Home » Language IDEs » PHP Development Tools (PDT) » Eclipse PDT 1.0.2 is freezing randomly on big file
Eclipse PDT 1.0.2 is freezing randomly on big file [message #65902] Wed, 13 February 2008 05:13 Go to next message
The last version of PDT, is freezing randomly when editing big files.
The syntax coloration become black (somme line are normal other black)
The CPU usage raise to 100% and nothing append, even if I let it run 2
hours nothing append.
I've tried zend studio for eclipse, and the problem is the same.
Really too bad for a stable version which is for me the perfect IDE of
the momment.
My configuration :
*** Date: mercredi 13 février 2008 11 h 09 HNEC
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
birt.viewer.working.path=C:\Documents and Settings\vincent
vermersch\Bureau\Zend\workspaces\DefaultWorkspace\.metadata\ .plugins\org.eclipse.birt.report.viewer
derby.system.home=C:\neon1\configuration
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\neon1\ZendStudio.exe
-name
ZendStudio
--launcher.library
C:\neon1\plugins\org.eclipse.equinox.launcher.win32.win32.x8 6_1.0.2.R331_v20071019\eclipse_1021.dll
-startup
C:\neon1\plugins\com.zend.php.startup_1.0.0.jar
-vm
C:\neon1\jre\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=com.zend.php.product
eclipse.startTime=1202897169484
eclipse.vm=C:\neon1\jre\bin\client\jvm.dll
eclipse.vmargs=-Xms128M
-Xmx512M
-XX:MaxPermSize=256m
-Djava.class.path=C:\neon1\plugins\com.zend.php.startup_1.0. 0.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\neon1\plugins\com.zend.php.startup_1.0.0. jar
java.class.version=49.0
java.endorsed.dirs=C:\neon1\jre\lib\endorsed
java.ext.dirs=C:\neon1\jre\lib\ext
java.home=C:\neon1\jre
java.io.tmpdir=C:\DOCUME~1\VINCEN~1\LOCALS~1\Temp\
java.library.path=C:\neon1;.;C:\WINDOWS\system32;C:\WINDOWS; c:\ruby\bin;C:\wamp\perl\bin\;C:\WINDOWS\system32;C:\WINDOWS ;C:\WINDOWS\System32\Wbem;C:\Program
Files\-Linux\SecureCRT;C:\Program
Files\GanttProject\gantt2mmt;C:\wamp\php;C:\wamp\perl\bin;C: \Program
Files\GanttProject;C:\PROGRA~1\ATT\Graphviz\bin;;C:\Program
Files\Subversion\bin;C:\PROGRA~1\SecureFX;C:\WINDOWS\system3 2\WindowsPowerShell\v1.0;C:\Program
Files\OpenSSH\bin;C:\Program Files\QuickTime\QTSystem\;C:\Program
Files\Java\bin;C:\PROGRA~1\Stardock\OBJECT~2\OBJECT~2\
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_08-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_08
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_08-b03
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.defaultlog=off
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.handle=393442
org.eclipse.equinox.launcher.splash.location=c:\neon1\plugin s\com.zend.php_6.0.0.v20080107\splash.bmp
org.eclipse.mylyn.context.core.context.active=true
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=fr
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,java
x.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text.html,java x.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tr ee,javax.swing.undo,javax.transaction,javax.transaction.xa,j avax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pa rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax,javax.xml.transform.stream,javax.xml.validatio n,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_ 2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,o rg.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA .TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingC ontextExtPackage,org.omg.CosNaming.NamingContextPackage,org. omg.Dynamic,org.omg.DynamicAny
,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny. DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,or g.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInt erceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org. omg.PortableServer,org.omg.PortableServer.CurrentPackage,org .omg.PortableServer.POAManagerPackage,org.omg.PortableServer .POAPackage,org.omg.PortableServer.portable,org.omg.Portable Server.ServantLocatorPackage,org.omg.SendingContext,org.omg. stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom. events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sa x.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\neon1\configuration\org.eclipse.osgi\bun dles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/neon1/configuration/
osgi.framework=file:/c:/neon1/plugins/org.eclipse.osgi_3.3.1 .R33x_v20070828.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.1.R33x_v20070828
osgi.install.area=file:/C:/neon1/
osgi.instance.area=file:/C:/Documents and Settings/vincent
vermersch/Bureau/Zend/workspaces/DefaultWorkspace/
osgi.instance.area.default=file:/C:/Documents and Settings/vincent
osgi.logfile=C:\Documents and Settings\vincent
vermersch\Bureau\Zend\workspaces\DefaultWorkspace\.metadata\ .log
osgi.manifest.cache=C:\neon1\configuration\org.eclipse.osgi\ manifests
osgi.nl=fr_FR
osgi.os=win32
osgi.splashLocation=c:\neon1\plugins\com.zend.php_6.0.0.v200 80107\splash.bmp
osgi.splashPath=platform:/base/plugins/com.zend.php
osgi.syspath=c:\neon1\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\neon1\jre\lib\rt.jar;C:\neon1\jre\lib \i18n.jar;C:\neon1\jre\lib\sunrsasign.jar;C:\neon1\jre\lib\j sse.jar;C:\neon1\jre\lib\jce.jar;C:\neon1\jre\lib\charsets.j ar;C:\neon1\jre\classes
sun.boot.library.path=C:\neon1\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.net.client.defaultConnectTimeout=60000
sun.net.client.defaultReadTimeout=60000
sun.os.patch.level=Service Pack 2
user.country=FR
