Home » Eclipse Projects » Equinox » Eclipse OSGi internal APIs
Eclipse OSGi internal APIs [message #65514] Thu, 27 April 2006 13:50 Go to next message
Currently I am using the following classes in my TPTP Integrated Agent
Controller code:
org.eclipse.osgi.framework.internal.core.BundleFragment
org.eclipse.osgi.framework.internal.core.BundleHost
org.eclipse.osgi.internal.baseadaptor.BaseStorageHook
These are marked as "internal" classes and I am discouraged to use them
in my code. However, I cannot find the "public" correspondence of those
classes. I need the above classed for resolving the JAR ad DLL files
provided by a bundle as well as its dependent bundles. One example is
that I may need to know where the SWT DLL's are unpacked under the
Eclipse configuration directory.
I have some questions:
1. Is there a plan to make them public? i.e. not internal
2. If not, is there going to be major changes on those classes in the
upcoming releases?
I will need know the answers since any changes now will impact our TPTP
4.2 development plan. Thanks.
Samson
Re: Eclipse OSGi internal APIs [message #65558 is a reply to message #65514] Fri, 28 April 2006 04:34 Go to previous messageGo to next message
Hi Samson,
I have a bundle with native-libs myself. And i cannot think of any
reason why I would want to know where my dlls/.so files are unpacked.
All i want to do with a dll/so is to load it.
What makes you want to know where the dll/so file is physically located ?
Even then if you start with -clean, the configuration area is wiped and
libs are unpacked fresh, so you couldn't save anything in there, only load.
Stepan
Samson Wai schrieb:
> Controller code:
> upcoming releases?
> Samson
Re: Eclipse OSGi internal APIs [message #65578 is a reply to message #65558] Fri, 28 April 2006 09:51 Go to previous messageGo to next message
Hi Stepan,
The reason I wanted to locate the DLL (such as the SWT ones) is that the
IAC is going to launch an external program (such as java.exe, or any
arbitrary executables) which will eventually trying to load the DLL's.
The IAC itself does have some DLL's packaged under its own
plugin/fragment and use the Bundle-NativeCode keyword in the manifest
file for locating them during plugin load time. But when IAC launches
another executable, it needs to know where physically these DLL's are in
order to populate the PATH environment for launching.
One example is the TPTP manual test client, which requires the TPTP
Execution Framework and the SWT plugins and thus also requires their
DLL's in the PATH environment when launched. The IAC is currently using
those internal APIs for resolving the FQ paths of the SWT JAR/DLL files
and add them to the CLASSPATH/PATH environment for the launched process.
I think the PDE launch capability can do somewhat similar but I couldn't
find a useful sample for my use case. Any pointers on this will be very
useful.
Samson
Stepan Rutz wrote:
> Hi Samson,
> Stepan
> Samson Wai schrieb:
>> Controller code:
>> them in my code. However, I cannot find the "public" correspondence of
>> those classes. I need the above classed for resolving the JAR ad DLL
>> files provided by a bundle as well as its dependent bundles. One
>> example is that I may need to know where the SWT DLL's are unpacked
>> under the Eclipse configuration directory.
>> upcoming releases?
>> TPTP 4.2 development plan. Thanks.
>> Regards,
>> Samson
Re: Eclipse OSGi internal APIs [message #65599 is a reply to message #65578] Fri, 28 April 2006 11:59 Go to previous messageGo to next message
Samson, thanks for clarification. I get your point now.
I use Bundle-NativeCode myself, but i see now why it is not enough.
Sorry, then the public api probably hides the OSGi configuration-area.
At least that seems reasonable to me. Also I am out of ideas :)
Stepan
Samson Wai schrieb:
> Hi Stepan,
> useful.
> Samson
> Stepan Rutz wrote:
>> Hi Samson,
>> and libs are unpacked fresh, so you couldn't save anything in there,
>> only load.
>> Regards,
>> Stepan
>> Samson Wai schrieb:
>>> Hi,
>>> Agent Controller code:
>>> of those classes. I need the above classed for resolving the JAR ad
>>> DLL files provided by a bundle as well as its dependent bundles. One
>>> upcoming releases?
>>> Regards,
>>> Samson
Re: Eclipse OSGi internal APIs [message #65728 is a reply to message #65599] Mon, 01 May 2006 15:34 Go to previous messageGo to next message
Take a look at the org.eclipse.core.runtime.FileLocator class in the
org.eclipse.equinox.common bundle. You can use the Bundle.findEntries
method to get the URLs to the libraries from the SWT bundle. Then you
can use the toFileURL method to get the real file location on disk where
the library got extracted. For example,
Bundle swtBundle = ...
Enumeration dlls = swtBundle.findEntries("", "*.dll", false)
while (dlls != null && dlls.hasMoreElements())
System.out.println(FileLocator.toFileURL((URL) dlls.nextElement()));
Re: Eclipse OSGi internal APIs [message #65769 is a reply to message #65599] Mon, 01 May 2006 15:36 Go to previous message
Thanks Stepan. Should I open a bugzilla enhancement request to make
those "internal" APIs "public" for the next release? If that's
reasonable, which component should I file the bug against?
Samson
> Stepan
> Samson Wai schrieb:
>> Hi Stepan,
>> the IAC is going to launch an external program (such as java.exe, or
>> any arbitrary executables) which will eventually trying to load the
>> DLL's. The IAC itself does have some DLL's packaged under its own
>> in order to populate the PATH environment for launching.
>> using those internal APIs for resolving the FQ paths of the SWT
>> JAR/DLL files and add them to the CLASSPATH/PATH environment for the
>> launched process.
>> couldn't find a useful sample for my use case. Any pointers on this
>> will be very useful.
>> Regards,
>> Samson
>> Stepan Rutz wrote:
>>> Hi Samson,
>>> located ?
>>> only load.
>>> Regards,
>>> Stepan
>>> Samson Wai schrieb:
>>>> Hi,
>>>> the upcoming releases?
>>>> Regards,
>>>> Samson
Previous Topic:Timeframe for Integrating AspectJ Load-Time Weaving into OSGi?
Next Topic:org.osgi.framework.bootdelegation=*
Current Time: Sun Jul 27 12:53:21 EDT 2025
Powered by FUDForum. Page generated in 0.04011 seconds
