Home » Archived » M2M (model-to-model transformation) » [ATL] Problem with uml2copy.atl
[ATL] Problem with uml2copy.atl [message #65912] Fri, 09 November 2007 10:55 Go to next message
Originally posted by: arnaud.giuliani.c-s.fr
i 've installed atl from cvs (taken plugin part) with eclipse 3.3 europa.
I couldn't use maven to build it because of my proxy ... and i built it
directly in eclipse.
And I've taken uml2copy.atl to see superimposition feature (wiki). it
couldn't compile : mismatched input ':' expecting RPAREN for almost all
the lines of the file.
What is my problem ? Why can't i compile this file ?
What is this '::' notation in this file ?
Arnaud GIULIANI.
Re: [ATL] Problem with uml2copy.atl [message #65934 is a reply to message #65912] Fri, 09 November 2007 11:51 Go to previous messageGo to next message
Hi Arnaud,
This thread may help you:
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg01354.html
Arnaud GIULIANI wrote:
> Hello,
> europa. I couldn't use maven to build it because of my proxy ... and i
> built it directly in eclipse.
> Arnaud GIULIANI.
Éric Vépa
SODIUS
6, rue de la Cornouaille - BP 91941
44319 Nantes, France
Email: evepa@sodius.com
www.mdworkbench.com
Draw more value from your models
Re: [ATL] Problem with uml2copy.atl [message #65953 is a reply to message #65934] Sun, 11 November 2007 05:25 Go to previous messageGo to next message
Thanks for the pointer: I had already updated UML2Copy.atl for this
issue, but the wiki page used fixed revision numbers :-/.
I updated the links on the wiki page, so they point to the latest
version of UML2Copy.atl, etc.
The issue itself is described here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196433
Dennis
Éric Vépa schreef:
> Hi Arnaud,
>> Hello,
>> all the lines of the file.
>> Arnaud GIULIANI.
Re: [ATL] Problem with uml2copy.atl [message #65968 is a reply to message #65953] Mon, 12 November 2007 04:49 Go to previous messageGo to next message
Originally posted by: tristan.faure.c-s.fr
thank you for your answers and for the modified version of UML2copy
But what is the purpose of the notation "::" ???
Re: [ATL] Problem with uml2copy.atl [message #66248 is a reply to message #65968] Thu, 15 November 2007 06:42 Go to previous messageGo to next message
The "::" is used as a namespace delimiter in MOF and UML. It separates
package names and class names, for example. In "uml::Class", "uml"
refers to the EPackage and "Class" refers to the EClass.
Dennis
Re: [ATL] Problem with uml2copy.atl [message #66355 is a reply to message #66248] Fri, 16 November 2007 09:51 Go to previous message
thank you all for your answers.
Atl transformations are running !
Previous Topic:resolving links to input model
Next Topic:[ATL] Raising transformation errors and "auxiliary" parameters
Current Time: Tue Jul 08 06:14:41 EDT 2025
Powered by FUDForum. Page generated in 2.25431 seconds
