load image to Gallery very slow [message #65474] |
Sat, 11 July 2009 15:42  |
Hi:
I use swt.image for assign images of the a folder with many images of high
sized but is very slow. Next I use the image with xxx.setImage();
I would like you to help me.
This is the code:
Image itemImage;
alleryItem item ;
// files.lenght = 700;
for (int i = 0, n = files.length; i < n; i++) {
itemImage = new Image(display, files[i].toString());
// resize the image
item.setImage(resize(itemImage, 640, 480));
itemImage.dispose();
Regards.
Gaston
Re: load image to Gallery very slow [message #66025 is a reply to message #65872] |
Sat, 25 July 2009 06:56  |
Hi Gaston,
AWT will add additionnal work to convert images to SWT so this won't
give you any speed improvements.
The code you provided uses the virtual mode but does not use threads.
Try to do the image loading and resize work in a Thread or a Job.
Note that the code on my blog uses the maximum processing quality, which
is the slowest :
gc.setAntialias(SWT.ON);
gc.setInterpolation(SWT.HIGH);
try to replace the previous code by
gc.setAntialias(SWT.OFF);
gc.setInterpolation(SWT.LOW);
This is often enough for thumbnails.
And don't forget to keep track of Image objects. You have to dispose
them after use (the gallery won't do this automatically).
Nicolas
gaston a écrit :
> Hi, I change mi code, is better, but is a bit slow.
> It is better to do with AWT and then convert to SWT for use in the
> gallery? The code for Resize is yours and is in your blog.
> gallery.addListener(SWT.SetData, new Listener() {
> public void handleEvent(Event event) {
> GalleryItem item = (GalleryItem) event.item;
> int index;
> if (item.getParentItem() != null) {
> index = item.getParentItem().indexOf(item);
> item.setItemCount(0);
> } else {
> index = gallery.indexOf(item);
> item.setItemCount(100);
> System.out.println( "setData index " + index); //$NON-NLS-1$
> // map is a map with file path
> Image img = resize(map.get(index), 640,480); item.setImage(img);
> item.setText("Item " + index); //$NON-NLS-1$
> }); Regards.
> And Thank you.
Re: load image to Gallery very slow [message #595738 is a reply to message #65474] |
Sat, 18 July 2009 06:22  |
Hi Gaston,
Loading and resizing images with SWT is not that fast and with this
code, your application is frozen while it processes all images.
You should do the loading and resizing in a separate thread and use
setImage after each image processed. Most applications work this way.
Additionnaly, you can post the code you use for resize, there may be
possible speed improvements.
Nicolas
gaston a écrit :
> Hi:
> high sized but is very slow. Next I use the image with xxx.setImage();
> This is the code:
> Image itemImage;
> alleryItem item ;
> // resize the image
> Regards.
> Gaston
Re: load image to Gallery very slow [message #595745 is a reply to message #65853] |
Sun, 19 July 2009 22:16  |
gallery?
int index;
} else {
item.setImage(img);
Regards.
And Thank you.
Re: load image to Gallery very slow [message #595804 is a reply to message #65872] |
Hi Gaston,
is the slowest :
Nicolas
> int index;
> } else {
> }); Regards.
> And Thank you.
FUDForum. Page generated in 0.03373 seconds
