connections not reconnecting [message #65735] |
Wed, 19 February 2003 11:29  |
Originally posted by: jwoods.journee.com
I've got a problem with my connections not reconnecting after an undo of a
delete command. If I delete a connection and do an undo, the connection is
fine. However, if I delete a connection and then one of the nodes the
connection was connected to and then undo both deletes - the connection's
endpoint doesn't follow the node's figure when it is moved. The strange
part is that If I close/reopen the editor - it follows it fine (possibly
understandable because I don't persist the connection anchors themselves -
they get recreated from other data).
I know for a fact the connection is still "connected" in the model, but the
connection's UI doesn't track the node's movement like it should. It would
seem as if some listener isn't getting hooked back up on the undo. But what
listener? I've stepped through the debugger and it appears the connection
anchor is being added as a listener to the node's figure (ancesterListener)
correctly - but it doesn't appear to be getting notified. ???
- Jason
Re: connections not reconnecting [message #65861 is a reply to message #65758] |
Thu, 20 February 2003 12:01   |
OK, I know what's going on now. Not sure if my fix is the correct one or
not though. Here's the deal:
Problem only occurs when I delete a connection then an endpoint node and
then undo both deletes. What is happening is that the edit part and the
figure for the node is getting deleted when the node is deleted. When I
undo that delete, the editpart and figure get recreated for the node. When
I undo the connection delete, the connection is reattached to the endpoints
but reuses existing connection anchors. These connection anchors have an
old reference to the original node's figure - and that's what they attach
themselves to listen to.
To fix this I've added a call to anchor.setFigure(this.getFigure()) from
within my node EditPart's
getSource/TargetConnectionAnchor(ConnectionEditPart) methods. This ensures
the anchor (whether newly created or reused) is up to date.
Here's what my getSourceConnectionAnchor() method currently looks like:
public void getSourceConnectionAnchor(ConnectionEditPart connEditPart)
MyConnectionModelClass conn = (MyConnectionModelClass)
connEditPart.getModel();
AbstractConnectionAnchor anchor = (AbstractConnectionAnchor)
conn.getSourceConnectionAnchor();
if ( anchor == null )
anchor = new MyAnchor(this.getFigure(),
conn.getSourceReferencePoint());
conn.setSourceConnectionAnchor(anchor);
else
anchor.setFigure(this.getFigure());
return anchor;
Currently, my connection model object holds a transient reference to the
connection anchors - these aren't persisted. What is persisted is a Point
object that the model object pulls out of the connection anchor whenever the
anchors change.
Would the better fix be to refactor my code to always create a new anchor
when getSource/TargetConnectionAnchor(ConnectionEditPart) is called? (And
to refactor out the transient reference to the anchor from within the
model)...
If it's ok to reuse anchors, then who should keep them? And how do/would
they know to ensure the owner figure is up-to-date?
- Jason
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b30bpp$1gg$1@rogue.oti.com...
> The connection anchor listens to the node figure, but does the connection
> listen to the connection anchor?
> We recently changed setSource/TargetAnchor(ConnectionAnchor) to remove a
> potential memory leak. When you undo, the polylineconnection should have
> its source/target anchors set back. Step into setXxxConnectionAnchor to
see
> if hookXxxConnecitonAnchor is being called. If it isn't, then it might be
> called later when activateFigure adds the connection to the connection
> layer.
> Do you override addNotify in PolylineConnection?
> "Jason Woods" <jwoods@journee.com> wrote in message
> news:b309qv$vaa$1@rogue.oti.com...
a
> is
connection's
themselves -
> the
> would
> what
connection
> (ancesterListener)
> > - Jason
Re: connections not reconnecting [message #65913 is a reply to message #65861] |
Thu, 20 February 2003 19:13  |
Your commands should not import or reference any java types from draw2d or
gef packages. If you need to store the anchor location, you should create
something in your model to represent it.
news:b3302a$2kh$1@rogue.oti.com...
When
endpoints
ensures
> else
> return anchor;
the
> anchors change.
> model)...
> - Jason
connection
have
> see
be
> > layer.
of
> a
connection
> > is
> connection's
strange
(possibly
> themselves -
but
> > the
> > would
But
> > what
> connection
> > (ancesterListener)
> > > - Jason
FUDForum. Page generated in 0.05876 seconds
