Re: Web Service installation Problem [message #65973 is a reply to message #65835] |
Tue, 18 January 2005 10:20  |
Originally posted by: tdraper.novell.com
Thanks for you help. I will wait for M3.
Tim
Lawrence Mandel wrote:
> The startup option Dave is referring to is -clean however there is nothing
> wrong with your install in this case. Web services tools are not included
> in milestone M2. They are slated for milestone M3. You can see the WTP
> milestone plan at
http://www.eclipse.org/webtools/development/planning/milesto ne_plan_1_0.html.
> The document you are looking at is an evaluation guide to the initial WTP
> contribution posted by IBM last summer for feedback from the community.
> This contribution was a trial or sneak peak of some of the tools IBM
> considered contributing to the WTP project.
> Stay tuned for M3.
> Lawrence
>>Hi Tim,
>>Several people have had this problem on various windoze platforms
> (including
>>myself). Generally a clean install of all the components into an new
> empty
>>directory does the trick. There is also apparently something called
> "eclipse
>>clean" (or perhaps "eclipse clear" I can't remember) which can be run on
> the
>>existing install and should fix it. I haven't tried that as I'd already
> got
>>it working with a clean install before I found out.
>>Dave.
>>"Tim Draper" <tdraper@novell.com> wrote in message
>>news:cs9o6g$qo8$1@www.eclipse.org...
>> I am trying to install Eclipse on Windows 2000 with WTP. I am using the
>> directions outlined in:
> http://download.eclipse.org/webtools/downloads/drops/S-1.0M2 -200412230036/in
> dex.html.
>> I have tried to install a couple of times to make sure it wasn't user
>> error.
>> The install works except that I don't see the menu feature for Web
>> Services. I have been looking at:
> http://www.eclipse.org/webtools/initial-contribution/IBM/eva lGuides/WebServi
> cesToolsEval.html?p=1.
>> In section 3.3, it shows that a Web Service option should exist in the
>> preferences. I don't see it in preferences or under File|new|other|web
>> service.
>> I do see XML as an option under preference and File|new|other.
>> I must be missing a key plug-in.
>> Any help will be appreciated.
>> Thanks Tim
FUDForum. Page generated in 0.25930 seconds