user.dir=C:\neon1
user.home=C:\Documents and Settings\vincent vermersch\Bureau
user.language=fr
user.name=vincent vermersch
user.timezone=Europe/Paris
user.variant=
workspace.projectclasspath=
*** Features:
com.aptana.ide.feature (1.1.2.007725) "Aptana Web Development Tools"
com.aptana.ide.feature.editor.css (1.1.2.007725) "Aptana CSS Editor"
com.aptana.ide.feature.editor.html (1.1.2.007725) "Aptana HTML Editor"
com.aptana.ide.feature.editor.js (1.1.2.007725) "Aptana JavaScript Editor"
com.aptana.ide.feature.editor.php (0.2.11.007285_200801290033) "Aptana
PHP Editor"
com.aptana.ide.feature.editors (1.1.2.007725) "Aptana Unified Editor"
com.aptana.ide.feature.syncing.ftp (1.1.0.007007) "Aptana
Synchronization Core"
com.extjs.ext.1.1 (1.1.0.00006) "Aptana Support for EXT 1.1"
com.jquery.1.2 (1.2.1.00006) "Aptana Support for jQuery"
com.lowagie.itext (1.5.2.v20070608-041-w31181821) "Lowagie Itext"
com.mochikit.1.4 (1.4.0.00005) "Aptana Support for MochiKit"
com.spket.ui (1.6.6) "Spket UI"
com.yahoo.yui.2.3 (2.3.1.00001) "Aptana Support for Yahoo! User Interface"
com.zend.php (6.0.0.v20080107) "Product Plugin"
net.mootools.1.11 (1.11.1.00002) "Aptana Support for mootools"
net.sf.colorer (0.7.2) "Eclipse Colorer"
org.aflax.1.0 (1.0.0.00002) "Aptana Support for Aflax"
org.apache.commons.codec (1.3.0.v20070907-02--w311817222849) "Apache
Commons Codec Plug-in"
org.apache.derby.core (10.1.2.1) "Apache Derby Core Plug-in for Eclipse"
org.dojotoolkit.dojo.1.0 (1.0.1.00001) "Aptana Support for Dojo Toolkit"
org.eclipse.birt (2.2.1.v20070709-7M7M7A3OP2Mz-yAItil64r9z0tw0)
"Business Intelligence and Reporting Tools"
org.eclipse.birt.chart (2.2.1.v20070709-797942epMxsxifpV0fIHD8tiM6p)
"BIRT Chart Framework"
org.eclipse.birt.chart.cshelp (2.2.1.r22x_v20070913-11--w31181736) "BIRT
Chart Context-sensitive Help"
org.eclipse.birt.chart.runtime (2.2.1.v20070718-7Y8l77MVg3v_6uC7shL5o)
"BIRT Chart Runtime"
org.eclipse.birt.cshelp (2.2.1.r22x_v20070913-11--w31181733) "BIRT
org.eclipse.birt.doc (2.2.1.v20070709-110-s332Aw31181_2_) "BIRT
Documentation"
org.eclipse.birt.doc.isv (2.2.1.v20070709-110-s332Aw31181_24) "BIRT ISV
Documentation"
org.eclipse.birt.example (2.2.1.v20070709-7C7C555QQ8JZTFDqAz0Hj) "BIRT
Example"
org.eclipse.birt.report.designer
(2.2.1.v20070709-7U7U7EB8R4y3DDSVyYpv9FacpRAm) "BIRT Report Designer"
org.eclipse.birt.report.runtime (2.2.1.v20070718-7U7U7EBz0-4X-6EZboQ_la)
"BIRT Report Runtime"
org.eclipse.cvs (1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D) "Eclipse CVS
Client"
org.eclipse.datatools.connectivity.feature (1.5.1.200709261) "Data Tools
Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.5.1.200709261) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.5.1.200709261) "DTP
Open Data Access"
org.eclipse.datatools.doc.user (1.5.1.200710161) "Data Tools Platform
User Guide"
org.eclipse.datatools.enablement.apache.derby.feature (1.5.1.200709261)
"High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.5.1.200709261) "Eclipse Data
Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.5.1.200709261)
"Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.5.1.200709261) "Eclipse
org.eclipse.datatools.enablement.jdbc.feature (1.5.1.200709261)
org.eclipse.datatools.enablement.msft.feature (1.5.1.200709261) "Eclipse
org.eclipse.datatools.enablement.mysql.feature (1.5.1.200709261)
org.eclipse.datatools.enablement.oda.designer.feature (1.5.1.200709261)
"Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.5.1.200709261) "Eclipse
Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.5.1.200709261)
org.eclipse.datatools.enablement.postgresql.feature (1.5.1.200709261)
org.eclipse.datatools.enablement.sybase.feature (1.5.1.200709261)
org.eclipse.datatools.modelbase.feature (1.5.1.200709261) "Eclipse Data
Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.5.1.200709261) "Eclipse
Data Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.eclipsemonkey (1.1.0.007007) "Aptana Scripting"
org.eclipse.emf (2.3.1.v200709252135) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.1.v200709252135) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.1.v200709252135) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200709252135) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.3.0.v200709252135) "EMF Template Code
Generator UI"
org.eclipse.emf.common (2.3.0.v200709252135) "EMF Common"
org.eclipse.emf.common.ui (2.3.1.v200709252135) "EMF Common UI"
org.eclipse.emf.converter (2.3.1.v200709252135) "EMF Model Convert Support"
org.eclipse.emf.ecore (2.3.1.v200709252135) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.0.v200709252135) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.1.v200709252135) "Sample Ecore Editor"
org.eclipse.emf.ecore.sdo (2.3.0.v200709252135) "EMF Service Data
Objects (SDO)"
org.eclipse.emf.edit (2.3.1.v200709252135) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.1.v200709252135) "EMF Edit UI"
org.eclipse.emf.mapping (2.3.0.v200709252135) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.0.v200709252135) "Eclipse Modeling
Framework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200709252135) "Eclipse
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.0.v200709252135) "EMF Mapping UI"
org.eclipse.gef (3.3.1.v20070814) "Graphical Editing Framework"
org.eclipse.jdt (3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL)
"Eclipse Java Development Tools"
org.eclipse.mylyn_feature (2.3.0.I20080206-2200) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (2.3.0.I20080206-2200) "Mylyn"
