Home » Archived » M2M (model-to-model transformation) » RCP feature/patch error installing ATL
RCP feature/patch error installing ATL [message #65397] Wed, 31 October 2007 18:42 Go to next message
Originally posted by: Geek4AllSeasons.hotmail.com
Installing ATL to an exist Eclipse installation the Update manager reports:
Eclipse RCP Patch 1 for 3.3.1 (3.3.1.v20071002_331) requires feature
"org.eclipse.rcp (3.3.1.R33x_r20070802-8y8eE8sEV3Fz0z0GlHJrXvTAUS)".
the update site is:
"download.eclipse.org/modeling/m2m/atl/updates/2.0.0"
The Product Configuration Report/dialogue shows the required feature is
disabled.
I found the following post with a workaround for the same error in the
eclipse.RCP list:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg26660.html
Any thoughts if this will work for ATL? Could it possibly break Eclipse?
If the feature is disabled is it possible and/or advisable to enable it?
Thanks.
david
Configuration Details:
*** Date: Wednesday, October 31, 2007 6:34:00 PM ET
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=I20070625-1500
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
E:\Software\Eclipse\Yoxos\3.3\\plugins\org.eclipse.platform_ 3.3.2.R33x_v20071022\splash.bmp
-launcher
E:\Software\Eclipse\Yoxos\3.3\eclipse.exe
-name
Eclipse
--launcher.library
E:\Software\Eclipse\Yoxos\3.3\plugins\org.eclipse.equinox.la uncher.win32.win32.x86_1.0.2.R331_v20071019\eclipse_1021.dll
-startup
E:\Software\Eclipse\Yoxos\3.3\plugins\org.eclipse.equinox.la uncher_1.0.1.R33x_v20070828.jar
-vm
E:\Software\Java\Sun\j2se\re\6.0_03\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1193862813805
eclipse.vm=E:\Software\Java\Sun\j2se\re\6.0_03\bin\client\jv m.dll
eclipse.vmargs=-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=E:\Software\Eclipse\Yoxos\3.3\plugins\org. eclipse.equinox.launcher_1.0.1.R33x_v20070828.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=E:\Software\Eclipse\Yoxos\3.3\plugins\org.ec lipse.equinox.launcher_1.0.1.R33x_v20070828.jar
java.class.version=50.0
java.endorsed.dirs=E:\Software\Java\Sun\j2se\re\6.0_03\lib\e ndorsed
java.ext.dirs=E:\Software\Java\Sun\j2se\re\6.0_03\lib\ext;C: \WINNT\Sun\Java\lib\ext
java.home=E:\Software\Java\Sun\j2se\re\6.0_03
java.io.tmpdir=C:\DOCUME~1\davidr\LOCALS~1\Temp\
java.library.path=E:\Software\Eclipse\Yoxos\3.3;.;C:\WINNT\S un\Java\bin;C:\WINNT\system32;C:\WINNT;E:\Software\Java\Sun\ j2se\re\6.0_03\bin\client;E:\Software\Java\Sun\j2se\re\6.0_0 3\bin;E:\Software\PHP\;E:\Software\Perl\site\bin;E:\Software \Perl\bin;E:\Software\Perl\bin;C:\WINNT\system32;C:\WINNT;C: \WINNT\System32\Wbem;E:\Software\GNU\W32\psutils\1.17\bin;C: \Program
Files\System Admin\bin;C:\Program Files\System Admin\Windows 2000\Support
Tools;C:\Program Files\System Admin\Windows 2000\Resource
Kit;E:\Software\bin;E:\Software\GNU\Emacs\emacs\bin;E:/Softw are/Perl\bin;E:\Software\PostgreSQL\8.2.4\bin;E:\Software\Ja va\bin;C:\Software\Open
Source\OpenJade\ver-1.3.1\bin;C:\Program Files\System Admin\Windows
2000\Support Tools;C:\Program
Files\QuickTime\QTSystem;E:\Software\Objective
Caml\bin;E:\Software\Java\Sun\j2ee\5.0\jdk\bin;E:\Software\J ava\Sun\j2ee\5.0\bin;C:\Program
Files\Pidgin\;C:\Program Files\Common Files\GNOME\GTK\2.0\bin\
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_03-b05
java.security.policy=/E:/Software/Eclipse/Yoxos/3.3/configur ation/org.eclipse.osgi/bundles/779/1/.cp/server.policy
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_03
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.6.0_03-b05
line.separator=
org.eclipse.equinox.launcher.splash.location=E:\Software\Ecl ipse\Yoxos\3.3\\plugins\org.eclipse.platform_3.3.2.R33x_v200 71022\splash.bmp
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows2000
org.osgi.framework.os.version=5.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w 3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c.dom. ls,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 2000
os.version=5.0
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=E:\Software\Eclipse\Yoxos\3.3\configuration \org.eclipse.osgi\bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/E:/Software/Eclipse/Yoxos/3.3/ configuration/
osgi.framework=file:/e:/Software/Eclipse/Yoxos/3.3/plugins/o rg.eclipse.osgi_3.3.1.R33x_v20070828.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.1.R33x_v20070828
osgi.install.area=file:/E:/Software/Eclipse/Yoxos/3.3/
osgi.instance.area=file:/E:/Projects/dev/workspace/3.3/
osgi.instance.area.default=file:/C:/Documents and
Settings/davidr/workspace/
osgi.logfile=E:\Projects\dev\workspace\3.3\.metadata\.log
osgi.manifest.cache=E:\Software\Eclipse\Yoxos\3.3\configurat ion\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=E:\Software\Eclipse\Yoxos\3.3\\plugins\o rg.eclipse.platform_3.3.2.R33x_v20071022\splash.bmp
osgi.splashPath=platform:/base/plugins/com.yoxos.distributio n
osgi.syspath=e:\Software\Eclipse\Yoxos\3.3\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=E:\Software\Java\Sun\j2se\re\6.0_03\lib\ resources.jar;E:\Software\Java\Sun\j2se\re\6.0_03\lib\rt.jar ;E:\Software\Java\Sun\j2se\re\6.0_03\lib\sunrsasign.jar;E:\S oftware\Java\Sun\j2se\re\6.0_03\lib\jsse.jar;E:\Software\Jav a\Sun\j2se\re\6.0_03\lib\jce.jar;E:\Software\Java\Sun\j2se\r e\6.0_03\lib\charsets.jar;E:\Software\Java\Sun\j2se\re\6.0_0 3\classes
sun.boot.library.path=E:\Software\Java\Sun\j2se\re\6.0_03\bi n
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.net.client.defaultConnectTimeout=60000
sun.net.client.defaultReadTimeout=60000
sun.os.patch.level=Service Pack 4
user.country=US
user.dir=E:\Software\Eclipse\Yoxos\3.3
user.home=C:\Documents and Settings\davidr
user.language=en
user.name=davidr
user.timezone=America/New_York
user.variant=
*** Features:
AnyEditTools (1.8.2) "AnyEdit Tools"
com.aptana.ide.feature (0.2.9.17048) "Aptana Web Development Tools"
com.aptana.ide.feature.editor.css (0.2.9.17048) "Aptana CSS Editor"
com.aptana.ide.feature.editor.html (0.2.9.17048) "Aptana HTML Editor"
com.aptana.ide.feature.editor.js (0.2.9.17048) "Aptana JavaScript Editor"
com.aptana.ide.feature.editors (0.2.9.17048) "Aptana Unified Editor"
com.atlassw.tools.eclipse.checkstyle (4.3.2) "Checkstyle Plug-in"
com.cb.eclipse.folding (1.0.6) "Coffee Bytes Code Folding"
com.dlsc.batik.feature (4.1.0) "Batik UI"
com.essiembre.eclipse.i18n.resourcebundle (0.7.5) "ResourceBundle Editor
Plug-in"
com.extjs.ext.1.0 (1.0.1.00003) "Aptana Support for EXT"
com.impart.framework (4.2.0) "Impart Framework Plug-in"
com.jquery.1.1 (1.1.3.00002) "Aptana Support for jQuery"
com.lowagie.itext (1.5.2.v20070705-1847) "Lowagie Itext"
com.mochikit.1.4 (1.4.0.00004) "Aptana Support for MochiKit"
com.neomalogic.solex (0.5.3.rc1) "Solex"
