Re: How To modify Eclipselink JPA 2.0 connection retry behaviour . [message #659414 is a reply to message #659409] |
Sun, 13 March 2011 18:03 |
Ed Merks Messages: 33218 Registered: July 2009 |
I'd suggest asking on the eclipse.rt.eclipselink newsgroup/forum.
mjawath wrote:
> EntityManager entityManager =
> Persistence.createEntityManagerFactory("mydb").createEntityManager();
> Database connection is connected
> private void cButton1ActionPerformed(java.awt.event.ActionEvent evt) {
> entityManager.createQuery(".....").getResultList();
> if Database connection is disconnected at this point.
> private void cButton2ActionPerformed(java.awt.event.ActionEvent evt) {
> Eclipselink automatically tries to reconnect it self to database
> whenever it detects a connection failure this causes swing ui to
> freeze without any responses until it connects to database .
> Are there any solution to modify this behavior
> Ie is it possible to throw exception when connection fails without
> retrying
> Please help on this issue
> I am facing with huge problem.
> I went throe eclipselink source code and google but I could not find
> any solution.
> Statck trace:
> [EL Info]: 2011-03-12 16:30:56.5--UnitOfWork(6658066)--Communication
> failure detected when attempting to perform read query outside of a
> transaction. Attempting to retry query.
> [EL Severe]: 2011-03-12 16:31:00.468--ServerSession(17922592)--Local
> Exception Stack:
> Exception [EclipseLink-4002] (Eclipse Persistence Services -
> 2.0.0.v20091127-r5931):
> org.eclipse.persistence.exceptions.DatabaseException
> Internal Exception:
> com.mysql.jdbc.exceptions.jdbc4.CommunicationsException:
> Communications link failure
> Last packet sent to the server was 0 ms ago.
> Error Code: 0
> at
> org.eclipse.persistence.exceptions.DatabaseException.sqlExce
> ption(DatabaseException.java:324)
> at
> ption(DatabaseException.java:319)
> at
> org.eclipse.persistence.sessions.DefaultConnector.connect(De
> faultConnector.java:138)
> at
> org.eclipse.persistence.sessions.DatasourceLogin.connectToDa
> tasource(DatasourceLogin.java:162)
> at
> org.eclipse.persistence.internal.databaseaccess.DatasourceAc
> cessor.connectInternal(DatasourceAccessor.java:327)
> at
> org.eclipse.persistence.internal.databaseaccess.DatabaseAcce
> ssor.connectInternal(DatabaseAccessor.java:294)
> at
> cessor.connect(DatasourceAccessor.java:415)
> at
> org.eclipse.persistence.sessions.server.ConnectionPool.build
> Connection(ConnectionPool.java:155)
> at
> org.eclipse.persistence.sessions.server.ConnectionPool.acqui
> reConnection(ConnectionPool.java:97)
> at
> org.eclipse.persistence.sessions.server.ServerSession.alloca
> teReadConnection(ServerSession.java:477)
> at
> org.eclipse.persistence.sessions.server.ServerSession.execut
> eCall(ServerSession.java:525)
> at
> org.eclipse.persistence.internal.queries.DatasourceCallQuery
> Mechanism.executeCall(DatasourceCallQueryMechanism.java:205)
> at
> Mechanism.executeCall(DatasourceCallQueryMechanism.java:191)
> at
> Mechanism.executeSelectCall(DatasourceCallQueryMechanism.jav a:262)
> at
> Mechanism.selectAllRows(DatasourceCallQueryMechanism.java:61 8)
> at
> org.eclipse.persistence.internal.queries.ExpressionQueryMech
> anism.selectAllRowsFromTable(ExpressionQueryMechanism.java:2 537)
> at
> anism.selectAllRows(ExpressionQueryMechanism.java:2496)
> at
> org.eclipse.persistence.queries.ReadAllQuery.executeObjectLe
> velReadQuery(ReadAllQuery.java:455)
> at
> org.eclipse.persistence.queries.ObjectLevelReadQuery.execute
> DatabaseQuery(ObjectLevelReadQuery.java:997)
> at
> org.eclipse.persistence.queries.DatabaseQuery.execute(Databa
> seQuery.java:675)
> at
> (ObjectLevelReadQuery.java:958)
> at
> org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAll
> Query.java:432)
> at
> InUnitOfWork(ObjectLevelReadQuery.java:1021)
> at
> org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.int
> ernalExecuteQuery(UnitOfWorkImpl.java:2863)
> at
> org.eclipse.persistence.internal.sessions.AbstractSession.ex
> ecuteQuery(AbstractSession.java:1225)
> at
> ecuteQuery(AbstractSession.java:1299)
> at
> ecuteQuery(AbstractSession.java:1207)
> at
> ecuteQuery(AbstractSession.java:1181)
> at
> org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeRea
> dQuery(EJBQueryImpl.java:453)
> at
> org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultL
> ist(EJBQueryImpl.java:669)
> at
> org.raheemiya.entity.dao.GenericDAO.ExecuteQuery(GenericDAO. java:216)
> at org.raheemiya.entity.dao.BillDAO.getNotPayed(BillDAO.java:37 )
> at
> org.business.rhotel.ui.hotel.CashierUI.testTimeElapse(Cashie
> rUI.java:227)
> at
> org.business.rhotel.ui.hotel.CashierUI$4$1.doInBackground(Ca
> shierUI.java:137)
> at javax.swing.SwingWorker$1.call(SwingWorker.java:278)
> at
> java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.jav a:303)
> at java.util.concurrent.FutureTask.run(FutureTask.java:138)
> at javax.swing.SwingWorker.run(SwingWorker.java:317)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa
> dPoolExecutor.java:886)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo
> lExecutor.java:908)
> at java.lang.Thread.run(Thread.java:619)
> Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException:
> at
> sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
> at
> sun.reflect.NativeConstructorAccessorImpl.newInstance(Native
> ConstructorAccessorImpl.java:39)
> at
> sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De
> legatingConstructorAccessorImpl.java:27)
> at
> java.lang.reflect.Constructor.newInstance(Constructor.java:5 13)
> at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
> at
> com.mysql.jdbc.SQLError.createCommunicationsException(SQLErr
> or.java:1074)
> at
> com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.jav a:2103)
> at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:718)
> at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:46)
> at
> at
> at
> at
> at
> com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.jav a:302)
> at
> com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDr
> iver.java:282)
> at java.sql.DriverManager.getConnection(DriverManager.java:582)
> at java.sql.DriverManager.getConnection(DriverManager.java:154)
> at
> faultConnector.java:98)
> ... 38 more
> Caused by: java.net.ConnectException: Connection refused: connect
> at java.net.PlainSocketImpl.socketConnect(Native Method)
> at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
> at
> java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.ja va:195)
> at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
> at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
> at java.net.Socket.connect(Socket.java:519)
> at java.net.Socket.connect(Socket.java:469)
> at java.net.Socket.<init>(Socket.java:366)
> at java.net.Socket.<init>(Socket.java:209)
> at
> com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketF
> actory.java:253)
> at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:280)
> at
> com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.jav a:2026)
> ... 50 more
Ed Merks
FUDForum. Page generated in 0.07372 seconds