org.eclipse.mylyn.context_feature (2.3.0.I20080206-2200) "Mylyn"
org.eclipse.mylyn.ide_feature (2.3.0.I20080206-2200) "Mylyn"
org.eclipse.mylyn.java_feature (2.3.0.I20080206-2200) "Mylyn"
org.eclipse.mylyn.pde_feature (2.3.0.I20080206-2200) "Mylyn"
org.eclipse.mylyn.trac_feature (2.3.0.I20080206-2200) "Mylyn"
org.eclipse.mylyn.web.tasks_feature (2.2.0.I20071220-1700) "Mylyn"
org.eclipse.pde (3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN) "Eclipse
Plug-in Development Environment"
org.eclipse.php_feature (1.0.2.v20080102-79-7GE7QYGHNGPGY) "PDT Plug-in"
org.eclipse.platform (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz)
"Eclipse Platform"
org.eclipse.rcp (3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS) "Eclipse
RCP"
org.eclipse.rse (2.0.2.v20071030-7D-68mJIkR9WAviqV8z0U9vz-C) "Remote
System Explorer End-User Runtime"
org.eclipse.rse.core (2.0.2.v20071030-7P-7DEB7sQRxTz0jQb) "Remote System
Explorer Core"
org.eclipse.rse.dstore (2.0.1.v20070926-7F-4DUUEF6FALu) "RSE DStore
Services"
org.eclipse.rse.ftp (2.0.1.v20070926-7737__kE77Y7dDK4I7B) "RSE FTP Service"
org.eclipse.rse.local (2.0.1.v20070705-7_-2AgI99h9l9l) "RSE Local Services"
org.eclipse.rse.ssh (2.0.1.v20070926-78-2_kE77Y7cAW) "RSE SSH Services"
org.eclipse.rse.telnet (2.0.1.v20070704-637AAgI99h9mBW4I7B) "RSE Telnet
Service"
org.eclipse.team.svn (0.7.0.v20080129) "Subversive SVN Team Provider
(Incubation)"
org.eclipse.team.svn.mylyn (0.7.0.v20080129) "Subversive Integration for
the Mylyn Project (Incubation)"
org.eclipse.team.svn.nl1 (0.7.0.v20080129) "Subversive SVN Team Provider
Localization (Incubation)"
org.eclipse.team.svn.resource.ignore.rules.jdt (0.7.0.v20080116)
"Subversive JDT Ignore Extensions (Incubation)"
org.eclipse.tm.discovery (2.0.0.v20070611-7J--E8McIJNJCPr) "Target
Management Service Discovery Engine"
org.eclipse.tm.terminal (1.0.2.v20071030-1-17w31182141) "Target
Management Terminal Widget"
org.eclipse.tm.terminal.serial (1.0.2.v20071030-1-17w31182141) "Target
Management Terminal Serial Connector"
org.eclipse.tm.terminal.view (1.0.2.v20071023-1-17w31182134) "Target
Management Terminal View"
org.eclipse.wst (2.0.1.v200709110510-7C-778k0JWNr93WEIHvplSVojWel) "Web
Standard Tools (WST)"
org.eclipse.xsd (2.3.1.v200709252135) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.edit (2.3.0.v200709252135) "XML Schema Edit Framework"
org.mozilla.rhino (1.6.0.v20070406-05--w31181821) "Rhino Javascript Plug-in"
org.openrico.rico.2.0 (2.0.0.00002) "Aptana Support for Rico"
org.polarion.eclipse.team.svn.connector (2.0.0.v20080129) "Subversive
SVN Connectors"
org.polarion.eclipse.team.svn.connector.javahl (2.0.0.v20080129)
"Subversive SVN 1.4 JavaHL Connector"
org.polarion.eclipse.team.svn.connector.javahl.win32 (2.0.0.v20080116)
"JavaHL 1.4.5 Win32 Binaries"
org.polarion.eclipse.team.svn.connector.javahl15 (2.0.0.v20080129)
"Subversive SVN 1.5 JavaHL Connector"
org.polarion.eclipse.team.svn.connector.javahl15.win32 (2.0.0.v20080129)
"JavaHL 1.5.0 Win32 Binaries"
org.polarion.eclipse.team.svn.connector.svnkit (2.0.0.v20080129)
"Subversive SVN 1.4 SVN Kit Connector"
org.polarion.eclipse.team.svn.connector.svnkit15 (2.0.0.v20080129)
"Subversive SVN 1.5 SVN Kit Connector"
org.polarion.team.svn.client.javasvn (1.1.9.02) "JavaSVN-based client
for Subversive SVN Team Provider"
org.polarion.team.svn.client.svnkit (1.1.9.02) "SVNKit-based client for
org.polarion.team.svn.mylyn (1.0.9.01) "Subversive Integration for the
Mylyn Project"
org.polarion.team.svn.resource.ignore.rules.jdt (1.0.5) "Subversive JDT
Ignore Recommendations"
org.prototypejs.prototype.1.5 (1.5.0.00003) "Aptana Support for Prototype"
org.scriptaculous.1.7 (1.7.0.00006) "Aptana Support for Scriptaculous"
org.w3c.sac (1.3.0.v20070406-02--w31181821) "W3C Sac"
*** Plug-in Registry:
AfaeEditorBlogger (0.1.0) "AfaeEditorBlogger" [Starting]
com.adobe.spry.1.5 (1.5.0.00002) "Aptana Support for Adobe Spry" [Resolved]
com.aptana.ide.branding (1.1.0.007007) "Aptana Web Development Tools"
[Resolved]
com.aptana.ide.core (1.1.2.007725) "Aptana Core" [Active]
com.aptana.ide.core.ui (1.1.2.007725) "Aptana User Interface" [Active]
com.aptana.ide.core.win32 (1.1.0.007007) "Aptana Core Win32" [Resolved]
com.aptana.ide.debug.core (1.1.0.007007) "Aptana Debugging Tools" [Active]
com.aptana.ide.debug.ui (1.1.0.007007) "Aptana Debugging Tools" [Active]
com.aptana.ide.documentation (1.1.1.007533) "Aptana Documentation"
[Starting]
com.aptana.ide.editor.css (1.1.1.007533) "Aptana CSS Editor" [Starting]
com.aptana.ide.editor.html (1.1.1.007533) "Aptana HTML Editor" [Starting]
com.aptana.ide.editor.js (1.1.1.007533) "Aptana JavaScript Editor"
[Starting]
com.aptana.ide.editor.php (0.2.11.007285_200801290033) "Aptana PHP
Editor" [Starting]
com.aptana.ide.editor.text (1.1.0.007007) "Aptana Generic Text Editor"
[Starting]
com.aptana.ide.editor.xml (1.1.1.007533) "Aptana XML Editor" [Starting]
com.aptana.ide.editors (1.1.1.007533) "Aptana Unified Editor" [Active]
com.aptana.ide.editors.codeassist (1.1.1.007533) "Aptana Unified Editor"
[Starting]
com.aptana.ide.epl (1.1.0.007007) "Aptana Eclipse Code" [Active]
com.aptana.ide.extras (1.1.0.007007) "Aptana Studio Extras" [Starting]
com.aptana.ide.framework.jaxer (1.1.2.007725) "Aptana Jaxer Development
Environment" [Starting]
com.aptana.ide.framework.jaxer.server.win32 (1.1.2.007725) "Aptana Jaxer
Server for Windows" [Starting]
com.aptana.ide.internet.proxy (1.1.0.007007) "Internet Proxy
Preferences" [Starting]
