Home » Archived » Test and Performance Tools Platform (TPTP) » eclipse automatically exit
eclipse automatically exit [message #65083] Thu, 06 April 2006 23:55 Go to next message
Originally posted by: tintu.XXX.com
hi
while profiling the project eclipse automatically exiting
and showing the error in jvm
why it is happening
and how to solve the problem
thanks
tintu
Re: eclipse automatically exit [message #65350 is a reply to message #65083] Mon, 10 April 2006 17:01 Go to previous messageGo to next message
tintu wrote:
> hi
> why it is happening
> thanks
> tintu
What is the error message from the JVM?
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: eclipse automatically exit [message #65476 is a reply to message #65350] Tue, 11 April 2006 00:03 Go to previous messageGo to next message
Randy D. Smith wrote:
> tintu wrote:
>> hi
>> why it is happening
>> thanks
>> tintu
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x807A016
Function=[Unknown.]
Library=C:\Program Files\Java\j2re1.4.2_04\bin\client\jvm.dll
NOTE: We are unable to locate the function name symbol for the error
just occurred.
i changed the jre , but also the same error is occuring
in the same path is showing
please find the reason
thanks for reply
tintu
Re: eclipse automatically exit [message #65539 is a reply to message #65476] Tue, 11 April 2006 09:27 Go to previous message
>> tintu wrote:
>>> hi
>>> why it is happening
>>> thanks
>>> tintu
> PC=0x807A016
> Function=[Unknown.]
> just occurred.
> thanks for reply
> tintu
In your other message thread you mentioned Eclipse 3.2 and TPTP 4.1.0.1.
TPTP 4.1.0.1 has as its Requirements Eclipse 3.1.2 and EMF/XSD 2.1.2.
Eclipse 3.2 is used with the 4.2 releases of TPTP, not 4.1.0.1.
It looks like you need to choose whether you're wanting to work with
releases (Eclipse 3.1.2 and TPTP 4.1.0.1) or with the development stream
(Eclipse 3.2M5a and TPTP 4.2M5, for example).
RDS
Previous Topic:TPTP 4.1 install problems [java.exe - Ordinal Not Found]?
Next Topic:Verification Hook class problem in Linux
Current Time: Sun Jul 27 02:05:38 EDT 2025
Powered by FUDForum. Page generated in 0.03928 seconds
