Home » Language IDEs » ServerTools (WTP) » content assist in wt m2
content assist in wt m2 [message #65311] Thu, 13 January 2005 07:16 Go to next message
With the new version of wtp (m2) in any jsp the content assist has stopped
working in comparison to m1, in some circumstances. Is this a change in
functionality, a bug or the wrong setting in my eclipse setup.
e.g.
<td width="300"><newcutomjsptag:localize key="<%=
javaobject[j].getLabelText() %>"/></td>
In the old version of wtp if I typed javaobject[j]. (followed by ctrl
space) content assist would appear, listing methods etc...
It *does* work in the rest of the jsp, just not in html sections outside
of <% %>.
I have just upgraded to the newer wtp m2 (with eclipse 3.1.0 Build id:
200412162000 on xp).
Any thoughts?
Stuart
Re: content assist in wt m2 [message #66992 is a reply to message #65311] Fri, 21 January 2005 17:09 Go to previous messageGo to next message
Originally posted by: pavery.us.ibm.com
Hi Stuart,
Did you ever get this figured out?
This functionality should be the same in M2, and works with my M2
environment.
I'm unclear on what you mean by this:
> of <% %>.
does that mean you're not getting HTML tag proposals?
-phil
> stopped working in comparison to m1, in some circumstances. Is this a
> change in functionality, a bug or the wrong setting in my eclipse setup.
> e.g.
> of <% %>.
> Any thoughts?
> Stuart
Re: content assist in wt m2 [message #67009 is a reply to message #65311] Sat, 22 January 2005 01:41 Go to previous message
> e.g.
Unless I'm mistaken, WTP1.0M1 didn't have a JSP editor. Do you have
anything more than Eclipse3.1M4, WTP1.0M2, and its prerequisites
installed? Strange things can happen when multiple editors for the
same content type are installed.
- Nitin
Previous Topic:Failure while refactoring
Next Topic:WTP EclipseCon Project Sprint - call for ideas
Current Time: Wed Aug 13 12:19:13 EDT 2025
Powered by FUDForum. Page generated in 0.04831 seconds
