Home » Modeling » GMF (Graphical Modeling Framework) » How does one create pre-defined fixed elements/figures?
How does one create pre-defined fixed elements/figures? [message #65143] Wed, 18 October 2006 09:02 Go to next message
For my application I would like to have the graphical editor come up
with two predefined containers (I fancy two large labeled rectangles)
inside which the user then starts creating sub-elements and connecting
them, etc.
This corresponds to two top-level elements that *always* have to be
present in the XML files that I am dealing with. I don't want to have to
create these outermost elements, they simply should be there right from
the begin (i.e. even if creating an new "empty" file or model).
Can one create such fixed and predefined figures? How?
Michael
Re: How does one create pre-defined fixed elements/figures? [message #65230 is a reply to message #65143] Wed, 18 October 2006 09:39 Go to previous messageGo to next message
You may remove tool references for this "fixed" mappings in the Map model,
effectively removing creation tools for them.
Then write custom code that creates this 2 fixed elements in the generated
<Model>DiagramEditorUtil#createInitialModel(), something like
* Create a new instance of domain element associated with canvas.
* @generated NOT
private static org.eclipse.uml2.uml.Package createInitialModel() {
org.eclipse.uml2.uml.Package root = UMLFactory.eINSTANCE.createModel();
root.setName("Model");
createDefaultPrimitiveTypeImports(root);
return root;
Michael
"Michael Moser" <mmo@zurich.ibm.com> wrote in message
news:eh58lc$760$1@utils.eclipse.org...
> For my application I would like to have the graphical editor come up with
> two predefined containers (I fancy two large labeled rectangles) inside
> which the user then starts creating sub-elements and connecting them, etc.
> Michael
Re: How does one create pre-defined fixed elements/figures? [message #65251 is a reply to message #65230] Wed, 18 October 2006 09:59 Go to previous message
Wow - *that* was easy! And it worked on the first try... unbelievable!
Thanks!
Michael :-)
"Michael Golubev" <michael.golubev@borland.com> wrote in message
news:eh5arh$3l4$1@utils.eclipse.org...
> model, effectively removing creation tools for them.
> generated <Model>DiagramEditorUtil#createInitialModel(), something
> like
> * @generated NOT
> return root;
> Michael
>> to create these outermost elements, they simply should be there right
>> from the begin (i.e. even if creating an new "empty" file or model).
>> Michael
Previous Topic:Compile error in code generated from the GMF tutorial's mindmap example.
Next Topic:How to replace the view of an existing element
Current Time: Sat Aug 30 23:49:05 EDT 2025
Powered by FUDForum. Page generated in 0.03120 seconds
