Home » Eclipse Projects » Remote Application Platform (RAP) » getText() in Text not working
getText() in Text not working [message #65183] Mon, 10 December 2007 16:01 Go to next message
Hello
i guess this is a probably serious bug:
in any textfield, the method getText() delivers "" (empty String) if the
contents has been copied and pastet into that field. This happens either
when the contents is copied with the keyboard or with copy&paste menu.
if anything is changed in the textfield, getText() delivers the whole
contents.
Version is 1.01 Service-Release build 1851.
Andrej
Re: getText() in Text not working [message #65288 is a reply to message #65183] Tue, 11 December 2007 03:26 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
hm, i couldn't reproduce this misbehaviour. neither on firefox 2.0.0.11
nor on IE6. when i copy something into a Text widget the getText() method
returns the proper string...
i'm using the CVS head plugins.
Antw: Re: getText () in Text not working [message #65309 is a reply to message #65288] Tue, 11 December 2007 04:00 Go to previous messageGo to next message
Originally posted by: admin.kabe-farben.ch
i was on IE7, but i will try on FF this evening and report back.
Andrej
>>> Ben W.<benjamin.wolff@web.de> schrieb am 11.12.2007 um 09:26 in
Nachricht
<ab4968e67fa0513c411a4bb3b611de08$1@www.eclipse.org>:
> method
Re: Antw: Re: getText () in Text not working [message #65498 is a reply to message #65309] Tue, 11 December 2007 07:12 Go to previous messageGo to next message
this is a known bug.
See 192146: Wrong text field behavior when using Ctrl. + V
https://bugs.eclipse.org/bugs/show_bug.cgi?id=192146
The problem is that we cannot reproduce it. Just tested it with IE7 and
FF 2.0.0.11. Maybe you can come up with a snippet how to reproduce the
problem.
Greets
Benny
> Thanks
> Andrej
> Nachricht
>> method
Re: Antw: Re: getText () in Text not working [message #65602 is a reply to message #65498] Tue, 11 December 2007 09:11 Go to previous messageGo to next message
Hi Benny
i just read Bug 192146 and there is a code snippet in it. I wouldn't know
what else to add.
Jordan writes:
"If you haven't typed, but just pasted into the text field, getText() will
return
an empty string. After you have modified the text field by typing or
deleting
some chars, everything will be fine. The problem occurs the first time
after
the text field was created."
This statement is accurate.
maybe it's the localization of the browser? i used IE7 german when this
problem occured.
Andrej
>>> Benjamin Muskalla<bmuskalla@innoopract.com> schrieb am 11.12.2007 um
13:12
in Nachricht <fjlv1k$hiq$1@build.eclipse.org>:
> problem.
> Greets
> Benny
>> Thanks
>> Andrej
>> Nachricht
>>> method
Re: Antw: Re: getText () in Text not working [message #65770 is a reply to message #65498] Wed, 12 December 2007 02:20 Go to previous messageGo to next message
Hi Benny
i check also with FF 2.0.0.9. Same issue as with IE7.
Greetings
Andrej
13:12
> problem.
> Greets
> Benny
>> Thanks
>> Andrej
>> Nachricht
>>> method
Re: Antw: Re: getText () in Text not working [message #68981 is a reply to message #65498] Sat, 05 January 2008 12:49 Go to previous message
Hi Benny
regarding Bug 192146(paste a text with Ctrl-V into an Text-Widget, do not
type anything with the keyboard, getText() delivers empty string instead
the pasted text): this Bug is still around in the newest RAP
1.0.1-Integration Build dated december 21.
Will this one be fixed soon?
We are in the process of finishing our RAP-Application and as we can not
forsee the behevior of internet-users, we must expect that users will use
the copy&paste feature. And that is exactly what Bug 192146 is all about.
Andrej
Previous Topic:Communication between Server and Client secure?
Next Topic:runs so slowly in IE
Current Time: Mon Jul 21 21:22:40 EDT 2025
Powered by FUDForum. Page generated in 0.10443 seconds
