Home » Eclipse Projects » Equinox » setting BundleContext properties?
setting BundleContext properties? [message #66024] Wed, 03 May 2006 15:12 Go to next message
trying to configure the OBR HTTPService bundle from equinox, I'm
wondering how to set properties in Equinox so you can read them out with that
code: m_httpPort = Integer.parseInt(m_bundleContext.getProperty(
"org.osgi.service.http.port"));
/peter
Re: setting BundleContext properties? [message #66086 is a reply to message #66024] Wed, 03 May 2006 16:51 Go to previous messageGo to next message
You should be able to set them in your config.ini or as simple Java
system properties.
Re: setting BundleContext properties? [message #66107 is a reply to message #66024] Wed, 03 May 2006 16:51 Go to previous message
You should be able to set them in your config.ini or as simple java
system properties.
Tom.
Previous Topic:OSGI settings missing ....
Next Topic:The RSP bundle must be singleton?
Current Time: Mon Jul 21 21:50:11 EDT 2025
Powered by FUDForum. Page generated in 0.11685 seconds
