Using Namespace URIs to Import Existing EPackages [message #654526] |
Wed, 16 February 2011 08:29 |
I had some doubts about Using Namespace URIs to Import Existing EPackages.
In the Xtext User Guide, there is a topic called "Using Namespace URIs to Import Existing EPackages", which says Quote: |
You can also use nsURI in order to import existing EPackage. Note that this is generally not preferrable, because you'll have to have the corresponding EPackage installed in the workbench.
What does the statement "You'll have to have the corresponding EPackage installed in the workbench." mean???
Does it mean that the EPackage must be installed through update site or must be there in design time workbench.
I have created a grammar which depends on the existing Ecore models. It takes the namespace uri of an existing EPackage.
Now, when i try writing code in accordance with my grammar, in the import statement i can only give the namespace uri of an EPackage whose Ecore file as well as the sources are already there in design time or the plugin is installed from Update Site.
But if i try to give a namespace uri whose ecore file as well as the sources are there in the runtime workbench and is not there in compile time workbench (and are also not installed as a plugin through update site), then it is unable to find the EPackage.
Can you please tell me why is this happening? Is there any solution to it.
Animesh
FUDForum. Page generated in 0.02606 seconds