com.python.pydev.extensions (1.3.9) "Pydev Extensions"
com.robnewsome.eclipse.jarretriever (0.1.1) "Eclipse JarRetriever Plug-in"
com.something.eclipse.shelled (1.0.2) "Shell Script Development Tools"
com.soyatec.euml2.free (3.0.2.20071021) "eUML2 Free Edition"
com.yahoo.yui.2.2 (2.2.0.00003) "Aptana Support for Yahoo! User Interface"
com.yoxos.distribution (2.0.3) "Yoxos Internal Component"
com.yoxos.yim (2.3.0) "Yoxos Install Manager"
com.yoxos.yim.yfes (2.2.0) "Yoxos Feature Set"
csdl.jupiter (3.2.1) "Jupiter Review Plug-in"
de.fh.reutlingen.cap (1.2.0) "Code Analysis Plugin"
de.fhworms.ztt.encodingvalidatorfeature (1.0.1) "Encoding Validator Plugin"
de.frenzelsoft.tools (1.0.4) "FS Tools Plug-in"
de.java2html.eclipse (1.5.0) "Java2Html Eclipse Plug-in"
de.jave.eclipse.copyfully (1.1.0) "Copy Fully Qualified Class Name Plugin"
de.jave.eclipse.labeldecorator (1.0.2) "Universal Label Decorator"
de.jave.eclipse.searcheclipse (1.3.0) "SearchInEclipse Plugin"
de.leiffrenzel.fp.haskell (0.10.0) "EclipseFP: Haskell"
de.leiffrenzel.fp.haskell.source (0.10.0) "pluginName"
de.leiffrenzel.yellowcount (1.0.5) "YellowCount"
de.uka.ipd.coverage.featureproject (0.9.5.3) "Coverlipse"
eclipseme.feature (1.6.7) "EclipseME"
EclipseSkins (1.4.2.1) "Extended VS Presentation Plug-in"
edu.cmu.sei.osate-frontend (1.5.3) "Aadl OSATE"
edu.cmu.sei.osate-frontend.source (1.5.3) "pluginName"
edu.cmu.sei.osate-plugins (1.5.2) "Aadl OSATE"
edu.cmu.sei.osate-plugins.source (1.5.2) "pluginName"
edu.umd.cs.findbugs.plugin.eclipse (1.2.1.20070531) "FindBugs Plug-in"
FileSync (1.3.2) "FileSync Plug-in"
fr.obeo.acceleo (2.1.0.200707131240) "Acceleo Generator Ui Plug-in"
hudson.freemarker_ide (0.9.14) "FreeMarker IDE"
JDepend4Eclipse (1.2.1) "JDepend4Eclipse"
net.java.amateras.umleditor (1.2.1) "UML Plugin"
net.java.amateras.umleditor.xmi (1.2.1) "AmaterasUML XMI Support Plugin"
net.mootools.1.1 (1.1.1.00004) "Aptana Support for mootools"
net.orthanc.flow4j (1.0.4) "Flow4J Core"
net.orthanc.flow4j.flowdoc (1.0.4) "Flow4J Flowdoc"
net.sf.fjep.fatjar (0.0.25) "Fat Jar Plug-in"
net.sf.tm (0.7.2) "Tomcat Manager"
net.sf.versiontree (1.4.0) "CVS VersionTree Plug-in"
net.sourceforge.astreproduce.feature (0.1.0) "AST Reproduce Core Plug-in"
net.sourceforge.ehep (0.3.0) "Ehep Plug-in"
net.sourceforge.metrics (1.3.6) "metrics Plug-in"
net.sourceforge.pmd.eclipse (3.2.2) "PMD For Eclipse"
net.sourceforge.sqlexplorer (3.0.0) "SQLExplorer Plugin"
net.sourceforge.texlipse (1.1.0) "TeXlipse Plug-in"
net.trajano.eclipse.platform (3.2.0.4) "Eclipse Platform Extensions"
nu.psnet.quickimage (0.2.0) "QuickImage"
org.aflax.1.0 (1.0.0.00002) "Aptana Support for Aflax"
org.apache.batik (1.6.0.v20061222-1222-0842283444-3444) "Apache Batik"
org.apache.commons.codec (1.3.0.v20070907-02--w311817222849) "Apache
Commons Codec Plug-in"
org.apache.derby.core (10.1.2.1) "Apache Derby Core Plug-in for Eclipse"
org.dojotoolkit.dojo.0.4 (0.4.3.00004) "Aptana Support for Dojo Toolkit"
org.eclipse.ajdt (1.5.0.200706070619) "AspectJ Development Tools"
org.eclipse.ajdt.source (1.5.0.200706070619) "Eclipse AspectJ Development
Tools Source Code"
org.eclipse.birt (2.2.1.v20070709-8M7M7A3OP2Mz-yAItil64r9z0tw0) "Business
Intelligence and Reporting Tools"
org.eclipse.birt.chart (2.2.1.v20070709-797942epMxsxifpV0fIHD8tiM6p) "BIRT
Chart Framework"
org.eclipse.birt.chart.cshelp (2.2.1.r22x_v20070913-11--w31181736) "BIRT
Chart Context-sensitive Help"
org.eclipse.birt.chart.runtime (2.2.1.v20070718-7Y8l77MVg3v_6uC7shL5o)
"BIRT Chart Runtime"
org.eclipse.birt.cshelp (2.2.1.r22x_v20070913-11--w31181733) "BIRT
org.eclipse.birt.doc (2.2.1.v20070709-110-s332Aw31181_2_) "BIRT
Documentation"
org.eclipse.birt.example (2.2.1.v20070709-7C7C555QQ8JZTFDqAz0Hj) "BIRT
Example"
org.eclipse.birt.report.designer
(2.2.1.v20070709-7U7U7EB8R4y3DDSVyYpv9FacpRAm) "BIRT Report Designer"
org.eclipse.birt.report.runtime (2.2.1.v20070718-7U7U7EBz0-4X-6EZboQ_la)
"BIRT Report Runtime"
org.eclipse.buckminster.core.feature (0.1.0.v20070626) "Buckminster UI
Plug-in (Incubation)"
org.eclipse.buckminster.cvs.feature (0.1.0.v20070615) "Buckminster CVS
org.eclipse.buckminster.maven.feature (0.1.0.v20070529) "Buckminster Maven
org.eclipse.buckminster.p4.feature (0.1.0.v20070615) "Buckminster Perforce
UI Plug-in (Incubation)"
org.eclipse.buckminster.pde.feature (0.1.0.v20070615) "Buckminster PDE
org.eclipse.cdt (4.0.1.200709241202) "Eclipse C/C++ Development Tools"
org.eclipse.core.tools (1.4.0.200607141315) "Core Tools"
org.eclipse.cvs (1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D) "Eclipse CVS
Client"
org.eclipse.cvs.source (1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D)
"Eclipse CVS Client SDK"
org.eclipse.datatools.connectivity.feature (1.5.1.200709261) "Data Tools
Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.5.1.200709261)
"DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.5.1.200709261) "DTP Open
Data Access"
org.eclipse.datatools.doc.user (1.5.1.200710161) "Data Tools Platform User
Guide"
org.eclipse.datatools.enablement.apache.derby.feature (1.5.1.200709261)
"High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.5.1.200709261) "Eclipse Data
Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.5.1.200709261) "Eclipse
Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.5.1.200709261) "Eclipse
org.eclipse.datatools.enablement.jdbc.feature (1.5.1.200709261)
org.eclipse.datatools.enablement.msft.feature (1.5.1.200709261) "Eclipse
org.eclipse.datatools.enablement.mysql.feature (1.5.1.200709261) "Eclipse
org.eclipse.datatools.enablement.oda.designer.feature (1.5.1.200709261)
"Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.5.1.200709261) "Eclipse
Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.5.1.200709261) "Eclipse
org.eclipse.datatools.enablement.postgresql.feature (1.5.1.200709261)
"Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.5.1.200709261)
org.eclipse.datatools.intro (1.5.1.200709261) "Eclipse Data Tools Platform
Intro Plug-in"
org.eclipse.datatools.modelbase.feature (1.5.1.200709261) "Eclipse Data
Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sdk.feature (1.5.1.200709261) "Data Tools Platform
Source Code"
org.eclipse.datatools.sqldevtools.feature (1.5.1.200709261) "Eclipse Data
Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.dd.dsf.gdb (0.9.0.v20070615) "Debug Services Framework GDB
Core Plug-in"
org.eclipse.dltk.core (0.9.1.r09_v20070920-08O2E8AWjpkOySy5VAPB) "Eclipse
Dynamic Languages Toolkit (Incubation)"
org.eclipse.ecf.core (1.1.0.v20070908-1720) "Eclipse Communication
Framework (ECF)"
org.eclipse.ecf.examples (1.1.0.v20070908-1720) "ECF Collaboration
Examples"
org.eclipse.eclipsemonkey (1.0.0.200706060947) "Eclipse Monkey
(Incubation)"
