Home » Eclipse Projects » Plugin Development Environment (PDE) » product export fails - no .exe created
product export fails - no .exe created [message #66040] Mon, 29 June 2009 01:55 Go to next message
I have defined a new product which uses "org.eclipse.ui.ide.workbench" as
its target application. When the product is exported, there will be no
exe generated (windows).
The export only fails when the product is based on features. When setting
to "product is based on plugins" and selecting all (my) plugins, the
export will succeed.
Using:
Version: 3.5.0.v20090123-7Z7_F8NFE-z0VXhWiu-8Qb95
Build id: I20090611-1540
Re: product export fails - no .exe created [message #66161 is a reply to message #66040] Mon, 29 June 2009 13:51 Go to previous message
> as its target application. When the product is exported, there will be
> no exe generated (windows).
> setting to "product is based on plugins" and selecting all (my) plugins,
> the export will succeed.
> Using:
See this bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=281224
Workaround is to install the deltapack.
(If you are using 3.5, see this post on how to do that:
http://aniefer.blogspot.com/2009/06/using-deltapack-in-eclip se-35.html)
-Andrew
Re: product export fails - no .exe created [message #598785 is a reply to message #66040] Mon, 29 June 2009 13:51 Go to previous message
> Using:
-Andrew
Previous Topic:Conflicting required versions of o.e.core.resources after export
Next Topic:Build and deploy plugin for many eclipe versions
Current Time: Sat Jul 26 00:52:15 EDT 2025
Powered by FUDForum. Page generated in 0.03409 seconds
