One *BIG* disto? [message #658810] |
Wed, 09 March 2011 21:22 |
As an active developer, I use Subversion, the modeling tools (including papyrus), CDT, python and PHP, Mylyn and Buckminster -along with XML tools. Unfortunately, I'm now to the point that Update Manager won't work for me - lots of updates and everyone of them depends on something that conflicts with something else or I'm only allowed one version of 4 that are listed.
I know I can create multiple 'installs' of the various packages but I *REALLY* like the advantages of an integrated environment. Is there any way I can create a list of which projects can be installed together and what versions of which modules should be used?
Re: One *BIG* disto? [message #658832 is a reply to message #658824] |
Wed, 09 March 2011 23:23 |
About 6 months ago I nuked my eclipse directory and downloaded the Helios Eclipse Modeling Tools - because it was the biggest. 8:D
Then I systematically installed various and sundry projects (pydev, papyrus, etc.) as well as "other" Helios individual projects like CDT until I had a fully functional, up-to-date install.
I should have left good enough alone. After several updates (and additions of more projects) I started getting conflicts. I'd go through one item at a time and try the update. If it worked, fine. If not, I skipped it. (You can't tell me software can't be made to "rot".) %>[
I tried resolving the current conflicts item-by-item recently but new items kept appearing faster than I could keep up. Now I think the best way would be to nuke the existing install and start over (as in the first two paragraphs).
I made this post as a Hail Mary hoping there was some magic utility that would clean up my install and I had just missed it in the newsgroups. Oh well.
Re: One *BIG* disto? [message #658839 is a reply to message #658832] |
Thu, 10 March 2011 00:38 |
Ed Merks Messages: 33218 Registered: July 2009 |
Dick,
No, it's easy to get consistent stuff from Helios, because it's a repo
designed to be consistent, but when you "shop" for things beyond this,
it just gets messy... :-(
> "rot".) %>[
Ed Merks
Re: One *BIG* disto? [message #660060 is a reply to message #658839] |
Wed, 16 March 2011 17:28 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
On 3/9/11 7:38 PM, Ed Merks wrote:
> Dick,
One thing that can help is in the Install New Software window, un-check
the option "Contact all update sites during install..." That will force
Eclipse to only get things from the repository that you've selected.
Eric
>> "rot".) %>[
FUDForum. Page generated in 0.11224 seconds
