Re: Problem in running application in eclipse [message #653348 is a reply to message #653260] |
Wed, 09 February 2011 13:29 |
On 2011.02.08 22:26, naveen wrote:
> Hi Problem in running webapp.
> Here i am using Eclipse 3.2.0 and Tomcat 5.5
> But here i am unable to run the server ie., there is no option run on
> server when i right click the login.jsp which is the starting file of
> the application.
> Can anyone resolve my problem.
First, it would be more appropriate for you to upgrade to modern
Eclipse. Currently, we're touching at the end of version 3.6. Second,
likely the forum you'll want to ask this in is eclipse.wst. Last, there
isn't enough detail to do much more than speculate or ask you more
questions. You should provide much more.
Re: Problem in running application in eclipse [message #653350 is a reply to message #653348] |
Wed, 09 February 2011 13:33 |
>> the application.
> likely the forum you'll want to ask this in is eclipse.wst.* Last, there
*Sorry, the forum is actually eclipse.webtools.
FUDForum. Page generated in 0.08067 seconds
