Home » Language IDEs » PHP Development Tools (PDT) » Compare with...
Compare with... [message #66033] Wed, 13 February 2008 09:04 Go to next message
Originally posted by: tatsudoshi.criion.net
Hi, I having problems using the 'Compare with...' function.
I am running eclipse pdt
Version: 3.3.1.1
Build id: M20071023-1652
and rse to connect to the files (php)
The 'Local History' works fine. The 'Each Other' is grayed out.
How do I compare to files of the same filename, but on different remote
locations?
Re: Compare with... [message #66076 is a reply to message #66033] Wed, 13 February 2008 10:53 Go to previous messageGo to next message
Is it only PHP files that you find the compare with each other is grayed out or does it happen for
any file. This could be an issue with RSE rather than PDT.
Dave Kelsey
> Version: 3.3.1.1
> locations?
Re: Compare with... [message #66096 is a reply to message #66033] Wed, 13 February 2008 10:54 Go to previous messageGo to next message
> locations?
Can't you ctrl-click the files successively and then right-click ->
Compare with ... -> Each other? Or do the files appear in different views?
Re: Compare with... [message #66140 is a reply to message #66096] Thu, 14 February 2008 03:35 Go to previous messageGo to next message
Ahh yes this worked! So simple yet so elusive ;-)
I was trying to open the two files and expecting 'Each Other' to light
up then or something 'to happen' hehe.
Thanks for the help guys
Re: Compare with... [message #66159 is a reply to message #66033] Thu, 14 February 2008 03:46 Go to previous messageGo to next message
A little side question:
It opens up in 'Default Compare Editor' in 'Text Compare'.
Is it possible to set it to use PHP highlighting?
Re: Compare with... [message #66769 is a reply to message #66159] Mon, 25 February 2008 19:03 Go to previous messageGo to next message
This is a bug in PDT 1.0.2 afaik, I think the relevant bug report is:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=203529
You can probably manually apply the patch yourself if you can open/edit
jar files, as the change is only in the plugin.xml file. Or use a nightly
build.
Re: Compare with... [message #66792 is a reply to message #66769] Tue, 26 February 2008 07:51 Go to previous messageGo to next message
Ah thanks mate
Re: Compare with... [message #66805 is a reply to message #66769] Tue, 26 February 2008 08:16 Go to previous messageGo to next message
Can I just take the <org.eclipse.php.ui_>.jar and replace the one in pdt
1.0.2 R or should I use the entire nightly?
Re: Compare with... [message #66858 is a reply to message #66805] Tue, 26 February 2008 09:21 Go to previous messageGo to next message
Apparently the 1.0.2 nightly build is taken from the HEAD branch which is actually the 1.1 (1.5)
nightly build, so I would suggest you don't take any part of the nightly build as this is targeted
at the eclipse 3.4 level.
Dave Kelsey
Re: Compare with... [message #66874 is a reply to message #66858] Wed, 27 February 2008 06:05 Go to previous message
Yea I tried but PDT wouldn't start with it.
I'll just wait for the release. It's not a real problem per say...
Thanks for the help everyone
Previous Topic:debug entire site
Next Topic:More than one client host for xdebugger and problem with zend debugger
Current Time: Mon Jul 21 21:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.31587 seconds
