Home » Eclipse Projects » Commercial » [ANN] MyEclipse 4.0 m3 - Includes Split-Screen Web Designer, UML Reverse Engineering, & New Appl
[ANN] MyEclipse 4.0 m3 - Includes Split-Screen Web Designer, UML Reverse Engineering, & New Appl [message #5854] Mon, 15 August 2005 10:43
Originally posted by: Support.myeclipseide.com
The third milestone release for the MyEclipse Enterprise Workbench version
4.0, is now available for immediate download at the MyEclipse site
(http://www.myeclipseide.com). This release introduces a number of new
features including full round trip UML development, new visual Web Designer,
expanded application-server connector support for Weblogic 9, Websphere 6
and Geronimo 1.0 and a number of platform enhancements. MyEclipse 4.0 M3
includes the following features and enhancements:
Full round trip UML development
- Reverse-engineer UML class diagrams from any MyEclipse J2EE
project or Eclipse Java project
- Batch process reverse-engineer any combination of project,
source-folder, Java package or individual class
- Drag-n-drop any Java class or interface from the Eclipse
PackageExplorer view onto any UML class diagram
- Customizable reverse-engineering preferences
- Drag-n-drop any UML artifact from the Outline view onto any
compatible UML diagram
- Auto-layout option for class diagram
- Comprehensive Undo support for all operations
New Visual Web Designer for WYSIWYG HTML/JSP development:
- Multiple page editor for source, visual design, split-screen
source-design and preview Modes
- Visually layout and size HTML, JSF and Struts UI controls
- Real-time synchronization between design and source modes
- Collapsible palette with 50+ design wizards for the creation
of new web UI controls
- Custom form-based property editors integrated with Properties
View
- Drag-and-drop and copy/cut/paste UI controls and visually
represented source artifacts
- Visual controls depict fly-over details of the underlying
source code
- Design mode support for CSS styles
- Code completion of elements and attributes
- While-you-type and file save validation with Problems view
support
- Auto-correction support of JSP imports
- Special support for default tag namespaces when editing JSP
fragments that lack explicit
- Show/hide non-visual tags in Visual Design Mode
An enhanced version of the Spring IDE
- New "Add Spring Capabilities" wizard
- Included Spring Framework 1.2.3 and all dependent libraries to
support the "Add Spring Capabilities" process
- New MyEclipse Spring Libraries
- Enhanced Spring IDE features include:
* Bean View
* Bean Graph View
* Integrated MyEclipse XML editor default bean
configuration editor
* Bean file validation
* 'S' character decoration for Spring enabled projects
- Spring Framework Developer Manual
- Spring IDE Developer Manual
Expanded Application-Server Connector Support for Weblogic 9, Websphere 6
and Geronimo 1.0
MyEclipse Platform Enhancements including:
- Modularized MyEclipse feature-sets for independent update
- Configurable MyEclipse feature-sets allowing users to
configure the Eclipse desktop to show/hide the MyEclipse feature-sets using
the Eclipse "capabilities" facility.
- New deployment option allowing the MyEclipse Deployer to
overwrite existing resources with their newer instance
Please review our New and Noteworthy section
( http://www.myeclipseide.com/ContentExpress-display-ceid-66.h tml) for
additional details on the new features and enhancements included in this
release.
Final release for MyEclipse 4.0 should be available August 29th, 2005.
Previous Topic:Web Performance Analyzer Eclipse Plugin EAP
Next Topic:[ANN] MyEclipse 4.0 m3 - Includes Split-Screen Web Designer, UML Reverse Engineering, & New Appl
Current Time: Fri Jul 25 01:51:27 EDT 2025
Powered by FUDForum. Page generated in 0.06098 seconds
