Home » Archived » Test and Performance Tools Platform (TPTP) » AGR - problems with view menus
AGR - problems with view menus [message #65180] Fri, 07 April 2006 15:14 Go to next message
I have trouble executing a macro that invokes an action from a view menu.
Using TPTP+AGR 4.2 i1/M5 build on win xp
The following recorded macro also demonstrates the problem. It tries to
show the problem view and bring up the preferences dialog, then closing
it. This can be executed from the Java Perspective.
<macro version="0.1" >
<shell id="org.eclipse.ui.internal.WorkbenchWindow" return-code="-1">
<command type="select" contextId="menus"
widgetId="org.eclipse.ui.internal.ShowViewMenu#{{&amp;Window-Show
&amp;View-&amp;Problems}}-{{0.8}}{{6|4|9}}-{{0.6}}{{ true}}-{{0.1}}{{13}}-{{0.1}}{{&amp;Package
Explorer&#x9;Alt+Shift+Q, P}}-{{0.2}}{{&amp;Search&#x9;Alt+Shift+Q,
S}}-{{0.2}}">
<parent widgetId="window"/>
<parent widgetId="showView"/>
</command>
contextId=" popup/view/org.eclipse.ui.views.ProblemView/org.eclipse.swt. widgets.Tree#1 "
widgetId=" org.eclipse.jface.action.ActionContributionItem#{{&amp;P references...}}-{{0.8}}{{5}}-{{0.6}}{{false}}-{{0.1}}{{6}}-{ {0.1}}{{&amp;Configure
Filters...}}-{{0.2}}{{last}}-{{0.2}}"/>
<shell
id=" org.eclipse.ui.views.markers.internal.MarkerViewPreferenceDi alog "
return-code="0">
<command type="select" contextId="shell"
widgetId="org.eclipse.swt.widgets.Button#{{0}}-{{1.0}}"/>
</shell>
<command type="wait"/>
</shell>
</macro>
When executing this macro I get an error that says: Cannot locate menu
item: ...
Re: AGR - problems with view menus [message #65948 is a reply to message #65180] Tue, 11 April 2006 16:23 Go to previous messageGo to next message
Hi Daniel,
You need to explicitly select an item in the problems view before invoking
an item from its context menu (i.e. left click an item and right click the
item to select a context menu item)
"Daniel Dominguez" <daniel@parasoft.com> wrote in message
news:e16dn7$h1k$1@utils.eclipse.org...
..1}}{{&amp;Package
> S}}-{{0.2}}">
> </command>
ts.Tree#1"
....}}-{{0.8}}{{5}}-{{0.6}}{{false}}-{{0.1}}{{6}}-{{0.1}}{{& amp;amp;Configure
> <shell
> return-code="0">
> </shell>
> </shell>
> </macro>
> item: ...
Re: AGR - problems with view menus [message #66013 is a reply to message #65948] Tue, 11 April 2006 16:44 Go to previous messageGo to next message
--------------040007090709030307080803
I think maybe I didn't describe the problem clearly enough. This issue
is not with context menus, but rather the view menu that is accessible
from the view's toolbar. I attached a screen shot to hopefully make it
more clear.
I only used the problem view as an example of a common view with a view
menu.
But this is preventing me from testing one of my views.
Thanks for your help,
Daniel
Ali Mehregani wrote:
> Hi Daniel,
> .1}}{{&amp;Package
>> S}}-{{0.2}}">
>> </command>
> ts.Tree#1"
> ...}}-{{0.8}}{{5}}-{{0.6}}{{false}}-{{0.1}}{{6}}-{{0.1}}{{&a mp;amp;Configure
>> <shell
>> return-code="0">
>> </shell>
>> </shell>
>> </macro>
>> item: ...
