
>>> if (isLoaded())
>>> return;
>>> Thanks
>>> Andre
>>> Andre Pareis wrote:
>>>> Hi Martin,
>>>> saw often.
>>>> Thanks
>>>> Andre
>>>> Martin Taal wrote:
>>>>> Hi Andre,
>>>>> gr. Martin
>>>>> Andre Pareis wrote:
>>>>>> Hi Martin,
>>>>>> code...
>>>>>> Regards
>>>>>> Andre
The Netherlands
Re: teneo - performance problem with new impl of HibernatePersistableEList.isLoaded() [message #600833 is a reply to message #66811] |
gr. Martin
Martin Taal wrote:
> Hi Andre,
> gr. Martin
> Andre Pareis wrote:
>> Hi Martin,
>> Andre
>> Martin Taal wrote:
>>> Hi Andre,
>>> that out.
>>> gr. Martin
>>> Andre Pareis wrote:
>>>> Hi Martin,
>>>> of type:
>>>> type:
>>>> of type:
>>>> type:
>>>> of type:
>>>> type:
>>>> of type:
>>>> type:
>>>> of type:
>>>> type:
>>>> of type:
>>>> type:
>>>> line: 176
>>>> call here:
>>>> if (isLoaded())
>>>> return;
>>>> Thanks
>>>> Andre
>>>> Andre Pareis wrote:
>>>>> Hi Martin,
>>>>> saw often.
>>>>> Thanks
>>>>> Andre
>>>>> Martin Taal wrote:
>>>>>> Hi Andre,
>>>>>> gr. Martin
>>>>>> Andre Pareis wrote:
>>>>>>> Hi Martin,
>>>>>>> my code...
>>>>>>> Regards
>>>>>>> Andre
The Netherlands
Current Time: Sun Jul 27 07:11:08 EDT 2025
Powered by FUDForum. Page generated in 0.06745 seconds
