Problem accessing RAP demo [message #5845] |
Tue, 13 March 2007 07:01  |
Hi all,
I've just installed RAP plugins - rap_site_1.0.0.M2.zip and followed the
tutorial to run RAP demo application. But when I access the RAP demo from
Firefox by url http://localhost:10080/ra, the Eclipse console shows the
following exceptions:
java.lang.IllegalArgumentException: An entry point named 'default' does
not exist.
org.eclipse.rap.rwt.internal.lifecycle.EntryPointManager.cre ateUI(EntryPointManager.java:70)
org.eclipse.rap.rwt.internal.lifecycle.PrepareUIRoot.execute (PrepareUIRoot.java:32)
org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.execute( RWTLifeCycle.java:60)
at com.w4t.engine.W4TModel$ServiceAdapter.execute(W4TModel.java :47)
com.w4t.engine.service.FormRequestServiceHandler.service(For mRequestServiceHandler.java:65)
com.w4t.engine.service.ServiceManager$HandlerDispatcher.serv ice(ServiceManager.java:90)
at com.w4t.engine.W4TDelegate.doPost(W4TDelegate.java:75)
org.eclipse.rap.ui.internal.servlet.RequestHandler.service(R equestHandler.java:41)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:129)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:91)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:110)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:60)
org.eclipse.equinox.http.jetty.internal.Activator$InternalHt tpServiceServlet.service(Activator.java:182)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Mar 13, 2007 5:51:20 PM org.mortbay.jetty.servlet.ServletHandler handle
SEVERE: /rap:
If I change the url into http://localhost:10080/rap?w4t_startup=controls,
the Eclipse console shows the following exception:
java.lang.IllegalArgumentException: An entry point named 'controls' does
not exist.
Mar 13, 2007 5:56:24 PM org.mortbay.jetty.servlet.ServletHandler handle
SEVERE: /rap:
Eclipse: v3.2.2.
Browser: Mozilla Firefox 2.0
OS: Linux OpenSuse 10.2
Any help would be greatly appreciated.
Best Regards,
Setya
Re: Problem accessing RAP demo [message #5863 is a reply to message #5845] |
Tue, 13 March 2007 07:25   |
Originally posted by: pedro.s.silva.criticalsoftware.com
Hi Setya,
Have you define an entry point in the project? Does it have the
parameter set to "default"?
If both answers are negative you have to open your manifest and define
an entrypoint in the extensions section. Add a new
org.eclipse.rap.ui.workbench.entrypoint and add it a new entrypoint as
it is done in the demo. Set its parameter to "default", after that you
should be able to see your sample.
Pedro Silva
Setya wrote:
> Hi all,
> from Firefox by url http://localhost:10080/ra, the Eclipse console shows
> the following exceptions:
> not exist.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> SEVERE: /rap:
> http://localhost:10080/rap?w4t_startup=controls, the Eclipse console
> not exist.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> SEVERE: /rap:
> Eclipse: v3.2.2.
> Best Regards,
> Setya
Re: Problem accessing RAP demo [message #8180 is a reply to message #7155] |
Thu, 15 March 2007 00:23  |
Rüdiger,
> in order for the demo to work You need to install the RAP SDK feature as
> well (included in rap_site_1.0.0.M2.zip). May that be the reason why?
This is in fact how I installed RAP. I just downloaded
rap_site_1.0.0.M2.zip then unzip it in Eclipse folder.
I also check Product Configuration through Help->Software Updates->Manage
Configuration and Rich Ajax Platform SDK (RAP) 1.0.0.200703021150 is
enlisted there.
But when I create new RAP application with the same configuration as the
demo. it works.
Setya
FUDForum. Page generated in 0.04957 seconds