Content-Type: image/png;
name="probView.png"
Content-Disposition: inline;
filename="probView.png"
iVBORw0KGgoAAAANSUhEUgAAAg8AAAD5CAIAAAAvE0HYAAAACXBIWXMAAAsT AAALEwEAmpwY
AAAAB3RJTUUH1gQLFCokYnVXBgAAHOBJREFUeNrt3XuYFNWdxvHfqR6YQW6j 6ACigMEgi4+X
3Fw1xluS3XiNG0zU8MTEZDHxhsOIDMoaH4MYBkcgRpMVY0xMNKKgkaBmY7KA 8cKTi7vZJ0wG
guEmKCgMIMhcuursHzUUNVXd1VXV9+7v5/HBnuqq6urTXeetc6q6jnpve7sA ABDIoAgAAKQF
ACAHatx/7NjxbtuaNgoFQIWZeOLEhoajwsxJNZiOss9bOAV07nnnVG1ZrFyx qozevvORXb7k
wsr+XJZc/kLUHR7w790Zv0JUg5nbFnYZUUBlxP7IvvTsxSJiJCr8zdpvU0Se kuVta4gNxGHX
bytXrBJJ/eWhGsycFpRRmUbFVcsuSSSq641ftewS+8Ev5Fdta8gMxMmMlIFB NRgqLSijcoyK
ycsvNQwRkYfOuk06O6WuTqRO6urrpF7q6qWuXqRe6urq6upF6q740dAKK4TJ yy8VkcdlWbrj
RCB8YBAVYdOCIihHiYTqfdTZeerXfnLK0NrtXV3uGYbX1v721baTPj5ORBbL O19+tK7yCuHq
Fz//mDxHIyOvZt+35I5bLrcf3/vwy7dOOTvkgnPuaQ14dtbt03O7YOyXQ4S0 IFHLrmFxzW8u
c/qgOqU3BrrW/m3fr5d/sPq1w04/c9DnLpaTTxXRIqJETj99xBPyzlceG1B5 BXLNby4TkUfl
lzQyHG3t2+0HEycMDzM9cyFPm/PogllRN2PW7dPn3NM6f+HDnulNjVMy1t3+ pZxlc7KU3bxo
aOit+mhY0LaoWEbi0K9kOjtFRLTIvl8/X7/lrdEnf2zvlrd2//p56+RTRItS okRprT1LlbKv
H3ab/eDHH3w3eKLjG7/7wiPyDIFhR4K5e9fA2gH7uw60tR8KhnTTU/rWY3+v 6947oLPjsK7d
IvKhY06IHRhNjVPclXiYqIgtOEtQ5LQ4cviEot84pBS2ocDbf6gbSkSkTkQs LR+sfvXoXXWW
vHuY6G1/b9e33i4ihiglYol0epeKbOcPhw27bmfwlFzprV8ap/y0a66IfLV2 pj2lqXFKundx
7cpJi2QpgSEiWusjGhqO0Hrzlk1tB79ZyY6do0ePFa33bdmUcQ3/efWHncez 71vyj7fW2lGx
cePmbAIjfFTEq/fjtUgQJy2OHD7BeVyU+te9AcXahoB63P6zFMLJXWPabQtL W4Ol374RtYPr
huzr3Du4e6gWEaUMUUrJyhUbbvrVUZ4LqHY8cITzuOHGXdFTKvWUHGdG4xRP LRDwitf9/vIf
ypIqD4yJE4a3tcumDf845phjR40c9f6+9/fs3j20vn7wyFFmT8/WrW/VDDsy ak+U06rYtHGT
iPzl4bNF5JQpL0cKDAl98oBzDOXRtnDqwWLViaXfSiiFLTQMV1qIiIglMvQ7 s/e8+Kt3Vr86
6PRP1l9wiaW1aJ1QokQ6+y7iGDG1w0kO53HI1003JXtPWPPk4NGopxPjCWue EdiddsOrX3xQ
niYw2tpl86ZNRx89akD/ugENI0Qk2d2z7Z1ttQ3Do0aFc4pbRJY/3hsb5922 dsV3T4gUGFS1
lZYWAcf77iDx15tOugTM70xMuYaMR/fOoX26ituzWk9TIPjZGA2ObF7O/6x/ 5oDYTvQ5A1H3