com.aptana.ide.intro (1.1.2.007725) "Aptana Intro" [Active]
com.aptana.ide.io.file (1.1.1.007533) "Aptana File System Support" [Active]
com.aptana.ide.jface.text.source (1.1.0.007007) "fragmentName" [Resolved]
com.aptana.ide.js.docgen (1.1.0.007007) "Aptana ScriptDoc Generation"
[Starting]
com.aptana.ide.lexer (1.1.0.007007) "Aptana Lexer" [Starting]
com.aptana.ide.libraries (1.1.1.003474) "Aptana Libraries" [Resolved]
com.aptana.ide.libraries.jetty (1.1.0.007007) "Aptana Jetty Libraries"
[Resolved]
com.aptana.ide.logging (1.1.0.007007) "Aptana Logging Facilities" [Starting]
com.aptana.ide.parsing (1.1.1.007533) "Aptana Parsing" [Starting]
com.aptana.ide.samples (1.1.0.007007) "Aptana Samples View" [Starting]
com.aptana.ide.scripting (1.1.0.007007) "Aptana Scripting" [Active]
com.aptana.ide.search (1.1.0.007007) "Aptana File Search" [Active]
com.aptana.ide.search.epl (1.1.2.007725) "Aptana File Search (EPL)"
[Starting]
com.aptana.ide.server (1.1.1.007533) "pluginName" [Starting]
com.aptana.ide.server.core (1.1.0.007007) "Aptana Server Core" [Starting]
com.aptana.ide.server.jetty (1.1.0.007007) "Aptana Jetty Server" [Starting]
com.aptana.ide.server.ui (1.1.0.007007) "Aptana Server User Interface"
[Active]
com.aptana.ide.snippets (1.1.0.007007) "Aptana Snippets View" [Starting]
com.aptana.ide.syncing (1.0.0.007007) "Aptana Synchronization Core" [Active]
com.aptana.ide.update (1.1.0.007007) "Aptana Updates" [Active]
com.aptana.ide.xul (1.0.0.007007) "Aptana XulRunner Browser Support"
[Starting]
com.extjs.ext.1.1 (1.1.0.00006) "Aptana Support for EXT 1.1" [Resolved]
com.extjs.ext.2.0 (1.0.0.00000) "Aptana Support for EXT 2.0" [Resolved]
com.ibm.icu (3.6.1.v20070906) "International Components for Unicode for
Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
com.jquery.1.2 (1.2.1.00006) "Aptana Support for jQuery" [Resolved]
com.lowagie.itext (1.5.2.v20070710) "Lowagie Itext" [Resolved]
com.mochikit.1.4 (1.4.0.00005) "Aptana Support for MochiKit" [Resolved]
com.rohanclan.afae (1.1.2) "Afae Plugin" [Starting]
com.rohanclan.imageviewer (0.8.7) "Image Viewer Plug-in" [Starting]
com.rohanclan.snippets (0.8.6) "Snippets Plug-in" [Starting]
com.spket.as.core (1.6.6) "Spket JavaScript Core" [Resolved]
com.spket.awt (1.6.6) "Batik AWT Extensions" [Resolved]
com.spket.core (1.6.6) "Spket Core" [Resolved]
com.spket.dtd (1.6.6) "Spket DTD" [Starting]
com.spket.grammars (1.6.6) "Spket Grammars" [Resolved]
com.spket.js (1.6.6) "Spket JavaScript Editor" [Starting]
com.spket.js.xpc (1.6.6) "Spket JavaScript Editor for Mozilla" [Starting]
com.spket.laszlo (1.6.6) "Spket Laszlo Editor" [Starting]
com.spket.mime (1.6.6) "Spket MIME Editor" [Starting]
com.spket.svg (1.6.6) "Spket SVG Editor" [Starting]
com.spket.swt (1.6.6) "Spket SWT Extension" [Resolved]
com.spket.theme (1.6.6) "Spket Theme" [Resolved]
com.spket.ui (1.6.6) "Spket UI" [Starting]
com.spket.widget (1.6.6) "Spket Widgets" [Resolved]
com.spket.widget.win32 (1.6.6) "Spket Widgets for Windows" [Resolved]
com.spket.wpfe (1.6.6) "Spket for Silverlight" [Starting]
com.spket.xml (1.6.6) "Spket XML Editor" [Starting]
com.spket.xul (1.6.6) "Spket XUL Editor" [Starting]
com.spket.ywt (1.6.6) "Yahoo! Widget Toolkit" [Starting]
com.xored.composer.sse (1.0.0.v20080107) "HyperComposer SSE Connector"
[Active]
com.xored.composer.ui (1.0.0.v20080107) "HyperComposer Richtext UI" [Active]
com.xored.scripting.core (1.0.0.v20080107) "pluginName" [Starting]
com.xored.scripting.javascript (1.6.7.v20080107) "pluginName" [Starting]
com.xored.swt.composer (2.0.3.v20071001) "HyperComposer WYSIWYG HTML
Editing Component" [Installed]
com.xored.swt.composer (2.0.3.v20080107) "HyperComposer WYSIWYG HTML
Editing Component" [Active]
com.xored.xulrunner.configuration (1.0.1) "Configuration Plug-in" [Starting]
Interface" [Resolved]
com.zend.php (6.0.0.v20080107) "Product Plugin" [Active]
com.zend.php.codeanalyzer (6.0.0.v20080107) "Codeanalyzer Plug-in" [Active]
com.zend.php.codeanalyzer.win32.x86 (6.0.0.v20080107) "Code Analyzer for
Windows x86 (Fragment)" [Resolved]
com.zend.php.codegallery (6.0.0.v20080107) "Code Gallery Plug-in" [Starting]
com.zend.php.core (6.0.0.v20080107) "Core Plug-in" [Active]
com.zend.php.datatools.core (6.0.0.v20080107) "Data Tools Core Plug-in"
[Starting]
com.zend.php.datatools.ui (6.0.0.v20080107) "Data Tools UI Plug-in"
[Starting]
com.zend.php.debug.core (6.0.0.v20080107) "Advanced Debugger Plug-in"
[Starting]
com.zend.php.debug.ui (6.0.0.v20080107) "Advanced Debugger Ui Plug-in"
[Active]
com.zend.php.formatter.core (6.0.0.v20080107) "Core Plug-in" [Active]
com.zend.php.formatter.ui (6.0.0.v20080107) "Ui Plug-in" [Starting]
com.zend.php.framework (6.0.0.v20080107) "Framework Plug-in" [Active]
com.zend.php.framework.resource (6.0.0.v20080107) "Resource Fragment"
[Resolved]
com.zend.php.help (6.0.0.v20080107) "Help Plug-in" [Starting]
com.zend.php.imports (6.0.0.v20080107) "Zend Imports Plug-in" [Active]
com.zend.php.javabridge.core (6.0.0.v20080107) "Java Bridge Core
Plug-in" [Active]
com.zend.php.javabridge.ui (6.0.0.v20080107) "Java Bridge UI Plug-in"
[Active]
com.zend.php.phpdocumentor (6.0.0.v20080107) "Phpdocumentor Plug-in"
[Starting]
com.zend.php.phpunit (6.0.0.v20080107) "PHPUnit Plug-in" [Active]
com.zend.php.platform.core (6.0.0.v20080107) "Core Plug-in" [Starting]
com.zend.php.platform.ui (6.0.0.v20080107) "Zend Platform Integration UI
Plug-in" [Starting]
com.zend.php.profile.core (6.0.0.v20080107) "Profiler Plug-in" [Starting]
