Home » Eclipse Projects » Mylyn » WikiText preview
WikiText preview [message #65674] Thu, 19 February 2009 09:48 Go to next message
Originally posted by: tbone13.gmx.de
I'm trying to use Mylyn WikiText in my little RCP-App.
I tried it in the IDE with a generic project and a file "test.textile"
und tried to start with a heading
h1. test
some text
(w/o the quotes)
For a second I can see a well formatted output in the preview editor
page. but after this second it looks like this:
"blank#test"
no more text or any fomatting.
Is it a bug or did I miss some configuration?
Thanks in advance
Grretings
Tobi
Re: WikiText preview [message #65763 is a reply to message #65674] Fri, 20 February 2009 06:10 Go to previous messageGo to next message
Hello!
I have some addition to my previous post.
The HTML source of the preview is
<HTML>blank#test</HTML>
so I think there is a problem in the parser.
On the other hand I tried the Task editor with textile-comment and it
works well. the same when I export HTML from the textile file
Greetings
Tobi
Re: WikiText preview [message #65785 is a reply to message #65763] Fri, 20 February 2009 17:40 Go to previous messageGo to next message
Tobi,
There's a great little example application that you can see if you
install the WikiText projects into your workspace (see
http://wiki.eclipse.org/index.php/Mylyn/Contributor_Referenc e#Workspace).
The code demonstrates how to integrate WikiText parsing for display with
a Browser widget as well as with the MarkupViewer.
The class is org.eclipse.mylyn.wikitext.textile.core.Main and you can
run it by right-clicking on the file in Eclipse and selecting Run
As->Java Application
If after looking at that code you still have problems please file a bug
at Eclipse.org and attach the problem code.
David
Re: WikiText preview [message #65877 is a reply to message #65785] Tue, 24 February 2009 09:21 Go to previous messageGo to next message
> Tobi,
> David
David,
I found my mistake. I used the Weekly Updatesites, Mylyn 3.1 and
WikiText 0.9.4. I don't know if it is a bug or version conflict with the
rest of my installation. back to Mylyn 3.0.2 and WikiText 0.9.0 all
works fine.
I tried your example, but I don't understand how to use the internal
MarkupProjection in this Editor.
Best regards!
Tobi
Re: WikiText preview [message #65893 is a reply to message #65877] Tue, 24 February 2009 10:01 Go to previous message
> works fine.
Tobi, I'm glad that you got it working. Note that the weekly update
sites hold the latest builds with code from CVS -- so if something isn't
working please let me know by filing a bug and I'll look into the issue.
There should be no need to use any internal classes. If you think that
you need to use internal classes to achieve what you need then please
file a bug requesting that the classes be made API.
David
Re: WikiText preview [message #596395 is a reply to message #65674] Fri, 20 February 2009 06:10 Go to previous message
Hello!
Greetings
Tobi
Re: WikiText preview [message #596407 is a reply to message #65763] Fri, 20 February 2009 17:40 Go to previous message
Tobi,
David
Re: WikiText preview [message #596433 is a reply to message #65785] Tue, 24 February 2009 09:21 Go to previous message
> Tobi,
> David
David,
works fine.
Best regards!
Tobi
Re: WikiText preview [message #596443 is a reply to message #65877] Tue, 24 February 2009 10:01 Go to previous message
> works fine.
David
Previous Topic:Mylyn without CVS support
Next Topic:JIRA Connector and Subtasks
Current Time: Sun Jul 27 03:11:01 EDT 2025
Powered by FUDForum. Page generated in 0.05387 seconds