vy+9/n+GYSSMmgnny4Tz62r71+ywanb9tSaReONP6w3D6OzsTKQ6aeGemEgY WxcMHTVtj/2v
iGxd0Hvdrf2niLxz/+GeKfYaPHO6/7QfO/P715nSYmkVX3/3YtUa5vclU1df cb8sJjDaRHa/
996gIUNERETt37snRlSIyJ9/+CkRJaKViBZRSrTuDYzfzh7/0et+Tx1KWqRu baSsvNwTA+a3
68TgqtBTbzprCHiJgMf+B+kmhuwcC4ix4HIIft2oTTpPT9Spnz3j+IEJUaJF ku/9vd+RHxZR
WvTq1es+cdqHH1my5r4/HpeynnWvx368dcHQ0dP3JhJqc+uQ0dP3OlW8/dg/ JXhO50/7gXvO
zF1Yycz9YOlM++OVC+RJzmFoyzJ7esvRsqwYa1h9/1kXNC+z86Y3JZQS0Xpf u4j+9LTnXmw5
6/SbX6Earca0CG4ZZKw3w8wfPI+/rszmVEHwhoVZZ8AaglcY7+U8bzndGzfc aSF1IpJQhoh0
vrd23aOTx1/zeN2R40UM0bqfMjo7O4009ezmVvvAU8Y2v2/P4zzwvIr9ON0U Zz3+OT0PNrcO
Gdv8fsYS+EJXk+eMpX0O45na+SHL8JY3rrpPflG1gdHWvv39jZuGH9VgmWZv C7RuwDsbNrZF
vHz29KmvPDf7TNEiSpRWWrT9cV7S1CoiyxZMP3v6a9ShVZoW/iP9jLHh6WAJ EzOVcUYkYIUh
yyG2Pm2LAyIiCSWW2bPu0cmnfelbf3h08kdm/EmUiFJKiUhnuqPycbfv86zQ 39pwP043xVmP
f073A3u2jS2DPYt4fP6DaU5UNLnOctuB8dxhC0KW0oy/fHmePFGFgdHWvn3P mxtGjhghInvf
37tv3/5BgwYOGTxkRMPwt9/cEDUw/Hnwu3vOEJFnWm45//bXS+qNc+1TkXui Ih0LR10wZF9Q
bq9EyvkJ/HxcERD8lv1X0BpK/c99Z5x21rGy7fnTzjr2D/M+/rHmP4uIIaqz M20fTvA1TuHT
wpm+bvbA8XfsT5cW9oPxd+xfN3tgmG6lpsYpywcvFBH3OYxIV2Hd9tfJ35XH qyow2tq3d6xb
P2rUKBHZunXr4eOPrxcRka3r1o8aNWrkiBFb162PFBju33JfPHnO8sdnmUn9 1Jymf/n26pJ6
45xIL3JaeM4qe6a46zJ350m8NfiPxN01ZsAp4jCrDX42dm0e5uWiLhuGYXh/ nWeIEhEZ7Fwm
v8UQJVoSou785jny0KpfbDsteD2eKRPuPLBu9kDnsT3dP8UwjJRzOutxP2i/ a4BntuCDxBeG
3m/P9MLQ++XgYWPwgikqkbavzJGfVVsLY//+fbt37zl8/PGHfp0nsnXd+vr6 OHcMc36aN2bs
GBEptZxAwaiC9Qvl5Bg8r5f2ls74Funepn3nj2+vvdqZcvLb35s5t/GUobUb Hr3o3e1v2xOP
Gj7yuGue/+2raz7zyRPtKXc9tOqp7f9ctd/y75zwWPXcSyr7O394fsstIvYP 9CLdJ6rEuXf2
8hrYprx7ojJWfDk8qIe/N2buzIUiIuLajTeJ/KFFRB75+XJ7wqkTxub1l3Ql 7q71X71Tflol
9x9MFwbhe5/S/ZYbpEV+5TYkqiRygt+m+9qkv42ZFmaFfztQ+YMmBZu94Wsi cof8hCtro8oy
KoYdPF7cyfEiaYGCty0MCiGeezZ//Xb5MTc5D8/9W+6U3VDD8nDVH0gL5Cot FIUQW8vWb4hI
szzCoK0x2gcgLVBO8nF3pmpz79v/3nu8LD8iNogHhKGWPPkQpVBe5u/gV0i5 19TwMIVgm3Tl
N2MstdRVk6Rcw1KqmnJPi089qCkFACLy8g0Zmq1nB1YXNw9bNOmKa0WlWYmm qiknSxcv8lxY
