Installing Google SDK's failling [message #650892] |
Thu, 27 January 2011 04:08 |
Corey Messages: 8 Registered: January 2011 |
Junior Member |
After opening the Android SDK manager and tring to install the Google SDK's I get these errors: Any Help Please I'm New to this. I do have 4 SDK's installed Android Honeycomg,2.3.1 api9, 2.2 API 8 and 2.1-update
Downloading SDK Platform Android 1.6, API 4, revision 3
File not found: C:\Program Files (x86)\Android\android-sdk-windows\temp\android-1.6_r03-windo ws.zip (Access is denied)
Downloading SDK Platform Android 1.5, API 3, revision 4
File not found: C:\Program Files (x86)\Android\android-sdk-windows\temp\android-1.5_r04-windo ws.zip (Access is denied)
Downloading Google APIs by Google Inc., Android API 9, revision 2
File not found: C:\Program Files (x86)\Android\android-sdk-windows\temp\google_apis-9_r02.zip (Access is denied)
Downloading Google APIs by Google Inc., Android API 8, revision 2
File not found: C:\Program Files (x86)\Android\android-sdk-windows\temp\google_apis-8_r02.zip (Access is denied)
Downloading Google APIs by Google Inc., Android API 7, revision 1
File not found: C:\Program Files (x86)\Android\android-sdk-windows\temp\google_apis-7_r01.zip (Access is denied)
Skipping 'Google APIs by Google Inc., Android API 4, revision 2'; it depends on 'SDK Platform Android 1.6, API 4, revision 3' which was not installed.
Skipping 'Google APIs by Google Inc., Android API 3, revision 3'; it depends on 'SDK Platform Android 1.5, API 3, revision 4' which was not installed.
Downloading Google Usb Driver package, revision 4
File not found: C:\Program Files (x86)\Android\android-sdk-windows\temp\usb_driver_r04-window s.zip (Access is denied)
Downloading Google Market Licensing package, revision 1
File not found: C:\Program Files (x86)\Android\android-sdk-windows\temp\market_licensing-r01. zip (Access is denied)
Re: Installing Google SDK's failling [message #651041 is a reply to message #650997] |
Thu, 27 January 2011 14:36 |
On 2011.01.27 5:23, Corey wrote:
> Skipping through your guide you pointed me to looks alot like the
> information I have been following. (Section 2) I will spend more time
> with it to night and if all else fails I will install it from my PC and
> follow yours step to step.
> Other things I have thought of trying is Run eclipse as Administrator or
> just the SDK installer.
> I had already tried to disable my Virus software
> Other information that my help you help me
> Windows 7 x64
> I'm a noob with Eclipse :d I'm a novice program :roll:
That's actually not mine, but the one I followed very successfully
(though I had my problems too). For my experience, which contains lots
of step-by-step notes about what I did following that tutorial, see
http://www.javahotchocolate.com/tutorials/android.html
Re: Installing Google SDK's failling [message #662978 is a reply to message #662806] |
Fri, 01 April 2011 17:06 |
On 31-Mar-11 21:16, yellowblues10@gmail.com wrote:
> I had the same problem and it was due to not running android sdk manager
> as admin in windows. Right click the program and Run as Administrator
It's your development hardware, for heaven's sake: stop installing stuff
where you can't use it. This stuff doesn't have to go under C:\Program
Files, etc. as if you were a casual Windows consumer. Put it on "real"
development paths you have access to.
FUDForum. Page generated in 0.08415 seconds