org.eclipse.emf (2.3.1.v200709252135) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.1.v200709252135) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.1.v200709252135) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200709252135) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.3.0.v200709252135) "EMF Template Code
Generator UI"
org.eclipse.emf.common (2.3.0.v200709252135) "EMF Common"
org.eclipse.emf.common.ui (2.3.1.v200709252135) "EMF Common UI"
org.eclipse.emf.converter (2.3.1.v200709252135) "EMF Model Convert Support"
org.eclipse.emf.doc (2.3.1.v200709252135) "Eclipse Modeling Framework
(EMF) Programmers Guide"
org.eclipse.emf.ecore (2.3.1.v200709252135) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.0.v200709252135) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.1.v200709252135) "Sample Ecore Editor"
org.eclipse.emf.ecore.sdo (2.3.0.v200709252135) "EMF Service Data Objects
(SDO)"
org.eclipse.emf.ecore.sdo.doc (2.3.1.v200709252135) "EMF Service Data
Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.edit (2.3.0.v200709252135) "EMF Service Data
Objects (SDO) Edit Support"
org.eclipse.emf.ecore.sdo.editor (2.3.0.v200709252135) "EMF Service Data
Objects (SDO) Editor"
org.eclipse.emf.ecore.sdo.source (2.3.0.v200709252135) "EMF Service Data
Objects (SDO) Source"
org.eclipse.emf.edit (2.3.1.v200709252135) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.1.v200709252135) "EMF Edit UI"
org.eclipse.emf.examples (2.2.0.v200609210005) "Eclipse Modeling Framework
(EMF) Examples"
org.eclipse.emf.mapping (2.3.0.v200709252135) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.0.v200709252135) "Eclipse Modeling
Framework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200709252135) "Eclipse
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.0.v200709252135) "EMF Mapping UI"
org.eclipse.emf.ocl (1.1.1.v200709121956-1007w31181_232_67) "Object
Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.ocl.doc (1.1.0.v200706071450-10-7w311817182561) "Object
Constraint Language (OCL) 2.0 Compatibility API Documentation"
org.eclipse.emf.ocl.examples (1.1.0.v200706071450-32-9oA55P5M5P8GJ5)
"Object Constraint Language (OCL) 2.0 Examples"
org.eclipse.emf.ocl.examples.source (1.1.0.v200706071450) "Object
Constraint Language (OCL) 2.0 Examples Source"
org.eclipse.emf.ocl.source (1.1.1.v200709121956-1007w31181_232_67) "Object
Constraint Language (OCL) 2.0 Compatibility Source"
org.eclipse.emf.query (1.1.0.v200706071712-10-7w311817182823) "EMF Model
Query"
org.eclipse.emf.query.doc (1.1.0.v200706071712-21-8s733G3E4C5B76) "EMF
Model Query Documentation"
org.eclipse.emf.query.ocl (1.1.0.v200706071712-10-7w311817182823) "EMF
Model Query OCL Integration"
org.eclipse.emf.query.ocl.source (1.1.0.v200706071712-10-7w311817182823)
"EMF Model Query OCL Integration Source"
org.eclipse.emf.query.source (1.1.0.v200706071712-10-7w311817182823) "EMF
Model Query Source"
org.eclipse.emf.source (2.3.1.v200709252135) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.emf.teneo (0.8.0.v200709051239) "Plugin.name (Incubation)"
org.eclipse.emf.teneo.doc (0.8.0.v200709051239) "Plugin.name (Incubation)"
org.eclipse.emf.teneo.source (0.8.0.v200709051239) "Eclipse Modeling
Framework Technology (EMFT) Teneo Source"
org.eclipse.emf.transaction (1.1.1.v200708231948-208Z8s733G3G5C5I9D) "EMF
Model Transaction Core"
org.eclipse.emf.transaction.doc (1.1.0.v200706071723-208Y8s733G3E3G5G79)
"EMF Model Transaction Documentation"
org.eclipse.emf.transaction.source
(1.1.1.v200708231948-208Z8s733G3G5C5I9D) "EMF Model Transaction Source"
org.eclipse.emf.validation (1.1.1.v200708161445-318Z9oA55P5O6O8IC_) "EMF
Validation Framework Core"
org.eclipse.emf.validation.doc (1.1.0.v200706071520-21-8s733G3E4C5_88)
"EMF Validation Framework Documentation"
org.eclipse.emf.validation.ocl (1.1.0.v200706071520-10-7w311817182631)
"EMF Validation Framework OCL Integration"
org.eclipse.emf.validation.ocl.source
(1.1.0.v200706071520-10-7w311817182631) "EMF Validation Framework OCL
Integration Source"
org.eclipse.emf.validation.source (1.1.1.v200708161445-318Z9oA55P5O6O8IC_)
"EMF Validation Framework Source"
org.eclipse.emf.workspace (1.1.1.v200707252036-208Z8s733G3F5E6_8B) "EMF
Model Transaction Workbench Integration Core"
org.eclipse.emf.workspace.doc (1.1.0.v200706071723-10-7w311817182834) "EMF
Model Transaction Workbench Integration Documentation"
org.eclipse.emf.workspace.source (1.1.1.v200707252036-208Z8s733G3F5E6_8B)
"EMF Model Transaction Workbench Integration Source"
org.eclipse.eodm (0.9.1.v200710090302) "pluginName (Incubation)"
org.eclipse.eodm.doc (0.9.1.v200710090302) "Plugin.name (Incubation)"
org.eclipse.eodm.source (0.9.1.v200710090302) "EODM Source"
org.eclipse.equinox.source (3.3.1.R33x_r20070918-7n7LECgEKVsLIM1aGBO4b00)
"Equinox bundle source plug-in"
org.eclipse.gef (3.3.1.v20070814) "Graphical Editing Framework"
org.eclipse.gef.examples (3.3.1.v20070814) "Graphical Editing Framework
Examples Source"
org.eclipse.gef.sdk (3.3.1.v20070814) "Graphical Editing Framework
Developer Resources"
org.eclipse.gef.source (3.3.1.v20070814) "Graphical Editing Framework
org.eclipse.gmf (1.0.100.v20070921-0000-7d-ETjEYjiMWQYLSEejlRjypkm71)
"Graphical Modeling Framework"
org.eclipse.jdt (3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL)
"Eclipse Java Development Tools"
org.eclipse.jdt.source (3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL)
"Eclipse Java Development Tools SDK"
org.eclipse.jem (1.2.4.v200704181020--6zXJK0L0SE3a95) "Java EMF Model"
org.eclipse.jem.sdk (1.2.4.v200704140333-GIHlkYKbOQv_rA7) "Java EMF Model
SDK"
org.eclipse.jem.source (1.2.4.v200704181020--6zXJK0L0SE3a95) "Java EMF
Model Source"
org.eclipse.jet (0.8.1.v20070913-17E19oA55P5V_8) "Eclipse Modeling
Framework Technologies - JET (Incubation)"
org.eclipse.jet.doc (0.8.0.v20070913-07707w31181_31) "Eclipse Modeling
Framework Technologies - JET Documentation (Incubation)"
org.eclipse.jet.examples (0.8.0.v20070913-077-7w31181_24) "Eclipse
Modeling Framework Technologies - JET Examples (Incubation)"
org.eclipse.jet.source (0.8.1.v20070913) "Eclipse Model to Text - JET SDK"
org.eclipse.jpt.feature.source (1.0.1.v200709130000-77-5CYQCCz-D7LQCCCD)
"Dali Java Persistence API (JPA) Tools"
org.eclipse.jst (2.0.1.v200709110510-7B-68dDTNImaz0di_Tvks1JyDPVe) "J2EE
Standard Tools (JST)"
org.eclipse.jst.common_core.feature.source
(2.0.0.v200706041905-1007w311817231426) "J2EE Standard Tools - Common Core
Source"
org.eclipse.jst.enterprise_core.feature.source
(2.0.1.v200709130705-42Aq_kE77Y7gBHDE77) "J2EE Standard Tools - Enterprise
Core Source"
org.eclipse.jst.enterprise_ui.feature.source
(2.0.1.v200709130705-7b7_ErsEU6AXKM4z-H2OSyjeRYcY) "J2EE Standard Tools -
Enterprise UI Source"
org.eclipse.jst.sdk (2.0.1.v200709110510-7F-788fNWpoJCFladAFBfkeXa3lR)