com.zend.php.profile.ui (6.0.0.v20080107) "Profiler Ui Plug-in" [Starting]
com.zend.php.refactoring.core (6.0.0.v20080107) "Refactoring Plug-In"
[Active]
com.zend.php.refactoring.ui (6.0.0.v20080107) "Refactoring UI Plug-in"
[Active]
com.zend.php.rss (6.0.0.v20080107) "Rss Plug-in" [Starting]
com.zend.php.startup (1.0.0) "Startup Plug-in" [Resolved]
com.zend.php.ui (6.0.0.v20080107) "UI Plug-in" [Active]
com.zend.php.utils (6.0.0.v20080107) "PHP Utils Plug-in" [Active]
com.zend.php.wsdl.core (6.0.0.v20080107) "Wsdl Core Plug-in" [Active]
com.zend.php.wsdl.generator (6.0.0.v20080107) "Generator Plug-in" [Starting]
com.zend.php.wsdl.ui (6.0.0.v20080107) "Wsdl Ui Plug-in" [Active]
com.zend.php.wysiwyg.charmap.ui (1.0.0.v20080107) "pluginName" [Starting]
com.zend.php.wysiwyg.core (1.0.0.v20080107) "Zend WYSIWYG Editor Tools"
[Starting]
com.zend.php.wysiwyg.css.core (1.0.0.v20080107) "Zend WYSIWYG CSS Tools"
[Starting]
com.zend.php.wysiwyg.css.ui (1.0.0.v20080107) "pluginName" [Starting]
com.zend.php.wysiwyg.editor (1.0.0.v20080107) "Zend WYSIWYG Editor Core"
[Active]
com.zend.php.wysiwyg.ui (1.0.0.v20080107) "Zend WYSIWYG Editor UI" [Active]
com.zend.php.wysiwyg.ui.properties.tabbed (1.0.0.v20080107) "pluginName"
[Starting]
de.babe.eclipse.plugins.MultiClipboard (2.1.1) "MultiClipboard Plug-in"
[Active]
de.babe.eclipse.plugins.QuickREx (3.5.0) "QuickREx Plug-in" [Starting]
de.babe.eclipse.plugins.QuickREx_I18N (1.0.0) "QuickREx
Internationalization" [Resolved]
de.babe.eclipse.plugins.tinyHTMLTools (1.1.1) "tiny HTML Tools Plug-in"
[Starting]
de.babe.eclipse.plugins.XPathDeveloper (1.0.1) "XPathDeveloper Plug-in"
[Starting]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle"
[Resolved]
javax.wsdl (1.4.0.v200706111329) "WSDL4J" [Resolved]
javax.wsdl15 (1.5.1.v200705290614) "WSDL4J" [Resolved]
javax.xml.rpc (1.1.0.v200706111329) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200706111329) "SAAJ" [Resolved]
net.mootools.1.11 (1.11.0.00002) "Aptana Support for mootools" [Resolved]
net.sf.colorer (0.7.2) "Eclipse Colorer" [Starting]
org.aflax.1.0 (1.0.0.00002) "Aptana Support for Aflax" [Resolved]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v200706191647) "Apache Web Services" [Resolved]
org.apache.batik (1.7.0.v20080107) "pluginName" [Resolved]
org.apache.batik.bridge (1.6.0.v200706111724) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200706111724) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200706111724) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200706111724) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200706111724) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.extension (1.6.0.v200706111724) "Apache Batik
org.apache.batik.javascript (1.7.0.v20080107) "fragmentName" [Resolved]
org.apache.batik.parser (1.6.0.v200706111724) "Apache Batik Parser"
[Resolved]
org.apache.batik.pdf (1.6.0.v200706111329) "Bundle-Name" [Resolved]
org.apache.batik.svggen (1.6.0.v200706111724) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.swing (1.6.0.v200706111724) "Apache Batik Swing" [Resolved]
org.apache.batik.transcoder (1.6.0.v200706111724) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200706111724) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200706111724) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200706111724) "Apache Batik XML" [Resolved]
org.apache.commons.codec (1.3.0.v200706111738) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.discovery (0.2.0.v200706111329) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.net (1.4.1.v200709210925) "Apache Jakarta Commons
Net" [Resolved]
[Starting]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.log4j (1.2.13.v200706111418) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene
Analysis" [Resolved]
org.apache.oro (2.0.8.v200706111724) "Apache Jakarta ORO" [Resolved]
org.apache.wsil4j (1.0.0.v200706111329) "WSIL4J" [Resolved]
org.apache.xalan (2.7.0.v20080107) "pluginName" [Resolved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver"
[Resolved]
[Resolved]
org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.2.200.v20070825_r331) "Ant UI" [Active]
org.eclipse.atf.mozilla.ide.core (0.2.1.v200703161053) "Mozide Core
Plugin" [Starting]
org.eclipse.atf.mozilla.swt.browser (0.2.1.v200703161053) "Mozilla
Browser Fragment" [Installed]
org.eclipse.atf.mozilla.swt.browser.win32.win32.x86
(0.2.1.v200703161053) "Standard Widget Toolkit Mozilla browser support
for Windows" [Installed]
org.eclipse.birt (2.2.1.v20070710) "Business Intelligence and Reporting
Tools" [Resolved]
org.eclipse.birt.chart (2.2.1.v20070710) "BIRT Chart Framework" [Resolved]
org.eclipse.birt.chart.cshelp (2.2.0.v20070625) "BIRT Chart
Context-sensitive Help" [Starting]
org.eclipse.birt.chart.device.extension (2.2.1.r221_v20070828) "BIRT
Chart Device Extension(s)" [Starting]
org.eclipse.birt.chart.device.pdf (2.2.1.r221_v20070828) "BIRT Chart
Device PDF Extension" [Starting]
org.eclipse.birt.chart.device.svg (2.2.1.r221_v20070918) "BIRT Chart
Device SVG Extension" [Starting]
org.eclipse.birt.chart.device.swt (2.2.1.r221_v20070828) "BIRT Chart
Device SWT Extension" [Starting]
org.eclipse.birt.chart.engine (2.2.1.r221_v20070911) "BIRT Chart Engine"
[Starting]
org.eclipse.birt.chart.engine.extension (2.2.1.r221_v20070911) "BIRT
Chart Engine Extension" [Starting]
org.eclipse.birt.chart.examples (2.2.1.r221_v20070828) "BIRT Chart
Examples Plug-in" [Starting]
org.eclipse.birt.chart.reportitem (2.2.1.r221_v20070921) "BIRT
Chart-Report Integration" [Starting]
