Home » Modeling » BPEL Designer » If activity in BPEL2.0
If activity in BPEL2.0 [message #5828] Thu, 31 August 2006 09:42 Go to next message
Looks like there is an inconsistency between BPEL 2.0 spec (both v 1.168
and the last public available on http://www.oasis-open.org - from
2006-08-23) and eclipse.bpel parser about If activity syntax:
Specification declares syntax as following:
<if standard-attributes>
standard-elements
<condition expressionLanguage="anyURI"?>bool-expr</condition>
activity
<elseif>*
activity
</elseif>
<else>?
activity
</else>
</if>
but parser doesn't recognize 'then' activity in such case (null value of
then reference). After some experiments I've wrapped activity with 'then'
element and all went ok.
Rykovanov Dmitri
mailto:drykovan@abisoft.spb.ru
Re: If activity in BPEL2.0 [message #5848 is a reply to message #5828] Thu, 31 August 2006 11:54 Go to previous messageGo to next message
Rykovanov Dmitrii wrote:
> Hello,
> standard-elements
> activity
> <elseif>*
> activity
> </elseif>
> <else>?
> activity
> </else>
> </if>
Yeah, I think OASIS may have changed their mind about the syntax since
we initially implemented the activity. Could you please open a bugzilla
bug so that this gets tracked and fixed in our model?
Thanks.
james
Re: If activity in BPEL2.0 [message #5885 is a reply to message #5848] Fri, 01 September 2006 04:19 Go to previous message
I've added new bugreport about the problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=155939
Rykovanov Dmitri
"James Moody" <James_Moody@ca.ibm.com> wrote in message
news:ed70o3$dt7$1@utils.eclipse.org...
> > Hello,
1.168
> > standard-elements
> > activity
> > <elseif>*
> > activity
> > </elseif>
> > <else>?
> > activity
> > </else>
> > </if>
'then'
> Thanks.
> james
Previous Topic:Eclipse plugin - can't get it to work
Next Topic:The very begining fails
Current Time: Sat Jul 26 20:10:38 EDT 2025
Powered by FUDForum. Page generated in 0.02997 seconds
