Problem with AJDT in eclipse 3.2 [message #65716] |
Tue, 13 June 2006 19:24  |
Originally posted by: sbederml.gmail.com
I'm trying to add aspect to an existing plugin project. The way I'm
doing it is for org.eclipse.search plugin:
1) Importing the plugin with linked content mode;
2) Converting the plugin project to AspectJ project;
3) Setting the AspectJ Out Jar to woven.jar;
4) Adding org.eclipse.search.jar to the AspectJ InPath;
5) Replacing org.eclipse.search.jar with woven.jar in the build path;
6) Creating source folder in the imported project and putting aspects
within it.
The problem is that when I run the plugin project in eclipse 3.1 the
aspects are woven into it, but when I run it from eclipse 3.2RC4-RC7 the
search option becomes not available. I'm also using the latest AJDT version.
Is this a bug in eclipse 3.2 or in AJDT?
How can I make it work in eclipse 3.2?
Thank you in advance,
Michael
Re: Problem with AJDT in eclipse 3.2 [message #65762 is a reply to message #65740] |
Thu, 15 June 2006 20:37  |
Hi Matt,
Indeed the problem was
Plug-in org.eclipse.search was unable to load class
org.eclipse.search.internal.ui.OpenSearchDialogAction.
I have replaced org.eclipse.search.jar with woven.jar in the classpath
(using Runtime tab in the manifest editor), and it works now.
Thank you very much,
Michael
Matt Chapman wrote:
> Hi Michael,
> It sounds like something is preventing the plug-in from starting, but
> it's hard to guess what that might be. Check you check for errors in the
> log (Window > Show View > Error Log) to see if that gives any clues?
> Matt.
> Michael Beder wrote:
>> within it.
>> the search option becomes not available. I'm also using the latest
>> AJDT version.
>> Michael
Re: Problem with AJDT in eclipse 3.2 [message #594133 is a reply to message #65716] |
Wed, 14 June 2006 08:12  |
Hi Michael,
Matt.
> within it.
> version.
> Michael
Re: Problem with AJDT in eclipse 3.2 [message #594148 is a reply to message #65740] |
Hi Matt,
Michael
Matt Chapman wrote:
> Hi Michael,
> Matt.
>> within it.
>> AJDT version.
>> Michael
FUDForum. Page generated in 0.06288 seconds