org.eclipse.birt.chart.reportitem.ui (2.2.1.r221_v20070828) "BIRT
Chart-Report UI Integration Plug-in" [Starting]
org.eclipse.birt.chart.runtime (2.2.1.v20070710) "BIRT Chart Runtime"
[Resolved]
org.eclipse.birt.chart.ui (2.2.1.r221_v20070828) "BIRT Chart Library UI
Plug-in" [Starting]
org.eclipse.birt.chart.ui.extension (2.2.1.r221_v20070913) "BIRT Chart
UI Extension" [Starting]
org.eclipse.birt.core (2.2.1.r22x_v20070924) "BIRT Core Package" [Active]
org.eclipse.birt.core.ui (2.2.1.r221_v20070828) "BIRT Core UI" [Starting]
org.eclipse.birt.cshelp (2.2.0.v20070622) "BIRT Context-sensitive Help"
[Starting]
org.eclipse.birt.data (2.2.1.r22x_v20070925) "BIRT Data Engine" [Starting]
org.eclipse.birt.doc (2.2.1.r221_v20070919) "BIRT Documentation" [Starting]
org.eclipse.birt.doc.isv (2.2.1.r221_v20070913) "BIRT ISV Documentation"
[Starting]
org.eclipse.birt.example (2.2.0.v20070531) "BIRT Example" [Resolved]
org.eclipse.birt.report.data.adapter (2.2.1.r22x_v20070919) "BIRT Data
Adapter" [Starting]
org.eclipse.birt.report.data.oda.jdbc (2.2.1.r22x_v20070919) "BIRT
ODA-JDBC Bridge Driver" [Starting]
org.eclipse.birt.report.data.oda.jdbc.ui (2.2.1.r22x_v20070919) "BIRT
JDBC UI Plug-in" [Starting]
org.eclipse.birt.report.data.oda.sampledb (2.2.1.r22x_v20070919) "BIRT
Sample Database" [Starting]
org.eclipse.birt.report.data.oda.sampledb.ui (2.2.1.r22x_v20070919)
"BIRT Sample Database UI Plug-in" [Starting]
org.eclipse.birt.report.data.oda.xml (2.2.1.r22x_v20070919) "BIRT
ODA-XML Driver" [Starting]
org.eclipse.birt.report.data.oda.xml.ui (2.2.1.r22x_v20070919) "BIRT ODA
XML Designer" [Starting]
org.eclipse.birt.report.debug.ui (2.2.1.r221_v20070831) "BIRT debug
Plug-in" [Active]
org.eclipse.birt.report.designer (2.2.1.v20070710) "BIRT Report
Designer" [Resolved]
org.eclipse.birt.report.designer.core (2.2.1.r221_v20070913) "BIRT
Designer Core" [Starting]
org.eclipse.birt.report.designer.samplereports (2.2.1.r221_v20070904)
"BIRT Samplereports Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui (2.2.1.r221_v20070924) "BIRT
Designer UI" [Starting]
org.eclipse.birt.report.designer.ui.cubebuilder (2.2.1.r221_v20070912)
"BIRT Cube Builder Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editors (2.2.1.r221_v20070831) "BIRT
MultipageEditor Extension Point Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editors.schematic
(2.2.1.r221_v20070831) "BIRT Editors Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.ide (2.2.1.r221_v20070914) "BIRT
Designer UI for IDE" [Starting]
org.eclipse.birt.report.designer.ui.lib (2.2.1.r221_v20070831) "BIRT
Designer UI for Library" [Starting]
org.eclipse.birt.report.designer.ui.lib.explorer (2.2.1.r221_v20070831)
"BIRT Library Explorer Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.preview.web (2.2.1.r221_v20070831)
"BIRT Preview Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.samples.ide (2.2.1.r221_v20070831)
"Report Samples IDE Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui.samplesview (2.2.1.r221_v20070904)
"BIRT Report Samples View Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.views (2.2.1.r221_v20070831) "BIRT
UI Views Plug-in" [Starting]
org.eclipse.birt.report.engine (2.2.1.r22x_v20070924) "BIRT Engine" [Active]
org.eclipse.birt.report.engine.emitter.html (2.2.1.r22x_v20070918) "BIRT
HTML Emitter" [Starting]
org.eclipse.birt.report.engine.emitter.pdf (2.2.1.r22x_v20070921) "BIRT
PDF emitter" [Starting]
org.eclipse.birt.report.engine.emitter.postscript (2.2.1.v20070823)
"BIRT POSTSCRIPT emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.ppt (2.2.1.r22x_v20070924) "BIRT
PPT emitter" [Starting]
org.eclipse.birt.report.engine.emitter.prototype.excel
(2.2.1.r22x_v20070914) "BIRT Excel emitter" [Starting]
org.eclipse.birt.report.engine.emitter.wpml (2.2.1.r22x_v20070829) "BIRT
Word emitter" [Starting]
org.eclipse.birt.report.engine.fonts (2.2.1.v20070823) "BIRT Engine
fonts" [Resolved]
org.eclipse.birt.report.item.crosstab.core (2.2.1.r221_v20070831) "BIRT
Crosstab Plug-in" [Resolved]
org.eclipse.birt.report.item.crosstab.ui (2.2.1.r221_v20070913) "BIRT
Crosstab UI Plug-in" [Starting]
org.eclipse.birt.report.model (2.2.1.r22x_v20070927) "BIRT Model" [Starting]
org.eclipse.birt.report.model.adapter.oda (2.2.1.r22x_v20070911) "BIRT
Model ODA Adapter" [Starting]
org.eclipse.birt.report.runtime (2.2.1.v20070710) "BIRT Report Runtime"
[Resolved]
org.eclipse.birt.report.viewer (2.2.1.r22x_v20070920) "BIRT Web Viewer"
[Active]
org.eclipse.birt.resources (2.2.1.r22x_v20070828) "BIRT Resources
Plug-in" [Resolved]
org.eclipse.compare (3.3.1.r33x_20070906) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.0.1.M20070822-0800) "JFace Data Binding"
[Resolved]
org.eclipse.core.databinding.beans (1.0.1.M20070910-0800b) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.3.1.r331_v20070829) "File Buffers" [Active]
org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.3.1.R33x_v20070709) "Eclipse Jobs Mechanism"
[Active]
org.eclipse.core.net (1.0.1.r33x_20070709) "Internet Connection
Management" [Active]
org.eclipse.core.resources (3.3.0.v20070604) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Active]
org.eclipse.cvs (1.0.0.v20070606) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.connectivity (1.0.1.200709061) "Data Tools
Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.derby (1.0.0.200706071) "Eclipse
Data Tools Platform Apache Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.0.200706071) "Eclipse
Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.200708201)
"Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.derby (1.0.0.200706071)
"Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC
(1.0.0.200706071) "Eclipse Data Tools Platform DBDefinition Generic JDBC
Plug-in" [Starting]
org.eclipse.datatools.connectivity.derby (1.0.0.200706071) "Eclipse Data
Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.derby.ui (1.0.0.200706071) "Eclipse
Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda (3.1.0.200708161) "DTP Open Data
Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.1.200708221) "DTP
ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.5.200709071) "DTP ODA
Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.5.200709071) "DTP
ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.4.200706071)
"Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.5.200707301)
"Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.5.200708131) "DTP
ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.5.200707301)
"DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.1.200709071) "Eclipse
Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.0.1.200708201)
"Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.fe.ui (1.0.0.200706071) "Eclipse
Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.fe.ui.actions (1.0.0.200706071)
"Eclipse Data Tools Platform FE Ui Actions Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.0.0.200709141)
"Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.0.1.200708231) "Data Tools
Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.0.1.200709171) "Eclipse
Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.0.0.200706071) "Data Tools Platform
User Guide" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.200708161) "Eclipse Data
Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.200706071) "Eclipse Data
Tools Platform Hypersonic DB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n
(1.0.0.200706071) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.profile
(1.0.0.200706071) "Eclipse Data Tools Platform IBM DB2 UDB iSeries
Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition
(1.0.0.200706071) "Eclipse Data Tools Platform DB2 UDB Database
org.eclipse.datatools.enablement.ibm.db2.luw.profile (1.0.0.200706071)
"Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n
(1.0.0.200706071) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.profile
(1.0.0.200706071) "Eclipse Data Tools Platform IBM DB2 UDB zSeries
Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition
(1.0.0.200706071) "Eclipse Data Tools Platform Informix Database
org.eclipse.datatools.enablement.ibm.informix.profile (1.0.0.200706071)
"Eclipse Data Tools Platform Informix Plug-in" [Resolved]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition
(1.0.0.200706071) "Eclipse Data Tools Platform SQL Server Database
org.eclipse.datatools.enablement.msft.sqlserver.profile
(1.0.1.200709041) "Eclipse Data Tools Platform Microsoft SQL Server
Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.0.200706071) "Eclipse Data
Tools Platform MySQL enablement plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.1.200709181)
"Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.profile (1.0.0.200706071)
"Eclipse Data Tools Platform MySQL Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.0.1.200709111) "Eclipse Data
Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.0.1.200709111) "Eclipse
Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.0.2.200709101) "Eclipse Data
Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.0.2.200709071) "Eclipse
Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.0.200706071)
"Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.profile (1.0.0.200706151)
"Eclipse Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition
(1.0.0.200706071) "PostgreSQL DB Definition" [Resolved]
org.eclipse.datatools.enablement.postgresql.profile (1.0.1.200709061)
"PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.200707131) "High-level
Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.0.200706071) "Sybase
ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.200706071)
"Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition
(1.0.0.200706071) "Eclipse Data Tools Platform Sybase Database
org.eclipse.datatools.enablement.sybase.ase.profile (1.0.0.200706071)
"Eclipse Data Tools Platform Sybase ASE Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.200706181) "Data Tools Platform Help
org.eclipse.datatools.lpg (1.0.0.200706071) "Wrapper for the LPG java
runtime" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.0.200706071) "Eclipse
Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.200706071) "Derby Plug-in"
[Starting]
org.eclipse.datatools.modelbase.sql (1.0.0.200708161) "Eclipse Data
Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.200706071) "Eclipse Data
Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.0.200706151) "Eclipse
Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.200706151) "Eclipse
Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.0.0.200708161) "DTP ODA
org.eclipse.datatools.sqltools.common.ui (1.0.0.200708161) "Eclipse Data
Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.0.0.200706151) "Data Core
Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.0.0.200706151) "Data UI
Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.200706071) "Eclipse Data
Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.200706131) "Eclipse
Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.200709251) "Eclipse
Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.0.200709261) "Eclipse
Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.0.200706161) "Eclipse
Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.0.200706161)
"Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.0.200706162)
"Eclipse Data Tools Platform SQL Query Parser Plugin" [Resolved]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.200706151)
"Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.200709061) "Eclipse Data
Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.200709061) "Eclipse Data
Tools Platform SQL Results View Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.200708161) "Eclipse
Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.200706111) "Eclipse Data Tools
Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.200709061) "Eclipse Data
Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.200709141) "Eclipse
Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.200706071)
"Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.tablewizard (1.0.0.200706071) "Eclipse
Data Tools Platform Database Table Creation Plug-in" [Starting]
org.eclipse.debug.core (3.3.1.v20070731_r331) "Debug Core" [Active]
org.eclipse.debug.ui (3.3.1.v20070731_r331) "Debug UI" [Active]
org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework
Draw2d" [Starting]
org.eclipse.dstore.core (2.0.1.v20070914) "RSE DStore Core" [Starting]
org.eclipse.dstore.extra (2.0.0.v20070627) "RSE DStore Platform Support"
[Starting]
org.eclipse.eclipsemonkey (1.1.0.007007) "Aptana Scripting" [Active]
org.eclipse.eclipsemonkey.doms (1.1.0.007007) "Aptana Scripting DOMs"
[Active]
org.eclipse.eclipsemonkey.lang.javascript (1.1.0.007007) "Aptana
JavaScript Scripting Support" [Active]
org.eclipse.eclipsemonkey.ui (1.1.0.007007) "Aptana Scripting User
Interface" [Starting]
org.eclipse.emf (2.3.0.v200709252135) "Eclipse Modeling Framework (EMF)"
[Starting]
org.eclipse.emf.ant (2.3.1.v200709252135) "EMF Ant Tasks" [Starting]
Generator" [Starting]
Generation" [Starting]
Generation UI" [Starting]
Generator UI" [Starting]
org.eclipse.emf.common (2.3.0.v200709252135) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.3.1.v200709252135) "EMF Common UI" [Starting]
org.eclipse.emf.commonj.sdo (2.3.0.v200709252135) "CommonJ SDO" [Starting]
org.eclipse.emf.converter (2.3.0.v200709252135) "EMF Model Convert
Support" [Starting]
org.eclipse.emf.ecore (2.3.1.v200709252135) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.3.0.v200709252135) "EMF Ecore Change
Model" [Starting]
org.eclipse.emf.ecore.change.edit (2.3.0.v200709252135) "EMF Ecore
Change Edit Support" [Starting]
Support" [Starting]
[Starting]
Objects (SDO)" [Starting]
org.eclipse.emf.ecore.xmi (2.3.1.v200709252135) "EMF XMI" [Active]
org.eclipse.emf.edit (2.3.1.v200709252135) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.3.1.v200709252135) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.3.0.v200709252135) "EMF Model Export
Support" [Starting]
org.eclipse.emf.importer (2.3.1.v200709252135) "EMF Model Import
Support" [Starting]
org.eclipse.emf.importer.ecore (2.3.1.v200709252135) "EMF Ecore
Importer" [Starting]
org.eclipse.emf.importer.java (2.3.1.v200709252135) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.3.1.v200709252135) "EMF Rose Importer"
[Starting]
org.eclipse.emf.mapping (2.3.0.v200709252135) "EMF Mapping" [Starting]
Framework (EMF) - org.eclipse.emf.mapping.ecore" [Starting]
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200709252135) "Ecore to
Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200709252135) "Ecore
to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.3.0.v200709252135) "Ecore to XML
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.3.0.v200709252135) "Ecore to XML
Mapping UI" [Starting]
org.eclipse.emf.mapping.ui (2.3.0.v200709252135) "EMF Mapping UI" [Starting]
org.eclipse.equinox.app (1.0.1.R33x_v20070828) "Equinox Application
Container" [Active]
org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.http.jetty (1.0.1.R33x_v20070816) "Jetty Http
Service" [Starting]
org.eclipse.equinox.http.registry (1.0.0.v20070608) "Http Service
Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.1.R33x_v20070816) "Http Services
Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.1.R33x_v20070816) "Jasper Jsp
Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp
Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.1.R33x_v20070828) "Equinox Launcher"
[Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.2.R331_v20071019)
"Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.preferences (3.2.100.v20070522) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.3.1.R33x_v20070802) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.101.v20070814) "Graphical Editing Framework" [Starting]
org.eclipse.help (3.3.1.v20070726_33x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20070510) "Help Application
Re: Eclipse PDT 1.0.2 is freezing randomly on big file [message #65926 is a reply to message #65902] Wed, 13 February 2008 06:07 Go to previous message
exquisitus wrote:
> Hello,
> the momment.
Hi, check out the thread called "Editor breaks up every now and then",
started 1/24/2008
It regards the same problem.
Previous Topic:debugging on LAMP situation
Next Topic:Editor breaks up every now and then
Current Time: Sat Jul 26 05:56:06 EDT 2025
Powered by FUDForum. Page generated in 0.13515 seconds
