Home » Archived » M2M (model-to-model transformation) » DSL projects: eclipse hangs when validating TGE
DSL projects: eclipse hangs when validating TGE [message #65796] Tue, 06 November 2007 03:27
I have been trying to develop a simple ANT-based language project using
the latest CVS version of the ATL environment and TCS under Eclipse 3.3.
Generally, everything works fine: my injector and editor have been
successfully generated and are usable.
The only problem is that, each time I start my injection script, Eclipse
hangs for a long time and displays exception stacks with the following
error messages:
Package with uri 'http://www.eclipse.org/gmt/tcs/2007/Editor' not found
Package with uri 'http://www.eclipse.org/gmt/tcs/2007/Outline' not found
My guess is that there is an attempt to validate my editor models
TGE/*-Editor.xmi and TGE/*-Outline.xmi, but the namespace definitions are
not found at the given URIs.
I don't understand why my editor models should be loaded and validated
while I only want to use my injector (and while there is actually no
editor pane open).
How can I prevent it from happening ?
Guillaume Savaton
Previous Topic:RCP feature/patch error installing ATL
Next Topic:[ATL]Instances of EMF-generated models as ATL outputs?
Current Time: Sat Jul 26 19:38:19 EDT 2025
Powered by FUDForum. Page generated in 0.24200 seconds
