Home » Language IDEs » Java Development Tools (JDT) » [ANN] release 1.3.2 of metrics plugin
[ANN] release 1.3.2 of metrics plugin [message #65681] Mon, 23 June 2003 23:58 Go to next message
New release 1.3.2 with these new features:
* Pause/Resume/Abort actions
* Usage hint in Dependency Graph View (a la Type Hierarchy)
* Progress Indicator for Enable
* Ant tasks for headless operation (finally!)
* Ranges and out-of-range flags in exported XML
* Cyclic package dependencies added to exported XML
http://metrics.sourceforge.net
(I know, webpage is not updated yet, help docs in plugin are though)
Frank
Re: [ANN] release 1.3.2 of metrics plugin [message #65703 is a reply to message #65681] Tue, 24 June 2003 01:23 Go to previous messageGo to next message
Frank,
I like the new version. The speed improvement after droping prevayler is
significant. A couple of suggestions:
- when metrics view is first shown, instead of keeping it blank, tell user
how to turn on metrics (hierarchy does it nicely)
- the same for dependency graph view -be explicit - although the new version
helps :)
How does "Usage hint in Dependency Graph View (a la Type Hierarchy)" work?
Regards.
Re: [ANN] release 1.3.2 of metrics plugin [message #66317 is a reply to message #65703] Tue, 24 June 2003 12:54 Go to previous message
Good idea. In the dependency graph it works by having the graph view show a
graph
with a single node. That node's label is the hint.... I couldn't figure out
quickly how to
work the StackLayout properly to have a label with hint and graph view on
top of each other
and show one or the other. Sounds like I'll need to figure that out anyways
to do it in the
metrics view as well. Time to study the Type Hiewrachy view I guess :-)
Frank
"Vladimir Blagojevic" <vladimir@cs.yorku.ca> wrote in message
news:bd8n7t$tjt$1@rogue.oti.com...
> Frank,
version
> helps :)
> Regards.
Previous Topic:[ANN] JNDI Explorer version 1.1
Next Topic:jdk 1.5, and early release stuff
Current Time: Mon Jul 21 21:59:07 EDT 2025
Powered by FUDForum. Page generated in 0.05876 seconds
