Home » Eclipse Projects » Equinox » OSGi bundles in web app
OSGi bundles in web app [message #65258] Sat, 22 April 2006 01:41 Go to next message
What is the best way to include some OSGi plugins in a web application, to
be used as a library for the web-application code (the web app code is not
organized in OSGi bundles, it is just any regular web-app java code). If the
plugins jar are not in WEB-INF/lib, the web-app code can't access it
directly. If all the code is in WEB-INF/lib, it breaks the eclipse extension
mechanism between the bundles.
Is there any example of this configuration available?
David
Re: OSGi bundles in web app [message #65279 is a reply to message #65258] Sun, 23 April 2006 07:46 Go to previous messageGo to next message
Originally posted by: skaegi.sympatico.ca
Hi David,
the
extension
You're right in that this is a bit tricky.
The problem here is that without the servlet container providing direct OSGi
support, the webapp classloader is going to "parent" (in the classloader
sense) the OSGi framework. As a result the OSGi framework "can" see the jars
in WEB-INF/lib but but not vice-versa (at least directly).
To expose functionality what you're left with is an approach where a bundle
will register a "call-back" function against a singleton or static in the
webapps code.
Take a look at the server-side incubator and specifically
http://www.eclipse.org/equinox/incubator/server/embedding_in _a_servlet_container.php
The call-back approach is how the Servlet Bridge exposes a callable servlet
interface back to the servlet container.
-Simon
Re: OSGi bundles in web app [message #65300 is a reply to message #65279] Sun, 23 April 2006 12:09 Go to previous messageGo to next message
Hi Simon,
Thank you for your answer. However I don't think we can register a call-back
method in the webapp code. The reason is that we provide the OSGi
bundles/Eclipse plugins as a library, so that anybody can use them in his
own web-application without restriction. There is a lot of API code you
might to access from the web-app, and we can't use an invasive approach
where the web-app has to declare some call-back functions for each API class
or use the OSGi framework for its servlets/JSP code.
Is there anyway to inform the web-app to use the OSGi classloader when
starting the OSGi framework? What do exactly the settings
osgi.parentClassloader=fwk and org.osgi.framework.bootdelegation=* do?
Otherwise if we move all plugins/bundles under WEB-INF/lib, what causes the
OSGi framework to fail loading the plugin/bundle extensions?
David
"Simon Kaegi" <skaegi@sympatico.ca> wrote in message
news:e2fpdv$dl7$1@utils.eclipse.org...
> Hi David,
>> to
>> not
> the
> extension
> OSGi
> jars
> bundle
> webapps code.
> servlet
> -Simon
Re: OSGi bundles in web app [message #65321 is a reply to message #65300] Mon, 24 April 2006 10:12 Go to previous message
What happens is that the webapp classloader parent's the framework's
classloader (e.g. the org.eclipse.osgi).
Every other bundle is parented by the classloader according to the
osgi.parentClassloader setting.
osgi.framework.bootdelegation filters what classes are visible for parent
delegation for these bundles (everything except org.eclipse.osgi).
the
This should work with servlet containers that unpack the WAR to the file
system.
If you use ths approach you'll probably also need to set up
"osgi.configuration.area" as some bundles need to use disk.
Rather than using "osgi.parentClassloader=fwk" you might consider using
"extension bundles" {3.15 of the spec}
Also see https://bugs.eclipse.org/bugs/show_bug.cgi?id=131253
The advantage here is that you can be more selective over what is exported
from the webapp classloader.
-Simon
Previous Topic:First steps to OSGi
Next Topic:org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.registry.osgi.Activator.s
Current Time: Sun Jul 27 06:09:43 EDT 2025
Powered by FUDForum. Page generated in 0.04241 seconds
