Separate Eclipse and Plugins Installation Issue [message #65941] |
Wed, 18 May 2005 13:24  |
Originally posted by: adalbert.perbandt.infineon.com
Hi there,
I'm fiddling 'round with a somewhat complex eclipse (3.1M7) installation
and would like to get some advice to do it right. The situation is as
follows:
Eclipse will be used for several purposes in my environment. Some people
use the EPIC plugin for doing Perl development. Others want to use the CDT
plugin for their C/C++ development. Some will work with the ClearCase
config management system by IBM Rational) and -- last but not least --
some developers will do Java development with Eclipse.
1. issue: I learned that it is possible to setup eclipse in a way that one
only installs the platform in one place and install the plugins, each
separate from the others, in a different place. Then the eclipse users
would configure "their" eclipse according to their needs, e.g. the C++
developers would define an extension point for the C++ plugin, the Java
folks would extend their eclipse with a JDT extension point, etc.
The installation directory structure for this scenario looks like this:
Eclipse Platform Installation:
/opt/eclipse_3.1/eclipse-platform-3.1M7-solaris-motif/eclips e
Plugins Installation:
/opt/eclipse-plugins/CDT/eclipse
/JDT/eclipse
/ccase/eclipse
All the "eclipse" directories of the installed plugins contain a file
".eclipseextension" which makes the respective directory usable as an
extension point.
The question here is: Does it really make sense to split off an eclipse
installation that way? Some colleagues meant this would make eclipse start
significantly faster. Is this true?
2. I'd prefer to have an eclipse installation with all needed plugins
available when eclipse is started (without any per user configuration of
extension points necessary). But still I'd like to have the plugins
installed in the way shown above, to be able to add new ones or perform
updates for plugins without the update manager by simply replacing the
contents of a plugin's "eclipse" directory. I learned that one can create
a directory "links" inside the "eclipse" directory inside the base eclipse
installation and put a file .link into it which contains a statement like
this:
path=/opt/eclipse-plugins
Then all plugins would have to be installed together in a directory
"/opt/eclipse-plugins/eclipse". Would it be possible to have for each
plugin a separate "eclipse" directory, as shown in the plugin installation
directory given for issue 1?
Thanks in advance for any helpful hint
Adalbert Perbandt
Re: Separate Eclipse and Plugins Installation Issue [message #65971 is a reply to message #65941] |
Wed, 18 May 2005 14:52   |
Originally posted by: tominospam-eclipse.yahoo.com
Hi Adalbert
I believe it makes sense to split the plugins form the eclipse installation.
The developers can install the plugins with the update manager of
Eclipse. To do this go to "Help > Software Updates > Find and
Install..." a dialog will appear and you choose "Search for new features
to install". You'll get a new dialog and there you choose "New local
site...". Point to the plugin, for example CDT and install it.
To disable or uninstall a plugin, use "Help > Software Updates > Manage
Configuration..."
Actually it's not correct to talk about plugins, since these are
features we're talking about. As far as I know, you can only install and
manage features the way I described.
Hope this will help.
Tomi
Adalbert Perbandt wrote:
> Hi there,
> follows:
> CDT plugin for their C/C++ development. Some will work with the
> ClearCase config management system by IBM Rational) and -- last but not
> least -- some developers will do Java development with Eclipse.
> one only installs the platform in one place and install the plugins,
> each separate from the others, in a different place. Then the eclipse
> users would configure "their" eclipse according to their needs, e.g. the
> C++ developers would define an extension point for the C++ plugin, the
> Java folks would extend their eclipse with a JDT extension point, etc.
> /JDT/eclipse
> /ccase/eclipse
> extension point.
> start significantly faster. Is this true?
> create a directory "links" inside the "eclipse" directory inside the
> base eclipse installation and put a file .link into it which contains a
> statement like this:
> installation directory given for issue 1?
> Regards
> Adalbert Perbandt
SOLVED PARTLY: Re: Separate Eclipse and Plugins Installation Issue [message #67053 is a reply to message #65941] |
Fri, 20 May 2005 09:39  |
Hi there,
I found a nice solution for the 2nd part of the problem.
> The installation directory structure looks like this:
> /JDT/eclipse
> /ccase/eclipse
In the directory
/opt/eclipse_3.1/eclipse-platform-3.1M7-solaris-motif/eclips e/links
I created not just one but a couple of files named
link.CDT
link.JDT
link.ccase
with this one liner inside:
path=/opt/eclipse-plugins/CDT
(example for the CDT plugin).
The result of this setup is that the eclipse installation obviously treats
the specification inside the ".link.something" file as the definition of
an extension point. This way I have each plugin/feature installed
separately from the others and can freely modify/add/remove each single
plugin/feature.
I hope that this trick is not working based on some undocumented side
effects.
Any comments on this are welcome.
Adalbert Perbandt.
FUDForum. Page generated in 0.08320 seconds
