Home » Eclipse Projects » Plugin Development Environment (PDE) » Filtering a fragment on criteria other than Eclipse-PlatformFilter settings
Filtering a fragment on criteria other than Eclipse-PlatformFilter settings [message #65117] Fri, 19 June 2009 11:53 Go to next message
Is there a way to filter whether a fragment and hence its host plugin get
resolved on criteria other than the Eclipse-PlatformFilter settings?
Ideally I would like to be able to provide a class that answers whether
this fragment should be resolved. Or someway to extend what is allowed in
Re: Filtering a fragment on criteria other than Eclipse-PlatformFilter settings [message #65161 is a reply to message #65117] Sat, 20 June 2009 10:03 Go to previous message
> get resolved on criteria other than the Eclipse-PlatformFilter settings?
> in the Eclipse-PlatformFilter settings?
Can you be a bit more specific on what you want to do? What outside of
dependencies and Eclipse-PlatformFilter do you need (note, as of 3.4,
you can use system properties in platform filters which offers even more
flexibility)?
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Filtering a fragment on criteria other than Eclipse-PlatformFilter settings [message #598432 is a reply to message #65117] Sat, 20 June 2009 10:03 Go to previous message
flexibility)?
Previous Topic:JSSE provider in Eclipse (Expeditor) project
Next Topic:How to run simple unit tests?
Current Time: Wed Jul 16 07:58:03 EDT 2025
Powered by FUDForum. Page generated in 0.04202 seconds
