Re: Starting Eclipse [message #657793 is a reply to message #657777] |
Fri, 04 March 2011 05:20 |
On 2011.03.03 18:12, 89@charter.net wrote:
> I read the Wiki, I followed all the instructions to no avail.
> I installed eclipse and each time I try to get it to start I get error :
> exit code=13
> which I understand it to mean that eclipse can't find the VM.
> I specified the path in the eclipse.ini
> Nothing seem to work.
> Un-installed, re-installed now eclipse.ini wouldn't save any changes I
> make to it.
> I am using OS Windows 7 64 bit
> Any help is greatly appreciated.
> Thank you
I can offer this...
http://www.javahotchocolate.com/tutorials/eclipse-summary.ht ml
Re: Starting Eclipse [message #657956 is a reply to message #657777] |
Fri, 04 March 2011 17:55 |
Originally posted by: coolsnoopy.gmx.net
Am 04.03.2011 02:12, schrieb 89@charter.net:
> exit code=13
> make to it.
> Thank you
so post your eclipse.ini and one might help you.
Did you read http://wiki.eclipse.org/Eclipse.ini ? "the" wiki is a
little bit to unspecific...
Re: Starting Eclipse [message #658119 is a reply to message #657969] |
Sun, 06 March 2011 17:40 |
No real name Messages: 7 Registered: March 2011 |
Junior Member |
Not much luck attempting to download java jdk to a folder under eclipse.
Here is my setting:
1-OS Windows 7 64 bit
2-I have, and have had, java under "Program Files(x86)->java->jre
3-Downloaded eclipse SDK-3.6.2-win32-x86_64
4-And extracted it to "Program Files(x86)->eclipse
5-Downloaded JDK1.6.0_24 to Program Files(x86)->java-> JDK 1.6.0_24
6-Right-click eclipse (showing under file type as configuration setings) and open with notepad shows the following:
Quote: | eclipse.ini
-startup
plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_14 00.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1. 2.R36x_v20101222
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-vmargs
-Xms40m
-Xmx384m
Any attempts to write anything to this file and save gives a message: "Save failed"
Any ideas?
Thank you
[Updated on: Sun, 06 March 2011 18:03] Report message to a moderator
Re: Starting Eclipse [message #659551 is a reply to message #658121] |
Mon, 14 March 2011 14:20 |
> Here is my setting:
> Quote:
>> eclipse.ini
>> -startup plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_14
>> 00.jar
>> --launcher.library
>> 2.R36x_v20101222
>> -showsplash
>> 256m
>> openFile
>> -vmargs
>> -Xms40m
>> -Xmx384m
> "Save failed"
> Any ideas?
> Thank you
You don't have administrative rights to the folder where you're trying
to save eclipse.ini. Make things simple: don't install Eclipse under
Program Files. Go back and read the link I gave you and follow my
advice. Later, after you're more familiar with how all of this works,
you can begin to ignore it and finesse your installation.
Re: Starting Eclipse [message #660075 is a reply to message #660068] |
Wed, 16 March 2011 18:02 |
Junior Member |
Perhaps...
With too many trials & error, I might have ended up with the 32 file.
Just checked my downloads and I see that I have:
jdk-6u24-windows-i586
Hate to go back and redo the whole thing..unless there is definite advantage to the 64.
The main reason I downloaded eclipse is to use it with GWT, but at this point.. I am even able to add GWT.. some files are missing.
Thanks again.
[Updated on: Wed, 16 March 2011 18:03] Report message to a moderator
FUDForum. Page generated in 0.08627 seconds
