Re: InterruptedException in aspectToolProvider [message #649226 is a reply to message #648803] |
Tue, 18 January 2011 09:53 |
I tried to reproduce again thjis bug, but was not successful.
1. I created a test.profile.uml, with a stereotype that extends the metaclass Association. Save and define it.
2. Create a model with class diagram displaying 2 classes, and the previous profile applied on it.
3. customize the palette, using the tool Association with stereotype applied
4. add to this tool the post action on properties
5. set the target property aggregation = composite and navigable = no
6. set the source property = navigable
7. Use the tool on the diagram between the 2 classes: no exception, and it works.
Could you try the same steps with the following zipped project: Zipped project
I found the code editpart.performRequest at line 280. Was it a typo mistake from you?
HTH
Rémi
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.04771 seconds
