Home » Newcomers » Newcomers » SWT ScrollBar problem(I'm creating a display,shell and canvas, drawing a rectangle and zooming it. After that I'm not able see the complete rectangle when scrolling down the scrollbar)
SWT ScrollBar problem [message #653601] |
Thu, 10 February 2011 11:35 |
vijaya Messages: 2 Registered: February 2011 Location: Banglore |
Junior Member |
Hi I'm attaching my code also here. Can anybody help me please
My mail id is vijaya.pramila@gmail.com
My code is
import org.eclipse.swt.*;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.ScrollBar;
import org.eclipse.swt.widgets.Slider;
import org.eclipse.swt.events.*;
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.*;
public class Snippet9 {
static double zoom = 1.0;
Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
final Point origin = new Point(0, 0);
final Canvas canvas = new Canvas(shell, SWT.BORDER | SWT.H_SCROLL
| SWT.V_SCROLL);
canvas.setBackground(new Color(display, 255, 255, 255));
canvas.setSize(600, 500);
final Color cyan = display.getSystemColor(SWT.COLOR_CYAN);
canvas.addPaintListener(new PaintListener() {
public void paintControl(PaintEvent e) {
e.gc.setBackground(cyan);
e.gc.drawRectangle(20, 20, (int) (200 * zoom),
(int) (200 * zoom));
e.gc.fillRectangle(20, 20, (int) (200 * zoom),
final ScrollBar hBar = canvas.getHorizontalBar();
hBar.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event e) {
int hSelection = hBar.getSelection();
int destX = -hSelection - origin.x;
Rectangle rect = canvas.getBounds();
* canvas.getAlwaysShowScrollBars();
* canvas.setExpandHorizontal(true);
* canvas.setExpandVertical(true);
canvas.scroll(destX, 0, 0, 0, rect.width, rect.height, false);
origin.x = -hSelection;
final ScrollBar vBar = canvas.getVerticalBar();
vBar.addListener(SWT.Selection, new Listener() {
int vSelection = vBar.getSelection();
int destY = -vSelection - origin.y;
canvas.scroll(0, destY, 0, 0, rect.width, rect.height, false);
origin.y = -vSelection;
// treeCanvas.redraw();
canvas.addListener(SWT.Resize | SWT.Show, new Listener() {
Rectangle client = canvas.getClientArea();
hBar.setMaximum((int) ((rect.width) * zoom));
vBar.setMaximum((int) ((rect.height) * zoom));
hBar.setThumb(Math.min(rect.width, client.width));
vBar.setThumb(Math.min(rect.height, client.height));
int hPage = rect.width - client.width;
int vPage = rect.height - client.height;
if (hSelection >= hPage) {
if (hPage <= 0)
hSelection = 0;
shell.setVisible(true);
canvas.setVisible(true);
if (vSelection >= vPage) {
if (vPage <= 0)
vSelection = 0;
canvas.dispose();
canvas.redraw();
Slider slider = new Slider(canvas, SWT.HORIZONTAL);
slider.setBounds(canvas.getBounds().width / 8, (int) (canvas
.getBounds().height / 1.1), 150, 20);
slider.setMinimum(10);
slider.setMaximum(110);
slider.addSelectionListener(new SelectionListener() {
public void widgetSelected(SelectionEvent e) {
Slider source = (Slider) e.getSource();
int value = source.getSelection();
zoom = ((value) / 46.0);
canvas.redraw();
shell.layout();
public void widgetDefaultSelected(SelectionEvent arg0) {
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Re: SWT ScrollBar problem [message #653776 is a reply to message #653601] |
Fri, 11 February 2011 06:43 |
I am not too sure if you should continue this way for zooming as this can have a lot of flicker on screen because of low rates for frame per second generated by this approach.
My suggestions would be to see draw2D and how it helps for zooming or u can even try OpenGL stuff for higher fps.
Re: SWT ScrollBar problem [message #654213 is a reply to message #653601] |
Mon, 14 February 2011 15:30 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
You should ask on the SWT forum group; you're more likely to find expert
advice there.
Eric
> My mail id is mailto:vijaya.pramila@gmail.com
> My code is
> public static void main(String[] args) {
> | SWT.V_SCROLL);
> if (hPage <= 0)
> hSelection = 0;
> if (vPage <= 0)
> vSelection = 0;
> canvas.dispose();
> canvas.redraw();
> canvas.redraw();
> shell.layout();
> shell.open();
> display.sleep();
> display.dispose();
Current Time: Fri Apr 26 23:38:40 GMT 2024
Powered by FUDForum. Page generated in 0.08179 seconds
