Home » Language IDEs » Java Development Tools (JDT) » Code Formatting Feature? Disabling code wrapping
Code Formatting Feature? Disabling code wrapping [message #65208] Mon, 23 June 2003 12:38 Go to next message
Originally posted by: kdolan.inmedius.com
Hello! I'm new to eclipse and am looking at it as a replacement to the IDE
our developers are currently using. I have a question which I think best
fits this newsgroup but am unsure so please let me know if another newsgroup
is more suitable.
Regarding the Java Development plug-in, I like the ability to setup
preferences for code formatting and then be able to press a button and say
format! However, there is one preference that I cannot set and I am
wondering if this preference will be available in the near future. If it
will not be available, then I have two options, forbid our developers to use
the code formatting feature or modify the open source, neither of which I
really desire.
The preference I am interested in is disabling the wrapping of code. We
have alot of code where in some cases, a statement is on one line and in
other cases, it is broken down into many lines. Each situation is coded
based on the importance of the statement and its readability. We do not
want these statements re-formatted. Unfortunately, if we use the code
formatter, it either wraps our one-line statements or reduces our
multiple-lined statements to one line. I cannot find a way to avoid this
other than not using the code formatter but then we do not benefit from the
other settings chosen for this feature.
JBuilder has a similar code formatting feature but provides a checkbox that
when checked preserves existing line breaks. As a result, I can set the
"column at which code is wrapped" to be very high and check this checkbox
and all of our statements remain as we originally coded them (from a line
perspective). I'm not saying that I particularly like JBuilder's
solution...the more I think about it, it would be nice to be able to specify
which formatting perferences are to be applied (e.g., enabled/disabled,
active/inactive, applied/ignored, etc.), not just for code wrapping.
So, I guess my questions are...
(a) Is there a way to prevent code wrapping that I do not know about?
(b) Is this ability officially being considered as an enhancement...
- if so, do you know the timeframe for its release?
- if not, how can I ask it to be?
(c) If we want to use the code formatter and therefore our only option is to
modify the open source to disable the application of code wrapping, could
someone please point me to the file that would need modified? I'm sure
given enough time we could figure this out but it is time we don't have.
Therefore, in reality, we would most likely not allow developers to use the
code formatting feature.
Thank you!
- Kelly
Re: Code Formatting Feature? Disabling code wrapping [message #65294 is a reply to message #65208] Mon, 23 June 2003 13:25 Go to previous messageGo to next message
Originally posted by: Jed.Anderson.EN.aclickinthedark.com
Kelly,
This annoys me as well. I just go into the preferences and make the
line length 9999 (or something equally large).
The preference (in a 2.1 build) is found at
window->preferences->java->code formatter->line splitting.
jkca
> is more suitable.
> really desire.
> Thank you!
> - Kelly
Re: Code Formatting Feature? Disabling code wrapping [message #65423 is a reply to message #65294] Mon, 23 June 2003 14:23 Go to previous messageGo to next message
Jed,
I tried this but found that for statements we had split into multiple lines,
it collapses them to one line.
Example:
Before:
aVar = method(param1, param2,
param3, param4);
After:
aVar = method(param1, param2, param3, param4);
What I really want is for Eclipse to leave line splitting alone, as-is,
etc...
- Kelly
Re: Code Formatting Feature? Disabling code wrapping [message #66073 is a reply to message #65208] Tue, 24 June 2003 08:02 Go to previous message
Eclipse's formatter is crap.
I gather they're building a new one for v.3.
In the mean time, you can check out Jalopy:
http://jalopy.sourceforge.net/
There's also JIndent for Eclipse - which is /sometimes/ at:
http://www.javadude.com/tools/
If you want something that will mostly leave your code alone,
though don't hold your breath.
__________
|im |yler http://timtyler.org/ tim@tt1.org
Previous Topic:External View and Java Applets
Next Topic:Unused public method?
Current Time: Tue Jul 22 12:01:27 EDT 2025
Powered by FUDForum. Page generated in 0.06305 seconds
