Home » Eclipse Projects » Nebula » [Gallery] ESC key no longer closes WizardDialog when Gallery added
[Gallery] ESC key no longer closes WizardDialog when Gallery added [message #65323] Sat, 04 July 2009 11:49 Go to next message
The Gallery seems to swallow/prevent normal ESC key handling when you add
it to a Wizard Dialog. Is this a known thing? I can't see any bugs raised
for this. Or maybe I've not spotted some setX() that's required?!
Justin
Re: [Gallery] ESC key no longer closes WizardDialog when Gallery added [message #65344 is a reply to message #65323] Sun, 05 July 2009 07:28 Go to previous messageGo to next message
Hi Justin,
This is strange. To cancel normal key handling, Gallery should set
event.doit=false somewhere. Currently this is only done if you use the
scrolling smoother and only for mouse wheel events.
Please check you don't have the same problem with a Canvas instead of a
Gallery. If the problem still occurs with Canvas, open a bug on SWT,
else, open a bug on Gallery and attach a snippet showing the problem.
Nicolas
Justin Dolezy a écrit :
> add it to a Wizard Dialog. Is this a known thing? I can't see any bugs
> raised for this. Or maybe I've not spotted some setX() that's required?!
> Justin
Re: [Gallery] ESC key no longer closes WizardDialog when Gallery added [message #65746 is a reply to message #65344] Thu, 16 July 2009 05:47 Go to previous message
Nicolas Richeton wrote:
> Hi Justin,
Hi Nicolas,
Yes, I couldn't see anywhere in the source that's causing this, very odd.
Tried replacing the gallery with a blank canvas, and Esc is handled
correctly. I've changed my wizard, adding a ListViewer before the gallery
- this initially has focus & Esc is ok. However tabbing into the gallery
then stops Esc working...
My version of the source is a little old; will try this again once I've
refreshed.
Justin
Re: [Gallery] ESC key no longer closes WizardDialog when Gallery added [message #595534 is a reply to message #65323] Sun, 05 July 2009 07:28 Go to previous message
Hi Justin,
Nicolas
> Justin
Re: [Gallery] ESC key no longer closes WizardDialog when Gallery added [message #595698 is a reply to message #65344] Thu, 16 July 2009 05:47 Go to previous message
> Hi Justin,
Hi Nicolas,
refreshed.
Justin
Previous Topic:Nebula Grid in RCP application
Next Topic:CalendarCombo Date Format
Current Time: Thu Jul 17 10:55:33 EDT 2025
Powered by FUDForum. Page generated in 0.13929 seconds
