Home » Eclipse Projects » Nebula » Nebula example error
Nebula example error [message #5850] |
Thu, 29 June 2006 12:47  |
Originally posted by: paul.hunter.rmb.co.za
Greetings All
I'm running eclipse 3.1 and jdk1.5.0_07. I have extracted the
nebula_examples.jar file into the eclipse/plugins directory. What
should I do with the nebula_grid.jar file?
When I try and open the nebula examples I get the following error
Unable to create view: Plug-in org.eclipse.swt.nebula.examples was
unable to load class org.eclipse.swt.nebula.examples.ExamplesView.
I have also restarted eclipse a number of time.
Thanks in advance
Paul
Re: Nebula example error [message #5956 is a reply to message #5920] |
Thu, 06 July 2006 06:45   |
Chris,
I'm also really interested in the nebula table grid. I _can't_ use Java
5, but want to play around with it also. How are your plans to update
the sample code?
By the way: Are you planning to write a JFace viewer for the grid? We
did some wrappers around JFace for our personal needs, and they are all
working with the StructuredViewer interface. By your sample code for
creating the grid it should be easily possible to do a GridViewer based
on the StructuredViewer interface, isn't it? (o.k., you may have to
adapt Content and LabelProvider also, and give the possibility to use a
_useful_ ColorProvider, but also that should be manageable).
Thanks in advance
Guido
Paul schrieb:
> No worries...I have upgraded to Eclipse 3.2 and 1.5 and all is working now
> Thanks
> Paul
> Chris Gross wrote:
>> Hi Paul,
>> No this is my error. I unintentionally compiled the plugins with a
>> 1.5 target (I assume you're using an older jre). I will post a new
>> version of the plugins with the target lowered but I can't do that
>> right away. I've made significant changes to Grid since I posted the
>> original examples download and those changes are not complete. I will
>> upload a new version in a week or so. Until then you'll need a 1.5 jre.
>> Sorry,
>> -Chris
>> Paul wrote:
>>> Thanks for the reply Chris. I have extracted both jars into the
>>> plugins directory and restarted eclipse but still get the following
>>> error. I'm doing something wrong.
>>> java.lang.UnsupportedClassVersionError:
>>> org/eclipse/swt/nebula/examples/ExamplesView (Unsupported major.minor
>>> version 49.0)
>>> at java.lang.ClassLoader.defineClass0(Native Method)
>>> at java.lang.ClassLoader.defineClass(Unknown Source)
>>> at
>>> org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
>>> at
>>> org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:227)
>>> at
>>> org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
>>> at
>>> org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
>>> at
>>> org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
>>> at
>>> org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
>>> at
>>> org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:72)
>>> at
>>> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
>>> Chris Gross wrote:
>>>> Hi Paul,
>>>> Both plugins (jars) in the examples download zip should be extracted
>>>> into the plugins directory. The nebula_grid.jar file is not
>>>> necessary for the examples plugin to work (the nebula code is in the
>>>> nebula plugin).
>>>> -Chris
>>>> Paul wrote:
>>>>> Greetings All
>>>>> Thanks in advance
>>>>> Paul
Re: Nebula example error [message #5974 is a reply to message #5956] |
Thu, 06 July 2006 07:54   |
Sorry about the 'by the way' section, just didn't see the Message of
Hans Mueller-Dieckert.
Guido
> Chris,
> the sample code?
> Thanks in advance
> Guido
>> now
>> Thanks
>> Paul
>> Chris Gross wrote:
>>> Hi Paul,
>>> will upload a new version in a week or so. Until then you'll need a
>>> 1.5 jre.
>>> Sorry,
>>> -Chris
>>>> major.minor version 49.0)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Chris Gross wrote:
>>>>> Hi Paul,
>>>>> extracted into the plugins directory. The nebula_grid.jar file is
>>>>> not necessary for the examples plugin to work (the nebula code is
>>>>> in the nebula plugin).
>>>>> -Chris
>>>>> Paul wrote:
>>>>>> Greetings All
>>>>>> Thanks in advance
>>>>>> Paul
Re: Nebula example error [message #5992 is a reply to message #5956] |
Fri, 14 July 2006 16:27   |
Hi Guido,
A new version of the Grid has been posted thats compiled with 1.4.
-Chris
Guido Küpper wrote:
> Chris,
> the sample code?
> Thanks in advance
> Guido
>> now
>> Thanks
>> Paul
>> Chris Gross wrote:
>>> Hi Paul,
>>> 1.5 jre.
