Home » Language IDEs » ServerTools (WTP) » Default Server Option Doesn't Work
Default Server Option Doesn't Work [message #65438] Thu, 13 January 2005 11:07 Go to next message
Originally posted by: jrduncans.stephenduncanjr.com
Is anyone else having this problem? When I try to set the default
server for my J2EE Project, it never works. Whenever I go back in, it's
back to <None>. This is true whether I set it on the project
properties, or as the checkmark when using "Run on Server." I don't see
any error in the logs...
-Stephen Duncan Jr
Re: Default Server Option Doesn't Work [message #65479 is a reply to message #65438] Thu, 13 January 2005 19:10 Go to previous messageGo to next message
Hi Stephen,
Please open a bugzilla against the wst.server component and I will
investigate. Thanks.
Re: Default Server Option Doesn't Work [message #65562 is a reply to message #65479] Fri, 14 January 2005 07:00 Go to previous message
Tim deBoer wrote:
> Hi Stephen,
Ok, it's Bug 82836: https://bugs.eclipse.org/bugs/show_bug.cgi?id=82836
Stephen Duncan Jr
Previous Topic:Unable to have XML code completion wit M2
Next Topic:Example creation wizard
Current Time: Sun Jul 27 10:54:16 EDT 2025
Powered by FUDForum. Page generated in 0.03895 seconds
