Home » Eclipse Projects » Remote Application Platform (RAP) » Problem accessing RAP demo
Problem accessing RAP demo [message #5845] Tue, 13 March 2007 07:01 Go to next message
Hi all,
I've just installed RAP plugins - rap_site_1.0.0.M2.zip and followed the
tutorial to run RAP demo application. But when I access the RAP demo from
Firefox by url http://localhost:10080/ra, the Eclipse console shows the
following exceptions:
java.lang.IllegalArgumentException: An entry point named 'default' does
not exist.
org.eclipse.rap.rwt.internal.lifecycle.EntryPointManager.cre ateUI(EntryPointManager.java:70)
org.eclipse.rap.rwt.internal.lifecycle.PrepareUIRoot.execute (PrepareUIRoot.java:32)
org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.execute( RWTLifeCycle.java:60)
at com.w4t.engine.W4TModel$ServiceAdapter.execute(W4TModel.java :47)
com.w4t.engine.service.FormRequestServiceHandler.service(For mRequestServiceHandler.java:65)
com.w4t.engine.service.ServiceManager$HandlerDispatcher.serv ice(ServiceManager.java:90)
at com.w4t.engine.W4TDelegate.doPost(W4TDelegate.java:75)
org.eclipse.rap.ui.internal.servlet.RequestHandler.service(R equestHandler.java:41)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:129)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:91)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:110)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:60)
org.eclipse.equinox.http.jetty.internal.Activator$InternalHt tpServiceServlet.service(Activator.java:182)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Mar 13, 2007 5:51:20 PM org.mortbay.jetty.servlet.ServletHandler handle
SEVERE: /rap:
If I change the url into http://localhost:10080/rap?w4t_startup=controls,
the Eclipse console shows the following exception:
java.lang.IllegalArgumentException: An entry point named 'controls' does
not exist.
Mar 13, 2007 5:56:24 PM org.mortbay.jetty.servlet.ServletHandler handle
SEVERE: /rap:
Eclipse: v3.2.2.
Browser: Mozilla Firefox 2.0
OS: Linux OpenSuse 10.2
Any help would be greatly appreciated.
Best Regards,
Setya
Re: Problem accessing RAP demo [message #5863 is a reply to message #5845] Tue, 13 March 2007 07:25 Go to previous messageGo to next message
Originally posted by: pedro.s.silva.criticalsoftware.com
Hi Setya,
Have you define an entry point in the project? Does it have the
parameter set to "default"?
If both answers are negative you have to open your manifest and define
an entrypoint in the extensions section. Add a new
org.eclipse.rap.ui.workbench.entrypoint and add it a new entrypoint as
it is done in the demo. Set its parameter to "default", after that you
should be able to see your sample.
Pedro Silva
Setya wrote:
> Hi all,
> from Firefox by url http://localhost:10080/ra, the Eclipse console shows
> the following exceptions:
> not exist.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> SEVERE: /rap:
> http://localhost:10080/rap?w4t_startup=controls, the Eclipse console
> not exist.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> SEVERE: /rap:
> Eclipse: v3.2.2.
> Best Regards,
> Setya
Re: Problem accessing RAP demo [message #5881 is a reply to message #5863] Tue, 13 March 2007 07:40 Go to previous messageGo to next message
Thanks for the response,
I have checked the manifest and in Extensions tab I found the following
entry points:
class: org.eclipse.rap.demo.DemoWorkbench
parameter: default
class: org.eclipse.rap.demo.RWTDemo
parameter: rwtdemo
class: org.eclipse.rap.demo.controls.LayoutDemo
parameter: layout
class: org.eclipse.rap.demo.controls.ControlsDemo
parameter: controls
Setya
Re: Problem accessing RAP demo [message #5915 is a reply to message #5881] Tue, 13 March 2007 08:38 Go to previous messageGo to next message
Originally posted by: roberto.sanchez.autonomind.com
Hi Setya, I had the same problem, but I couldn't solve it, I think that
is a Dependency problem but I'm not sure. In any case there is another
way to see the example running, donwloading it directly from cvs into
Eclipse workspace, then all necessary projects are downloaded
automatically. You can see it in:
http://www.eclipse.org/rap/cvs.php
It worked fine for me
I hope this can help you.
Cheers.
Roberto.
> entry points:
> parameter: default
> parameter: rwtdemo
> parameter: layout
> parameter: controls
> Setya
Re: Problem accessing RAP demo [message #5932 is a reply to message #5881] Tue, 13 March 2007 13:52 Go to previous messageGo to next message
Originally posted by: christian.franzel.convisual.com
maybe that is related to my observation: I have no problems running the
"Hello World" sample but as soon as I add the demo to the dependecies (in
order to implement the createUI method by delegating to the
DemoWor(k)bench) the entry point will not get registered anymore and I get
the same message...
Christian.
Re: Problem accessing RAP demo [message #7155 is a reply to message #5845] Wed, 14 March 2007 09:24 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Setya,
in order for the demo to work You need to install the RAP SDK feature as
well (included in rap_site_1.0.0.M2.zip). May that be the reason why?
Rüdiger
Setya wrote:
> Hi all,
> not exist.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> SEVERE: /rap:
> not exist.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> SEVERE: /rap:
> Eclipse: v3.2.2.
> Best Regards,
> Setya
Re: Problem accessing RAP demo [message #8180 is a reply to message #7155] Thu, 15 March 2007 00:23 Go to previous message
Rüdiger,
This is in fact how I installed RAP. I just downloaded
rap_site_1.0.0.M2.zip then unzip it in Eclipse folder.
I also check Product Configuration through Help->Software Updates->Manage
Configuration and Rich Ajax Platform SDK (RAP) 1.0.0.200703021150 is
enlisted there.
But when I create new RAP application with the same configuration as the
demo. it works.
Setya
Previous Topic:RAP in tomcat
Next Topic:RAP Table Update problem
Current Time: Sun Aug 31 17:16:11 EDT 2025
Powered by FUDForum. Page generated in 0.03570 seconds