TE8UQELEyYY0x5/KmxCKjtMK0ZsWz16+lrIAqk3A+Ymd29uflWjVwsoVlGgV pAUAcsIdFTl4
DbqeSAtkyf59e87vw1jcUWCjvnqWWxu7DAv8NsslJ7KPh2HDJ0wiKqokLUrk Fh353ox83IM2
5Qane6HYG+C/r6LzuhmH2yuLujLeoIrhP4ucbHyJjM1ealGBKkqLglU34WuB PG1G/m5X7tng
vJZhutH3yrq9leVHX6zPonxDIodRwe8zqqttEf6gz32kls141LGPrP0PAjbP U2UEjO+dzRDi
6TY44IUyjmSecuTzMMfaAetPeZTtnsfTw5Nu88IMMC6xRmMM2eyI1BPl+apk 3PjgQiiX5kXG
GjxfTYoc9UEp18VUOtM6lVLOPO7HKGhaZByDOuTE/O1gUYfITjk9eAjx3G5e wHDiIV80ZQgF
vGLGDyLdhxVy48MUacpCjt1oyHLw3YB1egqhAk5U5DUqMmRS3Mtns6nxiYqS aFukrKGC96Xw
B8iRDthzNQh2+HqqKH0y2fenZVk4WY4Ue2QBOyiCB6HKZtsqKTDyfooinzW1 09qw88BOFCdX
7GedKSmbJpHaK4iTFjk8xM75pSz5GwQ7Txtc4BfN8rqjLMu2wJVspK0NuW1F +RqURzDk83SF
u7p3Z4On5eGe6K/9PfN71kDtH5URtfrIYeUVaW3pBl4tWAVUyCPlfLy1I4t6 HrKQrx7jWt5S
i72y4ImKndvbg+4EFf1AXh8UULPTPihC2yJgsOjw40iHHHM7YCUxxqyO2v8Q fj152uDgxYM/
hTAv4T5Jm8PNi7Fy/wwBH1ZOvoHBLYB4JZPyBDvhwUVQVaj3roJFufNHye51 Of+pRGUXV7Xh
g/CkhdPltXLFqklXXOuqXVQ2bQvXalL0I6WcEmP+4JVU80dcQncVLMFdLvhg s+gbXMHX5xAV
FRAVOT6M9Z2O9p/JcHOeDajigzu1kFHR0qIEd7nwF3dRaFWLj6AwfVApK33P xHR/OumS7inx
XV4V/Bh90mLlilWUBYBgnmGOlj75kISpOkqm5g1onSBsWvTpbQRQKE2NU+Yv LJ9h+9xpofWk
vk8uXbyoxDefkMhBWojI3t1bKA6gkF76rxfLZe8bcvho9597OzYLNUbVpoWI 9HR/QIkARVFe
e1/mreV8csUxKAIAwfh1BYTRkABEigoGwyAtvILvchpDmJ+8cTE7kI+9L1fi RAUnlquhbZHb
SjzkXSv4SAApmRuNxPwhHictqi0t3F/cgBGNgkeV8f+bcn8IfpWSPdQCitLm CLP3SfoBVDLu
aPafnK6oVPHua1IT9csaPHqP/zgo45g5EjiidZhBeIAqiYrwe1/AbpJuXKzg xYtyuiJ/w1Ew
0EWMwKiJ8ZUN+BIHNKgBZNOMiLH3Rd0l090hOFpU5PRmgvkrYW4gGPWNR06L lA2FchwrBihl
/j7YAux97pUUtxsqZUWWcrA8ST9cEiN75zYwQv3eIuXxC+cSgAJkRsrj/Xzv fSV7xsJzp/Ew
wyWlm0cdVM23A8lZ28LfFs44ek+YQWbSLRLwKkCVB0bKEZwy7n3BY4V55rf/ 1DmtinISD+56
LYc1u6cl4R7Qu0ryI2fnLQIGIAuezT0l5eOARdLNk26dQKUmRPAOEmbvC7NI ij9L7Ld4nk4n
FCsqhDt/AMilHFXrRRm5qHoaFvHe46G2hXM7zLxa8uRDjKUBeBRm78vIPXzF 0icfEhEp3t6a
8YSEv5Mq5cmJdPUjY13ETIumximUBVAUpbD3zf/ejzxTXn39j1FX8skzPpHX Q+DgP0NOCZjO
WNyh0qKcxmMBKsje3VuG1B9b/O3wpUWMOmHp4kXcFaqCcd4CqHr+Dp+KqPSj NhRoWIRqWwAg