>>> Sorry,
>>> -Chris
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Chris Gross wrote:
>>>>> Hi Paul,
>>>>> -Chris
>>>>> Paul wrote:
>>>>>> Greetings All
>>>>>> Thanks in advance
>>>>>> Paul
Re: Nebula example error [message #6841 is a reply to message #5992] |
Wed, 19 July 2006 04:43   |
Hi Chris,
thanks a lot for posting the Java 1.4 Version. Unfortunately, when I
integrate it into my Eclipse 3.1 and trying to select the nebula sample
view, the only thing I'm getting is two new entries in eclipse ErrorLog
telling me about an unhandled event loop exception and the next one with
the stack trace added at the bottom of this mail (hope that helps). What
am I doing wrong? Should run under Eclipse 3.1, shouldn't it? I'm really
hot about playing around with it, especially because of an outstanding
local decision trying to use nebula grid in parts of our app (and also
perhaps of developing a viewer for it).
Thanks in advance
Guido
p.s.: The stack trace from the details dialog of the eclipse error log:
java.lang.NoClassDefFoundError: org/eclipse/jface/layout/GridLayoutFactory
org.eclipse.swt.nebula.examples.parts.GridExampleTab.createP arameters(GridExampleTab.java:72)
org.eclipse.swt.nebula.examples.AbstractExampleTab.create(Ab stractExampleTab.java:175)
org.eclipse.swt.nebula.examples.ExamplesView.createPartContr ol(ExamplesView.java:60)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:305)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:180)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:1655)
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:937)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:920)
at org.eclipse.ui.internal.WorkbenchPage$13.run(WorkbenchPage.j ava:3199)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3196)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3174)
org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHan dler.java:146)
org.eclipse.ui.handlers.ShowViewHandler.openOther(ShowViewHa ndler.java:102)
at org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHand ler.java:70)
at org.eclipse.ui.internal.ShowViewMenu$3.run(ShowViewMenu.java :113)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Chris Gross schrieb:
> Hi Guido,
> -Chris
> Guido Küpper wrote:
>> Chris,
>> Java 5, but want to play around with it also. How are your plans to
>> update the sample code?
>> all working with the StructuredViewer interface. By your sample code
>> for creating the grid it should be easily possible to do a GridViewer
>> based on the StructuredViewer interface, isn't it? (o.k., you may have
>> to adapt Content and LabelProvider also, and give the possibility to
>> use a _useful_ ColorProvider, but also that should be manageable).
>> Thanks in advance
>> Guido
>>> working now
>>> Thanks
>>> Paul
>>> Chris Gross wrote:
>>>> Hi Paul,
>>>> 1.5 jre.
>>>> Sorry,
>>>> -Chris
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Chris Gross wrote:
>>>>>> Hi Paul,
>>>>>> -Chris
>>>>>> Paul wrote:
>>>>>>> Greetings All
>>>>>>> What should I do with the nebula_grid.jar file?
>>>>>>> was unable to load class
>>>>>>> Thanks in advance
>>>>>>> Paul
Re: Nebula example error [message #6861 is a reply to message #6841] |
Wed, 19 July 2006 13:23  |
The Nebula example plugin is designed for Eclipse 3.2. The Nebula Grid
should work fine with Eclipse/SWT 3.1.
-Chris
Guido Küpper wrote:
> Hi Chris,
> Thanks in advance
> Guido
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Hi Guido,
>> Regards,
>> -Chris
>> Guido Küpper wrote:
>>> Chris,
>>> have to adapt Content and LabelProvider also, and give the
>>> possibility to use a _useful_ ColorProvider, but also that should be
>>> manageable).
>>> Thanks in advance
>>> Guido
>>>> working now
>>>> Thanks
>>>> Paul
>>>> Chris Gross wrote:
>>>>> Hi Paul,
>>>>> the original examples download and those changes are not complete.
>>>>> I will upload a new version in a week or so. Until then you'll
>>>>> need a 1.5 jre.
>>>>> Sorry,
>>>>> -Chris
>>>>>> following error. I'm doing something wrong.
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Chris Gross wrote:
>>>>>>> Hi Paul,
>>>>>>> is not necessary for the examples plugin to work (the nebula code
>>>>>>> is in the nebula plugin).
>>>>>>> -Chris
>>>>>>> Paul wrote:
>>>>>>>> Greetings All
>>>>>>>> Thanks in advance
>>>>>>>> Paul
Re: Nebula example error [message #562761 is a reply to message #5850] |
Thu, 29 June 2006 13:44  |
Hi Paul,
into the plugins directory. The nebula_grid.jar file is not necessary
for the examples plugin to work (the nebula code is in the nebula plugin).