"J2EE Standard Tools (JST)"
org.eclipse.jst.server_adapters.feature.source
(2.0.1.v200709110550-787KE8gDUUEF6F_KxpHEQ) "J2EE Standard Tools - Server
Adapters Source"
org.eclipse.jst.server_core.feature.source
(2.0.1.v200709110550-56CQ9rC7EK_UAblGAD2537) "J2EE Standard Tools - Server
Core Source"
org.eclipse.jst.server_ui.feature.source
(2.0.1.v200709110550-77-CR9yJXEkuiKVeQrclqTHQ3648) "J2EE Standard Tools -
Server UI Source"
org.eclipse.jst.web_core.feature.source
(2.0.200.v200709122200-7Q7AE7BEHhHegvh89ftNyC) "J2EE Standard Tools - Web
Core Source"
org.eclipse.jst.web_ui.feature.source
(2.0.1.v200709110605-7B1COCkuNa_RHevwkwAwi9_guOz-) "J2EE Standard Tools -
Web UI Source"
org.eclipse.jst.webpageeditor.feature.source
(1.0.1.v200709110605-3-29oA55P5V8A) "Web Page Editor Source"
org.eclipse.m2m.atl.engine (2.0.0) "ATLAS Transformation Language (ATL)"
org.eclipse.ocl (1.1.1.v200707131415-3209oA55P5N7F8JDH) "Object Constraint
Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.ocl.doc (1.1.0.v200706071450-21-8s733G3E3G5AC3) "Object
Constraint Language (OCL) 2.0 Documentation"
org.eclipse.ocl.source (1.1.1.v200707131415-3209oA55P5N7F8JDH) "Object
Constraint Language (OCL) 2.0 Source"
org.eclipse.ocl.uml (1.1.1.v200707131415-1007w311818242526) "OCL 2.0
Binding for UML"
org.eclipse.ocl.uml.source (1.1.1.v200707131415-1007w311818242526) "OCL
2.0 Binding for UML Source"
org.eclipse.pde (3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN) "Eclipse
Plug-in Development Environment"
org.eclipse.pde.source (3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN)
"Eclipse Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz) "Eclipse
Platform"
org.eclipse.platform.source (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS) "Eclipse
RCP"
org.eclipse.rcp.source (3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS)
"Eclipse RCP Plug-in Developer Resources"
org.eclipse.releng.tools (3.2.100.v20070122-32-7w31181523) "RelEng Plug-in"
org.eclipse.rse (2.0.1.v20070926-7D-58mJIkP9WAviqV7HBvSLC) "Remote System
Explorer End-User Runtime"
org.eclipse.rse.core (2.0.1.v20070926-7P-7BEB7sQRxSFkT) "Remote System
Explorer Core"
org.eclipse.rse.core.source (2.0.1.v20070926-7P-7BEB7sQRxSFkT) "Remote
System Explorer Core Source"
org.eclipse.rse.dstore (2.0.1.v20070926-7F-4DUUEF6FALu) "RSE DStore
Services"
org.eclipse.rse.dstore.source (2.0.1.v20070926-7F-4DUUEF6FALu) "RSE DStore
Services Source"
org.eclipse.rse.examples (2.0.0.v20070609-6--9oA55P5M7Q) "Remote System
Explorer Examples"
org.eclipse.rse.ftp (2.0.1.v20070926-7737__kE77Y7dDK4I7B) "RSE FTP Service"
org.eclipse.rse.ftp.source (2.0.1.v20070926-7737__kE77Y7dDK4I7B) "RSE FTP
Service Source"
org.eclipse.rse.local (2.0.1.v20070705-7_-2AgI99h9l9l) "RSE Local Services"
org.eclipse.rse.local.source (2.0.1.v20070705-7_-2AgI99h9l9l) "RSE Local
Services Source"
org.eclipse.rse.remotecdt (2.0.1.v20070926-4-18s733G3K5H) "Remote System
Explorer C/C++ Remote Debug Launcher"
org.eclipse.rse.sdk (2.0.1.v20070926-7J-77E7ZoHOP4inkX-oUe-z-wI6x) "Remote
System Explorer Extender SDK"
org.eclipse.rse.ssh (2.0.1.v20070926-78-2_kE77Y7cAW) "RSE SSH Services"
org.eclipse.rse.ssh.source (2.0.1.v20070926-78-2_kE77Y7cAW) "RSE SSH
Services Source"
org.eclipse.rse.telnet (2.0.1.v20070704-637AAgI99h9mBW4I7B) "RSE Telnet
Service"
org.eclipse.rse.telnet.source (2.0.1.v20070704-637AAgI99h9mBW4I7B) "RSE
Telnet Service Source"
org.eclipse.rse.tests (2.0.1.v20070926-6-19oA55P5SAG) "RSE Unit Tests"
org.eclipse.sdk (3.3.2.R33x_r20071022-7M7J7C_Mu2gop0b_GAwplOBhyuKO)
"Eclipse Project SDK"
org.eclipse.sdk.examples (3.1.200.v20070607-847XERgEE5Y56gOmWq8HKOG)
"Eclipse SDK Examples"
org.eclipse.team.extras (3.1.100.v20061012-7K3CF1UE77UABAS) "Eclipse FTP
and WebDAV Support"
org.eclipse.tm.discovery (2.0.0.v20070611-7J--E8McIJNJCPr) "Target
Management Service Discovery Engine"
org.eclipse.tm.terminal (1.0.1.v20070918-1-07w31181_38) "Target Management
Terminal Widget"
org.eclipse.tm.terminal.serial (1.0.1.v20070926-1-07w31181_37) "Target
Management Terminal Serial Connector"
org.eclipse.tm.terminal.ssh (1.0.1.v20070808-1-07w31181_1_) "Target
Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet (1.0.0.v20070609-1--7w31181716) "Target
Management Terminal Telnet Connector"
org.eclipse.tm.terminal.view (1.0.1.v20070918-1-07w31181_29) "Target
Management Terminal View"
org.eclipse.tptp.monitoring (4.4.1.v200707080100-7c7KEFJ7IYGHEHWXBQ5xe)
"TPTP Monitoring"
org.eclipse.tptp.monitoring.doc.user
(4.3.101.v200709261752-774Ai0r733G3K7E5GC7) "TPTP Monitoring Project
Documentation"
org.eclipse.tptp.monitoring.examples
(4.3.101.v200709261752-328Z-w31181_372863) "User examples for the TPTP
Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.instrumentation
(4.3.1.v200709261752-7A7921mA55P5VAM8PJA) "TPTP Instrumentation Monitoring
org.eclipse.tptp.monitoring.la.core
(4.4.1.v200707080100-7A78_91mA55P5S7N7_CE) "Monitoring Log Analyzer Core"
org.eclipse.tptp.monitoring.managedagent
(4.4.1.v200709261752-7E7D8c2hE77Y7gEUAYQE) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents
(4.4.1.v200709261752-330-w31181_372863) "JMX Managed Agent"
org.eclipse.tptp.monitoring.mx4j.jmx
(4.4.1.v200709261752-2-2-w31181_372863) "MX4J"
org.eclipse.tptp.monitoring.profile.server
(4.2.101.v200709261752-318Z-w31181_372863) "TPTP Profile On Server Logging
Utility"
org.eclipse.tptp.monitoring.report.birt
(4.4.1.v200707080100-7A798b1mA55P5V_P8KID) "BIRT Monitor Reports for TPTP
Branding Plugin"
org.eclipse.tptp.platform.analysis
(4.4.1.v200709191245-7E7_CI2hE77Y7gCaAOOK) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java
(4.4.100.v200709191245-777710r733G3K5K57AC) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine
(4.3.101.v200709261752-773CG0r733G3K7E5GC7) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core (4.4.1.v200707090100-8Q82ENLJEPilAlvO15vQb)
"TPTP Platform"
org.eclipse.tptp.platform.core.doc.user
(4.3.101.v200709261752-7A6CH1mA55P5VAM8PJA) "TPTP Platform Project
Documentation"
org.eclipse.tptp.platform.doc.user
(4.3.101.v200709261752-7A77CH08IIrT11IGIcOfKRIYPB) "TPTP Platform Project
Documentation"
org.eclipse.tptp.platform.examples
(4.3.101.v200709261752-328Z-w31181_372863) "TPTP Platform Examples"
org.eclipse.tptp.platform.instrumentation.ui
(4.2.1.v200709261752-320-w31181_372863) "Instrument Core UI"
org.eclipse.tptp.platform.integration.pde
(4.4.1.v200709261752-330-w31181_372863) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti (4.3.1.v200709261752-777710r733G3K7E5GC7)
"TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core
(4.3.101.v200707090100-328Z-w31181_2_2356) "Log Analysis Core"
org.eclipse.tptp.platform.lta (4.3.101.v200707090100-773Ai0r733G3K6H5BB_)
"TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit
(4.3.101.v200709261752-7E5EAY2hE77Y7gEUAYQE) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user
(4.3.101.v200709261752-318Z-w31181_372863) "Probekit User Documentation"
org.eclipse.tptp.platform.profile.server
(4.3.1.v200709261752-7E798c2hE77Y7gEUAYQE) "TPTP Profile on Server"
org.eclipse.tptp.platform.report
(4.2.101.v200709261752-7A5CH1mA55P5VAM8PJA) "TPTP Charting Service"
org.eclipse.tptp.platform.report.birt
(4.3.101.v200709261752-777710r733G3K7E5GC7) "BIRT Reporting for TPTP
Branding plugin"
org.eclipse.tptp.platform.samples
(4.3.101.v200709261752-7A4Dr1mA55P5VAM8PJA) "TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.report.birt
(4.4.1.v200709261752-777710r733G3K7E5GC7) "BIRT Statistical Reports for
TPTP Branding Plugin"
org.eclipse.tptp.platform.statistical.ui
(4.1.301.v200709261752-772CG0r733G3K7E5GC7) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace
(4.3.101.v200707090100-7E7AAk2hE77Y7gDXATPH) "TPTP Platform Trace"
org.eclipse.tptp.test (4.3.101.v200709261752-7I7ACJ3cI99h9rIcDhXI) "TPTP
Test"
org.eclipse.tptp.test.doc.user (4.3.101.v200709261752-320-w31181_372863)
"Test Tools User Documentation"
org.eclipse.tptp.test.report.birt
(4.3.101.v200709261752-7A7A21mA55P5VAM8PJA) "BIRT Test Reports for TPTP
Branding Plugin"
org.eclipse.tptp.test.samples (4.2.1.v200709261752-310-w31181_372863)
"TPTP Test Samples"
org.eclipse.tptp.test.tools
(4.3.101.v200709261752-7E7C31vNDHT9HNTErQiBN9QKB) "TPTP Test Tools"
org.eclipse.tptp.test.tools.junit
(4.4.1.v200709261752-7A7A21mA55P5VAM8PJA) "TPTP JUnit Plugin Test Tools"
org.eclipse.tptp.trace (4.2.1.v200709261752-771E9y0r733G3K7E5GC7) "TPTP
Trace"
org.eclipse.tptp.trace.arm (4.2.1.v200709261752-77210r733G3K7E5GC7) "TPTP
ARM Monitoring "
org.eclipse.tptp.trace.arm.ui (4.3.1.v200709261752-77510r733G3K7E5GC7)
"Instrument ARM UI"
org.eclipse.tptp.trace.jvmti (4.2.1.v200709261752-330-w31181_372863) "TPTP
Trace JVMTI Client"
org.eclipse.tptp.trace.report.birt
(4.4.1.v200709261752-7A7A21mA55P5VAM8PJA) "BIRT Trace Reports for TPTP
Branding Plugin"
org.eclipse.uml2 (2.1.1.v200708301222) "UML2"
org.eclipse.uml2.diagram (0.7.1.v200710010534) "UML2 Diagramming Plug-in
(Incubation)"
org.eclipse.uml2.diagram.source (0.7.1.v200710010534) "UML2 Diagramming
Source"
org.eclipse.uml2.doc (2.1.1.v200707181556) "UML2 Documentation"
org.eclipse.uml2.examples (2.1.0.v200706251652) "UML2 Examples"
org.eclipse.uml2.examples.source (2.1.0.v200706251652) "UML2 Examples
Source"
org.eclipse.uml2.source (2.1.1.v200708301222) "UML2 Source"
org.eclipse.uml2tools (0.7.1.v200710010534) "UML2 Tools Plug-in
(Incubation)"
org.eclipse.uml2tools.doc (0.7.0.v200710010534) "UML2 Tools Documentation
Plug-in"
org.eclipse.wst (2.0.1.v200709110510-7C-778k0JWNr93WEIHvplSVojWel) "Web
Standard Tools (WST)"
org.eclipse.wst.common_core.feature.source
(2.0.1.v200709110622-7C78EKGE_EkMNfNleyerlz) "Web Standard Tools - Common
Core Source"
org.eclipse.wst.common_ui.feature.source
(2.0.1.v200709110622-7C5EH2E9RvTVnijrspVz0bgOmfz-) "Web Standard Tools -
Common UI Source"
org.eclipse.wst.sdk (2.0.1.v200709110510-7E-788aNUivSRfjWLEcbxlUXG72x)
"Web Standard Tools (WST)"
org.eclipse.wst.server_core.feature.source
(2.0.1.v200709110637-2-CM8s733G3G5Jc) "Web Standard Tools - Server Core
Source"
org.eclipse.wst.server_ui.feature.source
(2.0.1.v200709110637-77-CU9vCXCjvdHL7ATINi447) "Web Standard Tools -
Server UI Source"
org.eclipse.wst.web_core.feature.source
(2.0.1.v200709111200-42CK_kE77Y7ZBNCQGG) "Web Standard Tools - Web Core
Source"
org.eclipse.wst.web_ui.feature.source
(2.0.1.v200709111200-7A0EAiCiWfGJsJZlAhE3TMaQW) "Web Standard Tools - Web
UI Source"
org.eclipse.wst.ws_core.feature.source
(2.0.1.v200709051445-7E7KEB0EC3wSU4Tuh9iKz) "Web Standard Tools - Web
Service Core Source"
org.eclipse.wst.ws_ui.feature.source
(2.0.1.v200709051445-791ECFAufYO8Az-ajoKBCFe8tVjL) "Web Standard Tools -
Web Service UI Source"
org.eclipse.wst.xml_core.feature.source
(2.0.1.v200709110650-787BE_1CYQCCz-CvRQLQSV) "Web Standard Tools - XML
Core Source"
org.eclipse.wst.xml_ui.feature.source
(2.0.1.v200709110650-7A1ECGCnbckz0bnr5wCp8KNAjipR) "Web Standard Tools -
XML UI Source"
org.eclipse.xsd (2.3.1.v200709252135) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.3.1.v200709252135) "XML Schema Infoset Model (XSD)
Programmers Guide"
org.eclipse.xsd.ecore.converter (2.3.1.v200709252135) "XML Schema Infoset
Model (XSD) - org.eclipse.xsd.ecore.converter"
org.eclipse.xsd.edit (2.3.0.v200709252135) "XML Schema Edit Framework"
org.eclipse.xsd.editor (2.3.0.v200709252135) "XML Schema Editor"
org.eclipse.xsd.mapping (2.3.0.v200709252135) "XML Schema Infoset Model
(XSD) - org.eclipse.xsd.mapping"
org.eclipse.xsd.mapping.editor (2.3.0.v200709252135) "XML Schema Infoset
Model (XSD) - org.eclipse.xsd.mapping.editor"
org.eclipse.xsd.source (2.3.1.v200709252135) "XML Schema Infoset Model
(XSD) Source"
org.eclipsedesktop.base (0.8.0) "Eclipsedesktop Base"
org.eclipsedesktop.beam (0.0.3) "Beam Plug-in"
org.eclipsedesktop.examem (0.8.0) "Examine Memory"
org.eclipsedesktop.monitorcenter (0.8.0) "Monitor Center"
org.eclipsedesktop.packer (0.9.1) "Packer"
org.eclipsedesktop.weblookup (0.8.1) "Web Lookup"
org.emonic.base (0.1.2) "Emonic Plug-in"
org.epic.feature.main (0.5.37) "Perl Editor Plug-in"
org.gna.eclox (0.6.5) "Eclox Branding Information"
org.gna.eclox.doxygen (1.5.3) "Eclox Branding Information"
org.jfree.chart (1.0.0) "JFreeChart Plug-in"
org.maven.ide.eclipse.feature (0.0.10) "Maven 2.0 integration"
org.mozilla.rhino (1.6.0.v20070406-05--w31181821) "Rhino Javascript
Plug-in"
org.muermann.gotofile (1.3.5) "GotoFile Plugin"
org.openarchitectureware.adapter.gmf.feature (4.2.0.200709162219NGT)
"openArchitectureWare GMF Adapter"
org.openarchitectureware.adapter.gmf.feature.source
(4.2.0.200709162219NGT) "openArchitectureWare GMF Adapter Source"
org.openarchitectureware.adapter.rsdp.feature (4.2.0.200709162219NGT)
"openArchitectureWare RSDP Adapter plugin"
org.openarchitectureware.adapter.rsdp.feature.source
(4.2.0.200709162219NGT) "openArchitectureWare RSDP Adapter Source"
org.openarchitectureware.classic.feature.source (4.1.2.v20070314)
"pluginName"
org.openarchitectureware.core.feature (4.2.0.200709162219NGT)
"openArchitectureWare core expressions"
org.openarchitectureware.core.feature.source (4.2.0.200709162219NGT)
"openArchitectureWare core Source"
org.openarchitectureware.lib.feature (4.2.0.200709162219NGT) "ANTLR
Runtime Plug-in"
org.openarchitectureware.plugins.feature (4.2.0.200709162219NGT)
"openArchitectureWare core plugin"
org.openarchitectureware.plugins.feature.source (4.2.0.200709162219NGT)
"openArchitectureWare oaw plugins Source"
org.openarchitectureware.recipe.feature (4.2.0.200709162219NGT)
