Home » Archived » M2M (model-to-model transformation) » [ATL] Standalone ATL transformation of UML2
[ATL] Standalone ATL transformation of UML2 [message #66032] Wed, 14 November 2007 06:03 Go to next message
I've been trying to implement a simple java launcher for ATL
transforming UML2 model files. But I fail already when I try to load the
metamodel for the UML2 models.
Using the following code fails naturally with a FileNotFoundException:
ASMModel uml2MetaModel = ((AtlEMFModelHandler)AtlModelHandler.
getDefault(AtlModelHandler.AMH_EMF)).loadModel("uml",
AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF).getMof() ,
"http://www.eclipse.org/uml2/2.1.0/UML");
In the Eclipse Plugin I use the options:
Metamodel: uml: uri:http://www.eclipse.org/uml2/2.1.0/UML
Model Handler: EMF
What do I have to use as URI or is my beginning completly wrong? It
would be nice if someone could help me getting startet or has already
implemented a standalone UML2 transformation and could show me some
example code.
Best regards
Sebastian
Re: [ATL] Standalone ATL transformation of UML2 [message #66053 is a reply to message #66032] Wed, 14 November 2007 06:31 Go to previous messageGo to next message
--------------050004020903020701090007
The path you give to the loadModel function must have an url form, so
you must use :
"uri:http://www.eclipse.org/uml2/2.1.0/UML"
instead of
And then it should work.
William
bfeater a
Re: [ATL] Standalone ATL transformation of UML2 [message #66095 is a reply to message #66053] Wed, 14 November 2007 09:06 Go to previous message
> Hello,
> you must use :
> instead of
thanks, now the transformation works.
> William
> bfeater a écrit :
>> the metamodel for the UML2 models.
>> Model Handler: EMF
>> example code.
>> Best regards
>> Sebastian
Previous Topic:[Announce] The EclipseCon 2008 Submission Deadline is Rapidly Approaching.
Next Topic:[ATL][UML] Problem with UML transformation
Current Time: Sat Jul 26 10:00:36 EDT 2025
Powered by FUDForum. Page generated in 0.05485 seconds
