Start Level Service [message #65341] |
Tue, 25 April 2006 07:46  |
Originally posted by: world2li.hotmail.com
I have a question about Start Level Service in osgi spec. Let's say, I
have a rcp app and I want certain plug-ins to start first, can I use the
Start Level Service? and how can I do that? Thanks in advance!
-Jason
Re: Start Level Service [message #66758 is a reply to message #65341] |
Sun, 14 May 2006 00:01  |
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
Jason,
With Equinox you have the option of setting the osgi.bundles list in the
config.ini (see the doc). there you can list the various bundles, what
start level they should be at and whether or not they should be
aggressively started. Note that by default bundles are installed at
start level 4 and the framework is bumped to startlevel 6 during the
startup sequence.
I am obliged to ask in these cases, are you really sure that these
bundles need to be started? and need to be started before the others?
Jeff
jason wrote:
> -Jason
FUDForum. Page generated in 0.29842 seconds
