Home » Modeling » OCL » Re: Install EMF SDK 2.5.0M4
Re: Install EMF SDK 2.5.0M4 [message #66049] Mon, 26 January 2009 01:10 Go to next message
Originally posted by: nickboldt.gmail.com
team.ui is part of the SDK: it's in the CVS feature iirc.
If you have Eclipse SDK 3.5.0M4, you should have that. If EMF or OCL are
declaring a dependency on Eclipse 3.4, however, there may be a problem.
Ed or Christian, thoughts?
Rasha wrote:
> I�m trying to install EMF SDK 2.5.0M4 and MDT OCL SDK 1.3.0M4 in Eclipse
> SDK 3.5.0, but I got this error
> Cannot find a solution satisfying the following requirements
> org.eclipse.team.ui [3.4.100.I20081202].
> However, I could install EMF SDK 2.4.2 M20090121130.
> Where I could find org.eclipse.team.ui
> Thanks in advance,
> Rasha
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: Install EMF SDK 2.5.0M4 [message #66070 is a reply to message #66049] Mon, 26 January 2009 08:16 Go to previous message
Originally posted by: cdamus.zeligsoft.com
Hi, Nick, Rasha,
MDT OCL does not require the Team plug-ins for anything, but does
require EMF 2.5, which in turn requires Eclipse Platform 3.5 (though
also not the Team plug-ins).
This oe.team.ui plug-in looks like a 3.5 version given the 100 in the
service segment, but I don't see how EMF or OCL would be the cause.
Christian
>> Eclipse SDK 3.5.0, but I got this error
>> Thanks in advance,
>> Rasha
Previous Topic:[Announce] MDT OCL 1.3.0 I200901231238 is available
Next Topic:[Announce] MDT OCL 1.3.0 I200901271329 is available
Current Time: Mon Jul 21 21:01:09 EDT 2025
Powered by FUDForum. Page generated in 0.03138 seconds