"openArchitectureWare recipe plugin"
org.openarchitectureware.recipe.feature.source (4.2.0.200709162219NGT)
"openArchitectureWare recipe Source"
org.openarchitectureware.sdk.feature (4.2.0.200709162219NGT)
"openArchitectureWare User Guide"
org.openarchitectureware.uml2.adapter (4.2.0.200709162219NGT)
"openArchitectureWare UML2 Adapter"
org.openarchitectureware.uml2.adapter.source (4.2.0.200709162219NGT)
"openArchitectureWare UML2 Adapter Source"
org.openarchitectureware.util.ple_feature (4.2.0.200709162219NGT)
"Featureconfig Model"
org.openarchitectureware.util.stdlib.feature (4.2.0.200709162219NGT)
"openArchitectureWare Standart libraries"
org.openarchitectureware.util.stdlib.feature.source
(4.2.0.200709162219NGT) "openArchitectureWare stdlib Source"
org.openarchitectureware.util.uml2ecore.feature (4.2.0.200709162219NGT)
"openArchitectureWare UML 2 Ecore"
org.openarchitectureware.util.uml2ecore.feature.source
(4.2.0.200709162219NGT) "openArchitectureWare uml2Ecore Adapter Source"
org.openarchitectureware.xtext.feature (4.2.0.200709162219NGT)
"openArchitectureWare xtext ui"
org.openarchitectureware.xtext.feature.source (4.2.0.200709162219NGT)
"openArchitectureWare Xtext Source"
org.openrico.rico.2.0 (2.0.0.00002) "Aptana Support for Rico"
org.prototypejs.prototype.1.5 (1.5.0.00002) "Aptana Support for Prototype"
org.python.pydev.feature (1.3.9) "Pydev - Python Development Environment"
org.radrails.rails_feature (0.8.0.200707021211) "RadRails IDE"
org.rubypeople.rdt (0.9.0.707021729NGT) "Ruby Development Tools"
org.rubypeople.rdt.source (0.9.0.705141801NGT) "pluginName"
org.scriptaculous.1.7 (1.7.0.00005) "Aptana Support for Scriptaculous"
org.sf.easyexplore (1.0.4) "Easy Explore Plugin"
org.testng.eclipse (5.5.0.1) "TestNG Eclipse Support"
org.tigris.jira (0.9.2) "Jira Dashboard"
org.tigris.jira.core (0.9.3) "Jira Core Plug-in"
org.tigris.subversion.subclipse (1.2.4) "SVN Team Provider Core"
org.topcased.experimental (1.0.0.v200709241920) "Topcased Experimental"
org.topcased.experimental.source (1.0.0.v200709241920) "Topcased
Experimental Source"
org.topcased.modeler.aadl (1.0.0.v200709241920) "AADL Editor"
org.topcased.modeler.ecore (1.0.0.v200709241920) "Ecore Editor"
org.topcased.modeler.sam (1.0.0.v200709241920) "SAM Editor"
org.topcased.modeler.uml (1.0.0.v200709241920) "UML Editor"
org.topcased.sdk (1.0.0.v200709241920) "Topcased SDK"
org.topcased.sysml (1.0.0.v200709241920) "SysML Model"
org.topcased.toolkit (1.0.0.v200709241920) "Topcased Toolkit"
org.topcased.toolkit.source (1.0.0.v200709241920) "Topcased Source"
org.w3c.sac (1.3.0.v20070406-02--w31181821) "W3C Sac"
sf.eclipse.javacc.feature (1.5.10) "JavaCC Plug-in"
ssh (1.0.0) "Ssh Plug-in"
*** Plug-in Registry:
byecycle (0.1.0) "Byecycle Plug-in" [Starting]
ca.ecliptical.emf.xpath (1.0.0) "EMF XPath Plug-in" [Starting]
ca.ubc.cs.javadb (1.3.1) "JavaDB" [Resolved]
ca.uvic.csr.shrimp (1.3.1) "SHriMP" [Resolved]
ca.uvic.csr.shrimp.creole (1.3.1) "Creole" [Starting]
ca.uvic.csr.shrimp.eclipsebridge (1.3.1) "SHriMP Eclipse Bridge Plugin"
[Starting]
ch.graftec.classcycle.plugin.ClassyclePlugin (1.1.1) "ClassyclePlugin"
[Starting]
ch.mimo.eclipse.plugin.logfiletools.Logfileview (1.4.1) "Log File View"
[Starting]
com.adobe.spry.1.5 (1.5.0.00002) "Aptana Support for Adobe Spry" [Resolved]
com.aptana.ide.branding (0.2.9.17048) "Aptana Web Development Tools"
[Resolved]
com.aptana.ide.core (0.2.9.17048) "Aptana Core" [Active]
com.aptana.ide.core.ui (0.2.9.17048) "Aptana User Interface" [Active]
com.aptana.ide.core.win32 (0.2.9.17048) "Aptana Core Win32" [Resolved]
com.aptana.ide.debug.core (0.2.9.17048) "Aptana Debugging Tools" [Starting]
com.aptana.ide.debug.ui (0.2.9.17048) "Aptana Debugging Tools" [Starting]
com.aptana.ide.documentation (0.2.9.17048) "Aptana Documentation"
[Starting]
com.aptana.ide.editor.css (0.2.9.17048) "Aptana CSS Editor" [Starting]
com.aptana.ide.editor.erb (0.2.8.200707021211) "Aptana ERB/RHTML Editor"
[Starting]
com.aptana.ide.editor.html (0.2.9.17048) "Aptana HTML Editor" [Starting]
com.aptana.ide.editor.js (0.2.9.17048) "Aptana JavaScript Editor"
[Starting]
com.aptana.ide.editor.php (0.2.9.17048) "Aptana PHP Editor" [Starting]
com.aptana.ide.editor.text (0.2.9.17048) "Aptana Generic Text Editor"
[Starting]
com.aptana.ide.editor.xml (0.2.9.17048) "Aptana XML Editor" [Starting]
com.aptana.ide.editors (0.2.9.17048) "Aptana Unified Editor" [Starting]
com.aptana.ide.editors.codeassist (0.2.9.17048) "Aptana Unified Editor"
[Starting]
com.aptana.ide.epl (0.2.9.17048) "Aptana Eclipse Code" [Starting]
com.aptana.ide.extras (0.2.9.17048) "Aptana IDE Extras" [Starting]
com.aptana.ide.internet.proxy (0.2.9.17048) "Internet Proxy Preferences"
[Starting]
com.aptana.ide.intro (0.2.9.17048) "Aptana Intro" [Starting]
com.aptana.ide.io.file (0.2.9.17048) "Aptana File System Support" [Active]
com.aptana.ide.lexer (0.2.9.17048) "Aptana Lexer" [Starting]
com.aptana.ide.libraries (0.2.9.13370) "Aptana Libraries" [Resolved]
com.aptana.ide.libraries.internal (0.2.9.11838) "Aptana Internal
com.aptana.ide.parsing (0.2.9.17048) "Aptana Parsing" [Starting]
com.aptana.ide.regex (0.2.9.17048) "Aptana Regular Expressions" [Starting]
com.aptana.ide.samples (0.2.9.17048) "Aptana Samples View" [Starting]
com.aptana.ide.scripting (0.2.9.17048) "Aptana Scripting" [Starting]
com.aptana.ide.server.core (0.2.9.17048) "Aptana Server Core" [Starting]
com.aptana.ide.server.ui (0.2.9.17048) "Aptana Server User Interface"
[Starting]
com.aptana.ide.snippets (0.2.9.17048) "Aptana Snippets View" [Starting]
com.aptana.ide.syncing (0.2.9.17048) "Aptana Synchronization Core" [Active]
com.aptana.ide.syncing.ftp (0.2.9.17048) "Aptana FTP Synchronization
Provider" [Starting]
com.aptana.ide.update (0.2.9.17048) "Aptana Updates" [Starting]
com.aptana.rdt (0.9.0.707021729NGT) "Aptana RDT Extensions" [Starting]
[Starting]
com.cb.eclipse.folding (1.0.6) "Coffee Bytes Code Folding" [Starting]
com.csc.dip.projectset (2.6.1) "Projectset Plug-in" [Active]
com.csc.dip.projectset.nl1 (2.6.1) "Projectset NL Support" [Resolved]
com.csc.dip.projectset.ui (2.6.1) "Projectset UI Plug-in" [Active]
com.csc.dip.projectset.ui.nl1 (2.6.1) "Projectset UI NL Support" [Resolved]
com.dlsc.batik (4.1.0) "Batik" [Starting]
com.dlsc.batik.ui (4.1.0) "Batik UI" [Starting]
Plug-in" [Starting]
com.extjs.ext.1.0 (1.0.1.00003) "Aptana Support for EXT" [Resolved]
com.google.abreslav.epexplorer (1.0.0) "Extension Explorer Plug-in"
[Starting]
com.hudson.hibernatesynchronizer (3.1.9) "Hibernate Synchronizer"
[Starting]
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Starting]
com.ibm.icu (3.6.1.v20070906) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.6.1.v20070906) "International Components for Unicode
for Java (ICU4J) source plug-in" [Resolved]
