Re: Still Having problems starting eclipse [message #652769 is a reply to message #652763] |
Sun, 06 February 2011 15:35 |
On 2011.02.06 6:51, Geraldine Simpkins wrote:
> I've followed the instructions given in the STICKY about specifying the
> JVM and I believe I have correctly configured it into the ini file.
> However whenever I try to start up eclipse it complains that it cannot
> find the jvm.dll file (even though the it is showing the correct
> pathname). Any ideas?
> I have just downloaded the Java EE IDE, prior to this I was successfully
> using the standard Java IDE.
> Cheers
Please paste your eclipse.ini in your question.
Note that you need a JDK and not a mere JRE (JVM). If you like, peruse
the following Eclipse setting-up summary:
http://www.javahotchocolate.com/tutorials/eclipse-summary.ht ml
FUDForum. Page generated in 0.07786 seconds