-Chris
Paul wrote:
> Greetings All
> Thanks in advance
> Paul
Re: Nebula example error [message #562786 is a reply to message #5868] |
Fri, 30 June 2006 04:55  |
Thanks for the reply Chris. I have extracted both jars into the plugins
directory and restarted eclipse but still get the following error. I'm
version 49.0)
Chris Gross wrote:
> Hi Paul,
> -Chris
> Paul wrote:
>> Greetings All
>> Thanks in advance
>> Paul
Re: Nebula example error [message #562813 is a reply to message #5886] |
Fri, 30 June 2006 12:17  |
Hi Paul,
No this is my error. I unintentionally compiled the plugins with a 1.5
target (I assume you're using an older jre). I will post a new version
of the plugins with the target lowered but I can't do that right away.
I've made significant changes to Grid since I posted the original
examples download and those changes are not complete. I will upload a
Sorry,
-Chris
> version 49.0)
> at
> at
> at
> at
> at
> at
> at
> at
> Chris Gross wrote:
>> Hi Paul,
>> plugin).
>> -Chris
>> Paul wrote:
>>> Greetings All
>>> Thanks in advance
>>> Paul
Re: Nebula example error [message #562839 is a reply to message #5903] |
Tue, 04 July 2006 04:37  |
Paul
Chris Gross wrote:
> Hi Paul,
> Sorry,
> -Chris
>> version 49.0)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Chris Gross wrote:
>>> Hi Paul,
>>> nebula plugin).
>>> -Chris
>>> Paul wrote:
>>>> Greetings All
>>>> Thanks in advance
>>>> Paul
Re: Nebula example error [message #562890 is a reply to message #5920] |
Chris,
the sample code?
Thanks in advance
Guido
> Thanks
> Paul
> Chris Gross wrote:
>> Hi Paul,
>> Sorry,
>> -Chris
>>> version 49.0)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Chris Gross wrote:
>>>> Hi Paul,
>>>> nebula plugin).
>>>> -Chris
>>>> Paul wrote:
>>>>> Greetings All
>>>>> Thanks in advance
>>>>> Paul
Re: Nebula example error [message #562912 is a reply to message #5956] |
Guido
> Chris,
> the sample code?
> Thanks in advance
> Guido
>> now
>> Thanks
>> Paul
>> Chris Gross wrote:
>>> Hi Paul,
>>> 1.5 jre.
>>> Sorry,
>>> -Chris
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Chris Gross wrote:
>>>>> Hi Paul,
>>>>> -Chris
>>>>> Paul wrote:
>>>>>> Greetings All
>>>>>> Thanks in advance
>>>>>> Paul
Re: Nebula example error [message #562930 is a reply to message #5956] |
Hi Guido,
-Chris
Guido Küpper wrote:
> Chris,
> the sample code?
> Thanks in advance
> Guido
>> now
>> Thanks
>> Paul
>> Chris Gross wrote:
>>> Hi Paul,
>>> 1.5 jre.
>>> Sorry,
>>> -Chris
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Chris Gross wrote:
>>>>> Hi Paul,
>>>>> -Chris
>>>>> Paul wrote:
>>>>>> Greetings All
>>>>>> Thanks in advance
>>>>>> Paul
Re: Nebula example error [message #562983 is a reply to message #5992] |
Hi Chris,
Thanks in advance
Guido
> Hi Guido,
> -Chris
> Guido Küpper wrote:
>> Chris,
>> Thanks in advance
>> Guido
>>> working now
>>> Thanks
>>> Paul
>>> Chris Gross wrote:
>>>> Hi Paul,
>>>> 1.5 jre.
>>>> Sorry,
>>>> -Chris
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Chris Gross wrote:
>>>>>> Hi Paul,
>>>>>> -Chris
>>>>>> Paul wrote:
>>>>>>> Greetings All
>>>>>>> Thanks in advance
>>>>>>> Paul
Re: Nebula example error [message #563010 is a reply to message #6841] |
-Chris
Guido Küpper wrote:
> Hi Chris,
> Thanks in advance
> Guido
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Hi Guido,
>> Regards,
>> -Chris
>> Guido Küpper wrote:
>>> Chris,
>>> manageable).
>>> Thanks in advance
>>> Guido
>>>> working now
>>>> Thanks
>>>> Paul
>>>> Chris Gross wrote:
>>>>> Hi Paul,
>>>>> need a 1.5 jre.
>>>>> Sorry,
>>>>> -Chris
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Chris Gross wrote:
>>>>>>> Hi Paul,
>>>>>>> -Chris
>>>>>>> Paul wrote:
>>>>>>>> Greetings All
>>>>>>>> Thanks in advance
>>>>>>>> Paul
Current Time: Tue Jul 15 15:13:20 EDT 2025
Powered by FUDForum. Page generated in 0.64859 seconds
