Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Build templates
PDE Build templates [message #65844] |
Fri, 26 June 2009 20:29  |
Originally posted by: jconlon.apache.org
Trying to compare the latest 3.5 customTargets.xml to mine to see what
if anything has changed, but can't find the latest source for the PDE
Build templates.
Tried org.eclipse.pde.build/templates/headless-build at
dev.eclipse.org:/cvsroot/eclipse
but a readme says:
The PDE project has moved to the CVS repository location
dev.eclipse.org:/cvsroot/eclipse/pde
but I can't connect to that repo.
Am I off in the weeds on this or what?
any help appreciated...
John
Re: PDE Build templates [message #66202 is a reply to message #66122] |
Mon, 29 June 2009 14:35   |
I found the org.eclipse.equinox.p2.internal.repository package in the
org.eclipse.equinox.p2.repository.tools_1.0.0.v20090527-1812 .jar/lib/repository-tools-ant.jar.
As a hack I extracted that jar to my desktop and added it to the
classpath for org.eclipse.pde.build and my build now works.
But what is the preferred way to set up the dependencies to
org.eclipse.pde.build?
thanks,
John
John E. Conlon wrote:
> Hi Chris,
> Yes, as I mentioned I do see the org.eclipse.pde.build, but when I check
> it out into my workspace, as I did for ganymede, (so I can call it with
> antrunner) I get errors resolving
> org.eclipse.equinox.p2.internal.repository.tools.tasks.IUDes cription;
> org.eclipse.equinox.p2.internal.repository.tools.tasks.Repo2 RunnableTask;
> on the BrandP2Task.
> Can't find these packages in my target platform.
> How can I resolve this?
> thanks for any help,
> John
>>> what if anything has changed, but can't find the latest source for
>>> the PDE Build templates.
>>> but a readme says:
>> It's still in 'dev.eclipse.org:/cvsroot/eclipse' but it's under the
>> pde directory... pde/build/*
>> Cheers,
>> Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
>> http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: PDE Build templates [message #66349 is a reply to message #66202] |
Tue, 30 June 2009 17:07   |
From what I have found out:
Don't import the org.eclipse.pde.build, instead
use a simple ant script to set up the env and then call
<ant antfile="${eclipse.pdebuild.scripts}/productBuild/productBuild.xml "/>
See:
http://aniefer.blogspot.com/2009/03/building-p2-rcp-products -in-eclipse.html
- John
> thanks,
> John
>> Hi Chris,
>> check it out into my workspace, as I did for ganymede, (so I can call
>> it with antrunner) I get errors resolving
>> on the BrandP2Task.
>> John
>>>> but a readme says:
>>> Cheers,
Re: PDE Build templates [message #67370 is a reply to message #66202] |
Mon, 06 July 2009 17:42  |
The simplest way to satisfy these dependencies is to get
org.eclipse.equinox.p2.jarprocessor
from cvs dev.eclipse.org:/cvsroot/rt/org.eclipse.equinox/p2/bundles
-Andrew
> thanks,
> John
>> Hi Chris,
>> on the BrandP2Task.
>> John
>>>> but a readme says:
>>> Cheers,
Re: PDE Build templates [message #598678 is a reply to message #65844] |
Sat, 27 June 2009 16:32  |
> Build templates.
> but a readme says:
It's still in 'dev.eclipse.org:/cvsroot/eclipse' but it's under the pde
Re: PDE Build templates [message #598720 is a reply to message #65883] |
Sun, 28 June 2009 17:31  |
I see it.
thanks for straightening me out.
John
>> Build templates.
>> but a readme says:
> Cheers,
Re: PDE Build templates [message #598768 is a reply to message #65883] |
Mon, 29 June 2009 13:04  |
Hi Chris,
on the BrandP2Task.
John
>> Build templates.
>> but a readme says:
> Cheers,
Re: PDE Build templates [message #598799 is a reply to message #66122] |
thanks,
John
> Hi Chris,
> on the BrandP2Task.
> John
>>> but a readme says:
>> Cheers,
Re: PDE Build templates [message #598860 is a reply to message #66202] |
See:
- John
> thanks,
> John
>> Hi Chris,
>> on the BrandP2Task.
>> John
>>>> but a readme says:
>>> Cheers,
Re: PDE Build templates [message #599059 is a reply to message #66202] |
-Andrew
> thanks,
> John
>> Hi Chris,
>> on the BrandP2Task.
>> John
>>>> but a readme says:
>>> Cheers,
Current Time: Sat Jul 26 03:45:02 EDT 2025
Powered by FUDForum. Page generated in 0.06038 seconds