com.ibm.mtf.core (1.0.2) "IBM Model Transformation Framework Core"
[Starting]
com.ibm.mtf.core.edit (1.0.2) "IBM Model Transformation Framework Core
Edit" [Starting]
com.ibm.mtf.doc (1.0.2) "IBM Model Transformation Framework documentation"
[Starting]
com.ibm.mtf.engine (1.0.2) "IBM Model Transformation Framework Engine"
[Resolved]
com.ibm.mtf.jdt (1.0.2) "IBM Model Transformation Framework JDT Support"
[Starting]
com.ibm.mtf.launch (1.0.2) "IBM Model Transformation Framework Launch UI"
[Starting]
com.ibm.mtf.mappings.ui (1.0.2) "IBM Model Transformation Framework
Mappings Viewer" [Starting]
com.ibm.mtf.relations.editor (1.0.2) "IBM Model Transformation Framework
Editor" [Starting]
com.ibm.mtf.relations.parser (1.0.2) "IBM Model Transformation Framework
Parser" [Starting]
com.ibm.mtf.report (1.0.2) "IBM Model Transformation Framework Report
Generator Model" [Starting]
com.ibm.mtf.uml2 (1.0.2) "IBM Model Transformation Framework UML2 Support"
[Starting]
com.ibm.mtf.utils (1.0.2) "IBM Model Transformation Framework Utilities"
[Starting]
com.ibm.mtf.xsd (1.0.2) "IBM Model Transformation Framework XSD Support"
[Starting]
com.ibmdb2.driver (0.3.1) "IBM DB2 Driver Plug-in" [Resolved]
com.impart.framework (4.2.0) "Impart Framework Plug-in" [Starting]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
com.jquery.1.1 (1.1.3.00002) "Aptana Support for jQuery" [Resolved]
com.lowagie.itext (1.5.2.v20070705-1847) "Lowagie Itext" [Resolved]
com.metys.merlin.generation.doc (0.5.0) "Merlin Generator Online Help"
[Starting]
com.metys.merlin.generation.examples.uml22ecore (0.5.0) "Uml2 2 Ecore
Sample" [Starting]
com.metys.merlin.generation.examples.uml2codegen (0.5.0) "Uml2 Code
Generation Sample" [Starting]
com.metys.merlin.generation.gef (0.5.0) "Merlin Generation Gef Model"
[Starting]
com.metys.merlin.generation.gef.ui (0.5.0) "Merlin Generation Gef Edit
Support" [Starting]
com.metys.merlin.generation.mapping (0.5.0) "Merlin Model Mapping"
[Starting]
com.metys.merlin.generation.mapping.ui (0.5.0) "Merlin Model Mapping UI"
[Starting]
com.metys.merlin.generation.templates (0.5.0) "Merlin JET Templates Model"
[Starting]
com.metys.merlin.generation.templates.ui (0.5.0) "Merlin JET Templates
Model UI" [Starting]
com.mochikit.1.4 (1.4.0.00004) "Aptana Support for MochiKit" [Resolved]
com.mysql.driver (0.5.1) "MySQL Driver Plug-in" [Resolved]
com.neomalogic.solex (0.5.3.rc1) "Solex" [Starting]
com.neomalogic.solex.ydoc (0.5.3.rc1) "Solex - Yoxos doc" [Starting]
com.oracle.driver (0.3.1) "Oracle Driver Plug-in" [Resolved]
com.python.pydev (1.3.9) "Pydev Extensions" [Starting]
com.python.pydev.analysis (1.3.9) "Analysis Plug-in" [Starting]
com.python.pydev.codecompletion (1.3.9) "Codecompletion Plug-in" [Starting]
com.python.pydev.debug (1.3.9) "Extensions Debug Plug-in" [Starting]
com.python.pydev.fastparser (1.3.9) "Fastparser Plug-in" [Starting]
com.python.pydev.refactoring (1.3.9) "Refactoring Plug-in" [Starting]
com.quantum.dbunit (3.0.7) "QuantumDB DbUnit Plug-in" [Starting]
com.quantum.flatfiles (3.0.7) "QuantumDB Data Export-Import Plug-in"
[Starting]
com.quantum.help (3.0.7) "Help Plug-in" [Starting]
com.quantum.Quantum (3.0.7) "Quantum DB Utility" [Starting]
[Starting]
com.rohanclan.cfml (1.1.17.2) "CFML Plug-in" [Starting]
com.simontuffs.eclipse.jarlaunch (0.5.1) "JarLaunch" [Starting]
com.simontuffs.eclipse.jarplug (0.6.1) "JarPlug" [Starting]
com.something.eclipse.script (1.0.6) "Script Plugin" [Starting]
com.something.eclipse.shelled (1.0.1) "Shell Script Development Tools"
[Resolved]
com.something.eclipse.shelled.resources (1.0.3) "ShellEd Resources"
[Starting]
com.something.eclipse.shelled.ui (1.0.3) "ShellEd UI" [Starting]
com.soyatec.additional (2.4.1.20071021) "Additional Elements Plugin"
[Starting]
com.soyatec.core (2.4.1.20071021) "Core Plugin" [Starting]
com.soyatec.diagrams (2.4.1.20071021) "Diagram tools Plugin" [Starting]
com.soyatec.euml2.free (3.0.2.20071021) "eUML2 Free Edition" [Resolved]
com.soyatec.model (2.4.1.20071021) "Open Model Plugin" [Starting]
com.sqlserver.driver (0.3.1) "SQL Server Driver Plug-in" [Resolved]
com.useit.eclipse.plugin.javagenerator (0.5.0) "JavaGenerator Plug-in"
[Starting]
com.useit.eclipse.plugin.javagenerator.helper (0.5.0) "Helper Plug-in"
[Starting]
com.useit.eclipse.plugin.javagenerator.useitGeneratorModel (0.5.0)
"UseitGeneratorModel Model" [Starting]
com.useit.eclipse.plugin.javagenerator.useitGeneratorModel.e dit (0.5.0)
"UseitGeneratorModel Edit Support" [Starting]
com.useit.eclipse.plugin.javagenerator.useitGeneratorModel.e ditor (0.5.0)
"UseitGeneratorModel Editor" [Starting]
com.useit.eclipse.plugin.javagenerator.useitgenmodel (0.5.0) "Use-it
Genmodel Model" [Starting]
[Resolved]
com.yoxos.distribution (2.0.3) "Yoxos Internal Component" [Starting]
com.yoxos.yan.core (2.3.0) "Yoxos Analyzer Core" [Starting]
com.yoxos.yim (2.3.0) "Yoxos Install Manager" [Starting]
com.yoxos.yim.core (2.3.0) "Yoxos Install Manager - Core" [Starting]
com.yoxos.yim.doc.user (2.3.0) "Yoxos Install Manager - User
Documentation" [Resolved]
com.yoxos.yim.ui (2.3.0) "Yoxos Install Manager - UI" [Starting]
com.yoxos.yim.ui.yeifragment (2.3.0) "Yoxos Install Manager - Eclipse
Integration" [Resolved]
com.yoxos.yim.yfes (2.2.0) "Yoxos Feature Set" [Resolved]
com.yoxos.yim.yfes.win32.win32.x86 (2.2.0) "Yoxos Feature Set
(win32.win32.x86)" [Resolved]
com.yoxos.yop.core (2.0.3) "Yoxos Outpost Core" [Starting]
csdl.jupiter (3.2.1) "Jupiter Review Plug-in" [Starting]
de.babe.eclipse.plugins.MultiClipboard (2.1.1) "MultiClipboard Plug-in"
[Active]
de.babe.eclipse.plugins.QuickREx (3.2.1) "QuickREx Plug-in" [Starting]
de.babe.eclipse.plugins.tinyHTMLTools (1.1.1) "tiny HTML Tools Plug-in"
[Starting]
de.babe.eclipse.plugins.XPathDeveloper (1.0.1) "XPathDeveloper Plug-in"
[Starting]
de.fh.reutlingen.cap (1.2.0) "Code Analysis Plugin" [Starting]
de.fh.reutlingen.cap.core (1.2.0) "Code Analysis Plugin - core" [Resolved]
de.fh.reutlingen.cap.core.eclipse (1.2.0) "Code Analysis Plugin -
core.eclipse" [Starting]
de.fh.reutlingen.cap.ui (1.2.0) "Code Analysis Plugin" [Resolved]
de.fh.reutlingen.cap.yhelp (1.2.0) "Code Analysis Plugin - Yoxos doc"
[Starting]
de.fhworms.ztt.encodingvalidator (1.0.1) "Encoding Validator Plugin"
[Starting]
de.frenzelsoft.tools (1.0.4) "FS Tools Plug-in" [Starting]
de.frenzelsoft.tools.appstage (1.0.4) "Application Starter Generator"
[Starting]
de.guhsoft.jinto.core (0.10.7) "JInto Core" [Starting]
de.g
Re: [ATL] RCP feature/patch error installing ATL [message #65659 is a reply to message #65397] Fri, 02 November 2007 07:21 Go to previous messageGo to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi David,
Normally, there is no dependency between Eclipse RCP & ATL.
