Home » Language IDEs » AspectJ » Product Export problem
Product Export problem [message #66074] Tue, 04 July 2006 03:28 Go to next message
Originally posted by: schulzs.informatik.uni-tuebingen.de
when I try to export my AspectJ enabled product via File > Export > ...,
pressing the Finish-Button does nothing (even the dialog doesn't
disappear). The error log says 'unhandled event loop exception' with no
stack trace available. This smells like an AJDT bug, doesn't it?
Any suggestions?
Sven Schulz
Re: Product Export problem [message #66098 is a reply to message #66074] Wed, 05 July 2006 04:23 Go to previous message
Originally posted by: hawkinsh.uk.ibm.com
Can you provide more information about the version of Eclipse and AJDT you
are using? In AJDT 1.4 for Eclipse 3.2 there is an aspectj version of
export product called "Eclipse product with AspectJ support". If your
product is AspectJ enabled this is the option you need to use. If this
isn't working for you can you raise a bug (https://bugs.eclipse.org/bugs/)
against AJDT and we'll investigate it.
Thanks, Helen
Re: Product Export problem [message #594302 is a reply to message #66074] Wed, 05 July 2006 04:23 Go to previous message
Thanks, Helen
Previous Topic:Product Export problem
Next Topic:compiler error
Current Time: Sat Jul 26 00:04:38 EDT 2025
Powered by FUDForum. Page generated in 0.03531 seconds
