Re: import XML model by Xtext [message #651336 is a reply to message #651334] |
Sat, 29 January 2011 12:14 |
hi, with use you mean reference right? yes this is possible but the work to do highly depends on the kind of xml you refernce is of. if you have already an ecore resource factory for it it is quite easý. if the xml is xsd based you can leverage xsd to ecore.
if you have this done then you can do something so´mthing similar as Xtext does for .ecore files in the plugins org.eclipse.xtext.ecore, org.eclipse.xtext.ui.ecore
or do you mean import in sense of transform. id write an xslt.
~Christian
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
[Updated on: Sat, 29 January 2011 12:29] Report message to a moderator
FUDForum. Page generated in 0.02739 seconds
