Home » Language IDEs » PHP Development Tools (PDT) » Formatting doesn't work?
Formatting doesn't work? [message #65214] Mon, 28 January 2008 19:38 Go to next message
I've downloaded PDT (Ubuntu Gutsy) All-in-one. The "Source => Format
Document" and "Source => Format Active Elements" blocks don't auto-format;
they just move everything to the left margin. No indentation at all.
I copied the example PHP class "Calculator" from the documentation (under
"Formatting Code"), and it produces the same results.
Is there some magic incantation??
Version: 3.3.1.1
Build id: M20071023-1652
Re: Formatting doesn't work? [message #67071 is a reply to message #65214] Tue, 11 March 2008 08:33 Go to previous messageGo to next message
Originally posted by: tigachris.gmail.com
hey I have the same problem.
I tried to make a fresh install of Eclipse and PDT but still the same
problem.
if anyone has a solution it would be nice !
Re: Formatting doesn't work? [message #522163 is a reply to message #67071] Sat, 20 March 2010 12:54 Go to previous message
Did you guys find out what the problem was? I have the same thing...
it seems to be an issue only with the files placed on a network location
[Updated on: Sat, 20 March 2010 12:56] by Moderator
Previous Topic:how to change background color on selected variable in php
Next Topic:Variables view empty when usign xdebug
Current Time: Wed Jul 09 22:24:49 EDT 2025
Powered by FUDForum. Page generated in 2.39566 seconds