JyomJ0DbAgBRAdoWAIqIqEBfnutXSQuAnCAnkMK5553j/pOeKKAq8etoRETb AiAqcm/p4kUU
czmadMW1pAWAwrUqAiodlAvOWwA4iDMWSI/zFgANC6ICkdG2AKovJ4DoaFsA VYmGBUgLAEQF
co6eKKDSefqgiApkkxZ7d2+hLICiyPfeN6SwL4cKT4uSuMM+UJVRkce9L9WZ bXZ2xMN5C6BC
pbzFbJl3Qymu7CpeMZIWQHUoq5xQfXkqODKjMIGxY8e7pAVQTQ2L8mxSaBdh YLtiBEbbmjZ3
YJAWQEVHRYVWbU6bw90Qcc+Z7lmED4wLL7ncHRikBVDRUVG2h+SenqiULQ97 NqcJ4k4I/7N8
NVIWY+DT1oUXf8EJDNICICpKtCILWdH7Q8W9CK2KmFEhorWltXXBRZfZgUFa AERF2dd66XLF
aXOQGVGjwl2wn7vw821r2vgtN1CZlUFVxqVKWQm6O6kgoS8Z0NpyHv/rBZeQ FkDFNSwqPSqc
2t9zusJfCQY8hUhpIdwnCqi0qKjQg1/PdbTuGTwzBzyFbD4F0gKorKigfkTO 4oK2BUBUAJnb
FqQFQFQApAVQnXs2ZYBcf6dSnbfglvdAscTY+4YcPrrPGjo2C7swCtO24Jb3 QLGiIvLe57sC
iv0XBUgLfssNlP0+TRmgAEgLoHwoVb63Im9snuM8njnnYT7M0jes4QT3f6QF UD5RUeYunXw1
H2P54poooDyjohxaFV9sXV7XvXdAZ8dhXbtF5EPHnHDp5KuXPf5Ynouq96Yg BfxwVDX8aJy0
AMotKsqnYnp6+sXO48bmOf94a60dFRs3bg5f7x980zrkIs6cOa/EPbcmtG9R lb+XIy0AVEVU
+Dmtik0bN4nIf88ZLiLnz9qepwP2fNTdAfekqnictwCIikJY2DLLefz6S72x cd5ta+3MCBkV
/kFV/UMhOX+mm80zs2QxOGtVjf9K2wIgKgrhN3c1iCgRrUS0iFK9b+i829a+ dFfDZ+/cEaZq
9nf7BExJuVTGlQd3LgV3jqVc0L/mMu2zIi2Aks+J8o+K5//jqAual9nvrfe9 KCWi9b52Ef3p
ac89P+uoi+a8W8QtDDk4a/ha3r8Sz0uUXWCQFkDJK//O8YvufvfZGcNEiyhR WmnRdlV6SVOr
iCxbMP3f5u0spfLWeV2J08KQsjrzQVoAKAR/HjzVeISIPNNyyxcX7vLXp6Vw 9J2TbQgz/mu6
7q+SaoJwlhsoycaE+7+K4P4t9xmfvVpEzKR+ak6TPyrclan7bLB7Svg61L1U uinp5o9UUzsL
ZlxJvPWTFgCqhfNb7jFjx4jIVQ90XPVAR3D96/BMcf50zyxphln1LOVfs/+6 WM/8/pdL+aLh
N9W/PRkfFx09UQDyJd1vuceOHV3IzXC3KvhQsk0LxrcAiqWC9750v+UuMEIi l2nB/fGBYkVF
9ex9RYkK5ArnLQAUgvu33HNnTaFASAsAQAXiLDeAHPvoDa9RCOXrjQfPpG0B AIiJtAAAkBYA
ANICAGxvPHhmug535ARnuQGUYtXvPA5zzvyNB8/k1DppAaAaObU/SUBaAECE 1sZHb3jNSQ6n
8eEOFedPz7PBy6Zsx6SbJ90MpAUAlFZgeFobzuOUbRH/ImGW9bRm/ItUZ3OH tABQotngOXj3
1OBhlvU3GjIuG3KFVRgYpAWAUhRcF+fv2TCLuLunqiczuIIWQCU0QXL+bMZF 0rVX0j2ukLYF
41sAxcLeF+NIP+AkczbPppzHv0gVnuIWEfWpB7WIvHw930CgOFFRMeNbLF28 aNIV1wp3FayI
5przaTroiQIAZEZaAABICwAAaQEAKAx+bwEgx7gXLG0LAABtCwDIztLFiygE 0gIAgnguzy9N