I suppose you will have more clues from eclipse.rcp newsgroup concerning
your problem.
You can try to install ATL by using the binaries build version. I think
it will be easier than the workaround from the eclipse.rcp list.
Freddy.
David Ross a écrit :
> the update site is:
> disabled.
> eclipse.RCP list:
> Thanks.
> david
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> -launcher
> -name
> Eclipse
> --launcher.library
> -startup
> -vm
> -Xmx256m
> eof=eof
> file.separator=\
> 2000\Support Tools;C:\Program Files\System Admin\Windows 2000\Resource
> line.separator=
h.kerberos,javax.security.auth.login,javax.security.auth.spi ,javax.security.auth.x500,javax.security.cert,javax.security .sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.samp led,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax .sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.sw ing.border,javax.swing.colorchooser,javax.swing.event,javax. swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,ja vax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf .synth,javax.swing.table,javax.swing.text,javax.swing.text.h tml,javax.swing.text.html.parser,javax.swing.text.rtf,javax. swing.tree,javax.swing.undo,javax.tools,javax.transaction,ja vax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.a nnotation,javax.xml.bind.annotation.adapters,javax.xml.bind. attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax. xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax. xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml. crypto.dsig.spec,javax.xml.dat
atype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,j avax.xml.stream,javax.xml.stream.events,javax.xml.stream.uti l,javax.xml.transform,javax.xml.transform.dom,javax.xml.tran sform.sax,javax.xml.transform.stax,javax.xml.transform.strea m,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,jav ax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,j avax.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA, org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.D ynAnyPackage,org.omg.CORBA..ORBPackage,org.omg.CORBA.portabl e,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.Co sNaming.NamingContextExtPackage,org.omg.CosNaming.NamingCont extPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.Dynami cAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,o rg.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.Codec Package,org.omg.Messaging,org.omg.PortableInterceptor,org.om g.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableSer ver,org.omg.PortableServer.Curr
entPackage,org.omg.PortableServer.POAManagerPackage,org.omg. PortableServer.POAPackage,org.omg.PortableServer.portable,or g.omg.PortableServer.ServantLocatorPackage,org.omg.SendingCo ntext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstra p,org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax. ext,org.xml.sax.helpers
> os.arch=x86
> os.version=5.0
> osgi.arch=x86
> osgi.nl=en_US
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> i386 i86
> sun.desktop=windows
> user.country=US
> user.language=en
> user.name=davidr
> user.variant=
> *** Features:
> Plug-in"
> Development Tools Source Code"
> "Business Intelligence and Reporting Tools"
> "BIRT Chart Framework"
> Documentation"
> Example"
> Maven Plug-in (Incubation)"
> Perforce UI Plug-in (Incubation)"
> Client"
> (1.5.1.200709261) "DTP ODA Designer UI Framework Plug-in"
> Open Data Access"
> User Guide"
> Platform Intro Plug-in"
> Source Code"
> Data Tools Platform SQL Tools Common UI Plug-in"
> Core Plug-in"
> "Eclipse Dynamic Languages Toolkit (Incubation)"
> Framework (ECF)"
> Examples"
> (Incubation)"
> Generation"
> Generation UI"
> Generator UI"
> Objects (SDO)"
> Framework (EMF) Examples"
> "Object Constraint Language (OCL) 2.0 Compatibility Source"
> Query"
> "EMF Model Query Source"
> (EMF) Source"
> "EMF Model Transaction Core"
> Integration Source"
> (1.1.1.v200708161445-318Z9oA55P5O6O8IC_) "EMF Validation Framework Source"
> "EMF Model Transaction Workbench Integration Documentation"
> (1.1.1.v200707252036-208Z8s733G3F5E6_8B) "EMF Model Transaction
> (3.3.1.R33x_r20070918-7n7LECgEKVsLIM1aGBO4b00) "Equinox bundle source
> plug-in"
> Examples Source"
> (3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL) "Eclipse Java
> Model SDK"
> Model Source"
> Core Source"
> Enterprise Core Source"
> - Enterprise UI Source"
> Server Adapters Source"
> Server Core Source"
> - Server UI Source"
> Web Core Source"
> - Web UI Source"
> Constraint Language (OCL) 2.0 Parser/Interpreter"
> Binding for UML"
> "Eclipse Platform"
> RCP"
> System Explorer End-User Runtime"
> Explorer Core"
> Services"
> DStore Services Source"
> Explorer Examples"
> FTP Service Source"
> Services Source"
> "Remote System Explorer Extender SDK"
> Services Source"
> Service"
> and WebDAV Support"
> Management Terminal Widget"
> "TPTP Monitoring"
> Documentation"
> Monitoring "
> Logging Utility"
> (4.4.1.v200707090100-8Q82ENLJEPilAlvO15vQb) "TPTP Platform"
> Documentation"
> Project Documentation"
> (4.3.1.v200709261752-777710r733G3K7E5GC7) "TPTP JVMTI Profiler Client"
> (4.3.101.v200707090100-773Ai0r733G3K6H5BB_) "TPTP Log and Trace Analyzer"
> Branding plugin"
> Test"
> Branding Plugin"
> "TPTP Test Samples"
> Trace"
> "TPTP ARM Monitoring "
> "Instrument ARM UI"
> "TPTP Trace JVMTI Client"
> Branding Plugin"
> (Incubation)"
> Source"
> Source"
> (Incubation)"
> Documentation Plug-in"
> Common Core Source"
> Common UI Source"
> Source"
> Server UI Source"
> Source"
> Web UI Source"
> Core Source"
> XML UI Source"
> (XSD) Programmers Guide"
> Infoset Model (XSD) - org.eclipse.xsd.ecore.converter"
> (XSD) Source"
> Plug-in"
> "pluginName"
> Runtime Plug-in"
> [Starting]
> [Starting]
> [Starting]
> [Resolved]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> Plug-in" [Starting]
> [Starting]
> [Starting]
> Unicode for Java (ICU4J) source plug-in" [Resolved]
> [Starting]
> Edit" [Starting]
> documentation" [Starting]
> [Resolved]
> [Starting]
> UI" [Starting]
> Editor" [Starting]
> Parser" [Starting]
> Support" [Starting]
> [Starting]
> [Starting]
> [Starting]
> Sample" [Starting]
> [Starting]
> Support" [Starting]
> [Starting]
> [Starting]
> Model" [Starting]
> com.neomalogic.solex.ydoc (0.5.3.rc1) "Solex - Yoxos doc&quo
Re: [ATL] RCP feature/patch error installing ATL [message #65704 is a reply to message #65659] Sat, 03 November 2007 19:17 Go to previous message
Hi Freddy,
Thanks for responding. If the binary version has the same dependencies
that wouldn't solve the problem. However, you wouldn't be making the
suggestion if that were the case. My ignorance of the Update Manager
installation process maybe showing.
I was left to my own devices long enough to find another approach. I've
installed the source from CVS and successfully exported the ATL and AM3
plug-ins.
It was surprisingly easy. The instructions were good. I have a suggestion
for a minor change. The "ADT is ready to be tested ..." paragraph (and
bullets) should appear after the Export dialog figure.
This was my first time building a plug-in from source. I was lost
searching for non-existent Run-time launch configurations and a "plugin"
directory until I figured out that the Export process had to come first.
I'm about to launch a Run-time workbench to test them. It is a great
opportunity to learn about Plugin Development. I'd like to know if I can
contribute to testing. I don't recall seeing anything test related in CVS,
but I only looked at the HEAD branch.
It seems that the YOXOS distribution I am using was "patched" to disable
the version/patch feature required by the ATL update manger install. The
standard Configuration Manager reported that the feature could not be
enabled due to errors in the configuration.
The YOXOS Inspector view had a message saying that a subscription was
required for that feature. I wasn't happy about being denied the use of an
open source plugin.
Installing from source is hardly an inconvenience. It's time for the
training wheels to come off.
Previous Topic:[ATL] How to reference object of different metamodels
Next Topic:DSL projects: eclipse hangs when validating TGE
Current Time: Fri Aug 29 16:06:16 EDT 2025
Powered by FUDForum. Page generated in 0.12057 seconds
