Re: need help with terminal/keyword problem [message #653839 is a reply to message #653722] |
Fri, 11 February 2011 13:43 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
I managed to solve this in the end, but wonder why it has to be so darned
complicated...
I ended up with a rule using a fragment for the :: part, and it required a
predicate of (':' ':')=>. this got me as far as not greedily lexing a
single colon. To make it perform as if terminated by a space (the dfa
prediction generated by antlr does not seem to consider the predicated
colons...), I had to write an action last in the rule to check if parsed
text is a keyword and return the keyword token instead.
- henrik
Henrik Lindberg <henrik.lindberg@cloudsmith.com> wrote:
> I have this terminal rule
> terminal FQN :
> (':' ':')? ('0'..'9'|'a'..'z'|'A'..'Z'|'_'|'.'|'-')+
> ((':' ':') ('0'..'9'|'a'..'z'|'A'..'Z'|'_'|'.'|'-')+)*;
> and a set of keywords such as 'default', 'case', etc.
> with the intent of allowing FQN to include keywords if also including
> '::' as in '::default', or 'default::default', or naturally a::b::c::d etc.
> I get problems when the lexer sees a sequence that ends with a single
> ':', it will then not recognize what precedes it as a keyword. e.g.
> // false error on space after ':' (expected ':')
> default:
> // ok
> default::default
> // ok - kw 'default' followd by ':'
> default :
> I use an external lexer so I can include "antlr tricks", but at the
> moment I don't understand how to make the lexer do the same when it sees
> a ':' that is not followed by a another ':' as it does when it sees say a space.
> I do not want to use parser rules for this (moving this to the lexer is
> done to reduce the complexity in the grammar).
> Hope someone can help me...
> Regards
> - henrik
- henrik
FUDForum. Page generated in 0.03063 seconds