Z/9AROTmYYvOPe8ce8rKFavsx8MaTuBDDEBPFACAtAAAkBYAANICAEBaAABI CwBAJWF8C6DI
2PsK61iKIKu0qJg77ANlFxXsfSgL9EQBAEgLAABpAQAgLQAApAUAgLQAAJAW AADSAgAA0gIA
QFoAAEgLAABpAQAgLQAApAUAoHIxvgVQZOx9hcX94bNLC+6wDxQrKtj7UBbo iQIAkBYAANIC
AEBaAABICwAAaQEAIC0AAKQFAACkBQCAtAAAkBYAANICAEBaAABICwBA5WJ8 C6DI2PsKi/vD
Z5cW3GEfKFZUsPehLNATBQAgLQAApAUAgLQAAJAWAADSAgBAWgAASAsAAEgL AABpAQAgLQAA
pAUAgLQAAJAWAIDKxfgWQJGx9xUW94fPLi24wz5QrKhg70NZoCcKAEBaAABI CwAAaQEAIC0A
AKQFAIC0AACQFgAAkBYAANICAEBaAABICwAAaQEAIC0AAJWL8S2AImPvKyzu D59dWnCHfaBY
UcHeh7JATxQAgLQAAJAWAADSAgBAWgAASAsAAGkBACAtAAAgLQAApAUAgLQA AJAWAADSAgBA
WgAAKhfjWwBFxt5XWNwfPru04A77QLGigr0PZYGeKAAAaQEAIC0AAKQFAIC0 AACUj95rojp2
baMsgGJIsPcV1tEUQVZpMbT+KMPoF36xjl3boi4CxPbwC29OOmt4f+miKOB2 2KAhUSsuCi3b
tDCMfm93mDv2SHeX2d1tJS0xLbG0JSKmpbTWlmVY2kpa+qTj+o0b2X/P/uTh R/Qu8va7Xaal
ahKRX1trne+3Z1oqWnHk/11E3aSK2aoYH7f9vRo3wphy4bgHf7nua+cPY4+F W4yKi0LLNi1E
ZMceOXyg0VVrdPdYplba1JaltGjTUpa2TEuZpnT3WG9u6Ro3sv/u/Ulnkc4D /U0dKy2s/KeF
zn9aRHwXUTepYrYqxsdtf6/Wb9l//DG1Hfu7xeA0G7xiVFzINi26u8yuWsMy LdNUpilJS2mt
725pmTm9WSxliiRNES0qoURk1z7TWUQMSVhaRT9hro28p0UiYg1VgHeRiF5p VsZWxfi47e+V
/ZXr7lFKKfZYePgrrtlz5866dYapJV3FhazTImnZ4Zw0ddIUEbm7pUVE5ra2 TL1pZm8FocTQ
WkT2HegRke5uq7vHEktEpPd/kVglVxx5ehfjRyfWbTb9/xZ3qwpdVlbMV1Gi RESLJi2QIi36
Vlx2rTXn3nnTbm52+lc9FReyTwuVTIpl9/dZ1px759nTp940U2utRStR+mBf wIEuLSJJS0yt
LFFatDKj78n53/e1RGxb5O1dvLLOHD864fn3jPE1xd2q2AUVZ6tUnI/P/SrK SLDHwpcWfSqu
WbfOsOuuBd9ruenG5pQVF7JNC21p0xLRWmtxouLGG2fYp4wsUYarQkmaFDoK zaBtAf8hhavi
UoayD3Dv//5cEfn+Ay3X39hMxZX7tOgxddIUJerulrn2lOlNM0Rkf4/zoShD tKWV2F2BIqYl
2tSmVoaIGaOfIf/nLKO+QqHfhS6VrYrxJiJvlRHnTfR5FUXbAl5OxWUfShzo sfr309ObZrTO
nyciPzgYGO6KC1m3LbTWltainaZc6/x5jU0zDs2gtKkl4arhLG1ZltKWNg3R 0bullZX3Q0Uz
Yg2Vt3eReh6zyFsVv6BibFWMj9v+Xjm9ZIZB2wJeSdPOgN4vSY2hTJF7W1vs P6+7aYYWndRa
LC2xelyR4niv21TdpjJFmaJm3tpsT1w4f15Nf5VUYv/XY+lu06DQUSSK//iv 739iajGtQxMs
UU5UTJk6o7fussTSXH6du7ZFMtnbTFOitKFvnd5sF/r372u5vqk5aUnStH9f Zbn6IlTSkk57
Qkme5Y7eGMnLu/jTm9ahfzcc+rfTKuZWFbqsVMxX6dF0QCF926JvxXVva29H +k23NJtaUlZc
yEFPlF3oCcMyk0pEGptmLJw/7/qmZm1pbYlYorV29570JHVnt06a2rRUTfTP QqvS+y133t7F
xNGJpKknjk50JeWEMTXOv8XdqtgFFWOrYnzc9vfKsiwRMQyDniik+F71rbim NTYvWNgytWlm
0u5aT1VxIdu0sCzLtEytDMvSIlqLtizjhqm3Wt06KWJZlmWJ0r2dyPYl8ElL d/dYopWhLSP6
oWMBLk8wdLQqrQDvIuomVcxWxfi47e+V/SPw2oTwewv4+SuuG6fOMJOmtlS6 igvZpsVHxvVb
v6VTW8o8WKB2+Zo6oUQM0crS2tL/NKZGRIYMTIjIScf1e3NLV8KQpNV77Vok ifyf/EhGrAML
8C6S0RsKlbFVMT5u+3tlf+WGDqpjd4VfjIoLWaXFK2veOevEEccfUxtmmWdf 3XbuSUNFZNzI
/uNG9qcQkW9P/37rledzo2l4xai4Fqyh2LJLi4nHDnp61eYdezr3faB7zJ7u pFLassT53Xzv
g341xhGDaq88/2jp2dWxa1tXt7VhR9fatz6gHJE/w4f2+8yJQ6Rn1+4OCgN9 TDx2SNSKi0LL
Ni0u+/kgkUGhltgji38mjCiCgvoLRYB0clZx7dyxltIMwDXIAIAQbYubhy2i FABUs5UrVlEI
Gan3trdTCgCAYPREAQAy+3/axNiq2hlS8gAAAABJRU5ErkJggg==
--------------040007090709030307080803--
Re: AGR - problems with view menus [message #66426 is a reply to message #66013] Thu, 13 April 2006 15:29 Go to previous messageGo to next message
Yes, the toolbar menu is not supported.
You can open a defect and I'll try and attend to it.
"daniel" <daniel@parasoft.com> wrote in message
news:e1h4ga$mjv$1@utils.eclipse.org...
> more clear.
> menu.
> Daniel
> > Hi Daniel,
invoking
the
> >> Hi,
menu.
to
return-code="-1">
> > .1}}{{&amp;Package
> >> S}}-{{0.2}}">
> >> </command>
> > ts.Tree#1"
> >> <shell
> >> return-code="0">
> >> </shell>
> >> </shell>
> >> </macro>
> >> item: ...
Re: AGR - problems with view menus [message #66615 is a reply to message #66426] Thu, 13 April 2006 16:57 Go to previous message
Thanks Ali,
I put the bug url here in case anyone else wants to track this issue.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=136756
Previous Topic:What’s New for Callisto?
Next Topic:TPTP crashes eclipse help
Current Time: Tue Nov 11 12:07:32 EST 2025
Powered by FUDForum. Page generated in 0.03965 seconds
